Helmet Rules
1 Post
St. Jude Donor '05 '09
Helmet Rules
I've never posted in this AX-RR forum (I usually stay in the C6Z06 stable), but I'm in the process of buying a helmet and I've noticed some amazing deals on open face helmets. Is there a new rule that says that [even in a coupe/hardtop] goggles are required with an open face helmet? Or is there some new obscure rule that makes open face helmets really unwanted??? TIA
Tom
Tom
What type of racing is this for? For AutoX I think as long as it's Snell M2005 Rated it's ok, whether that be open or closed. SA2005 is even better, so that will work too.
1 Post
For Snell Foundation helmet test ratings, SA is an automotive (motorsports) rating. An M rating is for motorcycles. Some track days will allow an M-rated helmet, and some may not.
The best thing to do is to check with the event sanctioning association to see if there is a specific requirement for an SA rated helmet or if an M rated helmet will work. Open or full-face styles are usually a personal preference and can depend on whether or not a driver wears glasses, or has problems with perpherial vision when wearing full-face helmets.
Most HPDE/track day events want you to run with side windows down and it's easy to get "marbles" or even pebbles tossed up by a car in front and manage to find their way inside your interior and possibly hit you in the face. A full-face helps here especially one with a face shield.
I have a Bell Mag 4 Racer Series Open face helmet and it works fine for me for track days. But I wear glasses so an open-face helmet is easier to put on as I don't have to remove my glasses. I can also change to sunglasses without removing the helmet.
A Mag 5 SA-rated helmet should work fine for HPDE. IIRC, the Mag 5 has a Nomex lining where the Mag4 does not. If you decide to go into SCCA competition, you might want to go with a full-face helmet with Nomex lining. That way, when you buy a Nomex suit, gloves, and belaclava/scarf you will have good protection against fire. Make sure the helmet will work with a HANS device too.
Received 8,928 Likes
As far as HPDEs I have never been to one that required anything but a current or near current Snell Rated Helmet (one that I know of still accepts Snell 95 Helmets). The operators of the events did not have any rulings on Open or Closed Face Helmets or on the use of HANS devices either. However, a fair number of people participating in these events now use the HANS. I have never seen a HANS device attached to an open face helmet and I suspect that it might not work very well with one but I am no expert on the subject.
Head and Neck Support (HANS). Keeps head and helmet from moving forward/sideways during an incident thus reducing the chance of a basal skull fracture which is usually fatal.
Bill
Bill
SA 2005 is just perfect, a HANS is nice but should not be use without harnesses, and race seats, PLUS roll cage, or Harness bar ( but is still questionable)
Open or Closed face is a personal choice. Many ppl prefer close face helmets with the eye shield down.
Too much stuff flys into the cockpit and can bounce off your chin, sand, bugs, track turds, broken car body parts that get picked up off the track or if you hit a tire wall, Like I did, my drivers side mirror bounced out and hit my chin gaurd then landed on the right side of the dash in one piece. Could have broken my chin.
If you are going to run just SCCA PDX's, a Snell "M" rated helmet is OK. If you are going into full club racing, you will definitely need a current "SA" rated helmet.
Don't forget it depends if running open or closed cockpit .Most clubs still allow M rated but keep in mind what they are designed for and what type of impact. Shortly they will be phased out after 2009 if I'm not mistaken.I recommend driving with the face shield down ,you just can't react fast enough .
Not after 2009 at the end of 2008.
Most clubs no longer allow M ratings for track days or HPDEs.
