Active handling defeated!
#161
I just acquired a stock 1999 FRC, which I am preparing for Intermediate / Advanced HPDE.
The car displays a message "Service Tire Pressure Monitoring System", and the message cannot be cleared with the reset button on the DIC. In fact, I cannot scroll to any other feature of the DIC. Obviously there is an issue with the DIC and/or its motherboard in the instrument panel cluster (IPC). More info on that whole issue can be found here: https://www.corvetteforum.com/forums...working-2.html
I mention the above only as background for this:
I prefer to run multiple sets of track tires/wheels without TPMS. My plan has been to follow the suggestion of this thread and permanently disconnect the Steering wheel sensor (SWS). Thanks to those of you who discovered and analyzed this gem of a track tip!
Assuming that I can correct the DIC / IPC issue, and assuming that its message is correct that the Tire Pressure Monitoring System requires service (for normal stock function), will disconnecting the SWS eliminate my current TPMS issue (by rendering it moot) and allow remaining function of the ABS and TC as described in this thread?
Or must I repair the TPMS system even though I will not use TPMS sensors, and will have the SWS disconnected?
One more clue: the DIC does not display any pressures, or XXXX in their place. It displays only the quoted message above.
#162
Same here, it has an annoying yellow light that I covered, other than that unplugging the SWPS has had zero ill effects street driving or track.
#163
My friend who is a very experienced driver has a C6 and wants to turn off everything- is the fuse pulling the simplest way? I don't think he'd mind ABS.
Also, what does it do for mag ride? Does he have to be in competition mode for it to be stiff?
#164
If a C6, simplest way to turn off Active Handling and Traction Control is to hold the button down for 5 seconds, no fuse pulling needed. ABS is unaffected. However, there is no mag ride unless a C7, which someone else needs to chime in on, since I have a C6Z.
#165
What this whole thread is about has to do with the fact that with the active handling turned off in a C6, if you have a tire pressure sensor fail, a TPMS problem, or don't have sensors in your track wheels, the active handling automatically turns back on to a very intrusive mode, and the car goes into a limp mode that doesn't give any throttle response when you're in a turn, and limits speed even when going straight.
Pulling the steering position cable allows you to run on track without tire pressure sensors, or with a failed sensor, without the terribly intrusive mode of active handling and the limp mode.
My 2005 C6 had MSRC!!
My C6 ZR1 has MSRC!!
There are LOTS of C6 Vettes with MSRC, and one of the inputs into the mag ride control module is steering position angle.
When any of the inputs into that module is lost, you'll get a "Service Ride Control" message and the mag shocks go full soft.
So...I don't think you want to pull the steering position cable on a car with mag shocks whether it's a C7 or a C6.
village idiot (03-14-2018)
#166
If you turn off all the nannies by holding down the TC button, what "mode" does it put the shocks in?
Also, what happens if you pull the fuse with no TPMS for the mag ride?
#167
#168
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
newbie here...just got a 08 ZO6, read the whole thread and still don't get one thing.
If I don't install TPMS in my track wheels, will the car's AH remain fully functional? other than a warning that TPMS is faulty?
tommyc6z06 (03-15-2018)
#170
Received 8,930 Likes
There was no way around this other than purchasing LG's module that programmed the system to ignore the issue or by unplugging the steering sensor which then disabled Active Handling but didn't bother ABS or Traction Control. With Active Handling disabled it didn't matter whether you had a sensor reporting 0 tire pressure or no sensors at all the system couldn't use AH to apply the brakes so you could keep on driving.
If you have a C5 or C7 there is no need to pull the steering sensor connector because these systems don't react the way the C6 system does. Both the C5 and C7 can run at speed with no sensors in the wheels. Their systems warn the driver but don't intervene in the operation of the vehicle. I think the C6 got hit by some lawyer's liability concerns and once they incorporated the sequence in the system they didn't get rid of it until C6 production ended. I also believe they got an earful of complaints about interfering with how owners wanted to drive their cars.
Bill
HC Mechanic (04-25-2018)
#171
#172
Ok, got it. Sorry for the naive question that has probably been answered many times, but I’m new to this.
Thanks!
Thanks!
#173
Wanted to ask this again:
#174
Pro Mechanic
On my C5 z06 we did this back in 2003, during the One Lap of America. The active handling was malfuntioning and DRM contacted GM and was told that disconnecting the steering position sensor was the way to completely disable active handling without affecting abs. I always wondered if that would work on C6s. Guess we have our answer.
I have done this to everyone of my GM vehicles since 2003, Works in my 2012 Silverado, Pontiac, 05 Vette. Cant drive in snow with active handling. Prior to steering sensor disconnect Silverado would turn active handling back on over 45 mph.
HC Mechanic (04-08-2018)
#175
It’s really nice driving now and not getting any surprises. For me it’s better all around with it unplugged.
#176
How is C5 Traction Control affected?
In a 1999 FRC:
I have unhooked the steering wheel position sensor (SWPS) to deactivate active handling. That seems to have also deactivated traction control; pushing the traction control button no longer causes any change in dash display, and the amber traction symbol (near the speedometer) is constantly lit.
I am unclear on whether disconnecting the SWPS deactivates TC. Some threads say that TC remains active while others say that it is deactivated along with active handling. Prior to this, I have been unconcerned about that, as I am willing to drive without the nannies (ABS remains active).
But on my first track day with this car, I noticed a strong vibration when accelerating out of curves (especially left hand turns). The vibration was proportional to RPM, and I could reduce it by taking a wider line through the curve.
This experience makes me wonder: Might Traction control still be available with the SWPS disconnected, and if so, might my vibration be the TC system trying to kick in and do its job? In which case, maybe my amber idiot light on the dash is telling me the TC really does require a repair.
#177
So we think that just turning off everything keeps the MRC in a soft mode. Is there any way to defeat TC but keep suspension stiff?
#178
In a 1999 FRC:
#179
#180
In a 1999 FRC:
