Question for those with LS2 & LS3 motors
Old 09-07-2010, 05:53 PM
geerookie
geerookie's Avatar
Default Question for those with LS2 & LS3 motors
Do you guys have the same problem with oil in the intake as those of us with LS1 and LS6 motors?
Is there a need for an oil catch can on these motors?
Old 09-07-2010, 06:04 PM
AU N EGL
AU N EGL's Avatar
LS3s need a dry sump
There is a thread on here about LS3 oiling issues
Old 09-07-2010, 06:10 PM
geerookie
geerookie's Avatar
Thanks for the headsup, I was aware of that issue. I have a friend who wants to put an oil catch can on his C6. I didn't think those motors had the same PCV issues that the LS6 and LS1 have. Therefore I was thinking the catch can was a waste of money.
Old 09-07-2010, 06:39 PM
Maynor29
Maynor29's Avatar
Can't comment on street use by my track-only LS2 does get a ton of oil in in the intake under high-g, high rpm conditions.
I'm about to install a dual catch can setup to see if that resolves it until I go full dry sump for my winter upgrade.
John
M3 LS2
Old 09-07-2010, 07:15 PM
geerookie
geerookie's Avatar
John
M3 LS2
That's what I was looking for. So it appears it may be a characteristic of the LSx motors in general. Of course one example doesn't make the case but we'll see.
Old 09-07-2010, 07:24 PM
J.R.
J.R.'s Avatar
Install a catch can in LS1, LS2, LS3 and LS6 engines.
On LS1 engines use the LS6 valley cover.
Of course dry sump is always good but obviously expensive.
Old 09-07-2010, 09:42 PM
longdaddy
longdaddy's Avatar
i've never had oil in the intake in my LS6. did have this in my LS1 car.
Old 09-08-2010, 07:20 AM
fred_S
fred_S's Avatar
I have an LS2 engine with Elite Engineering Catch can, and after a 5000 miles and two track days it was about half full with oil. So in my case it's catching oil like it is supposed to.
Old 09-08-2010, 09:32 AM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
I run the snot out of my LS2 and generally put about 1/2 quart over or a bit less in at the start. I have an OCC but do not get much in it at all.
When I put more than 1/2 quart over, then I get a full OCC and blowby.
It seems to do very well with just a bit over full, anything else is wasted into the OCC
Old 09-08-2010, 10:02 AM
geerookie
geerookie's Avatar
Thanks. This is helpful to know.
Old 09-08-2010, 01:11 PM
waddisme
waddisme's Avatar
My LS2 has a occ and and oil cap breather. I usually add up to an extra quart before each track day. Somewhere I lose about 1/2 a quart per track day, but occ only has 1-2 tblsp. When I removed intake a couple of months ago after 4 track days in 4 mos, it was clean as a whistle. Not sure where it goes, but at least it is not in the intake. I had the same set up on my sc LS6 and when it blew, there was just a small amount in the intake valley after a summer of track days, but occ would get 1/2 full after every other track day. HTH.
To Question for those with LS2 & LS3 motors
Quick Reply: Question for those with LS2 & LS3 motors
