Why don't many Corvette racers use Canards?
I think they may be against some rule in SCCA, but as far as NASA goes, very few vette racers actually use canards...and I have always wondered why, since they seem to provide pretty good benefits in theory...
Are they against the rules? Do they not work? Is what they do negligible?
What am I missing here?
Hmmm, so if you get the right size and angle canards you might be able to just run canards instead of a splitter/undertray? I could probably fab up and attach some canards myself for $40 in materials... I'm sure the splitter/undertray produces better aerodynamics, but for just a little front downforce maybe canards are a cheap/easy solution.
they don't always work....in many cases, vertical flaps in front of the front tires are more effective. Race Care Engineering did a comparison a few years back, and they don't work as well as intuition would suggest in most cases.
Search past Race Car Engineering article as per David. They give you pretty exact numbers.
The drag to downforce coefficient is not as productive. i.e a lot more drag as to down force as compared to a splitter. Some of the European touring cars on short tracks and high HP run these regularly.
Not sure if I did, or how I could have, but I am not inferring that canards be used in place of a splitter...I mean as an addition.
I thought the bigger reason for the canards (instead of creating downforce) was to direct air away from the lower side/body/wheels of the car and up to the outer edges of the rear wing...whereby making the wing more effective and reducing the drag on the wheels/wheel wells and possibly even under the car.
Is that all just a load of crap?
Would running those same vertical flaps over the rear tires also help as well? or has the air already been deflected upwards at that point?
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
What I read is they are very hard to get right and guessing is a bad idea
So for DTM cars, the main purpose of canards may be to provide more downforce, but for us (and most other GT racecars), canards have a dual purpose. Yes, they may provide more downforce, however when done correctly they disrupt the airflow on the side of the car, REDUCING drag caused by the wheels/wheelwells. Anectodally, this has shown some pretty tangible benefits for people I know that club race.
For the vette though, its a whole lot easier just to put a flap in the leading edge of the wheel well for the same effect.
Former Vendor
I guesstimated where to put some on my FWD TT car just to see what would happen and the car was faster into the corners, mid turn and more grip on exiting them, at least by my butt dyno Actually the car was more stable under braking as well in the front but the rear wanted to start locking up, I have to take some rear brake bias out to compensate.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
We had them on our 2004 W.C. C5 because the car needed more front downforce, in addition to the splitter and hood.
I believe they were out-lawed in season's after that. I would say most of it is rules on why you do not see them more on the cars.
That's complex stuff and making it effective without CFD and wind tunnel testing isn't practical.
In terms of downforce, I think they're just baffles rather than airfoils, so they will have a poor downforce-to-drag ratio.
And they look dorky
