Neutral Safety Switch Located on 66 With auto
Old 08-24-2005, 09:33 PM
Stingray_RSSS
Stingray_RSSS's Avatar
Default Neutral Safety Switch Located on 66 With auto
Since my reverse lights don't work I am trying to find the neutral safety switch, can anyone tell me if its on the column, which if so mine's missing, or is it mounted on the tranny which is a 2 speed powerglide.
Old 08-24-2005, 09:53 PM
67L36Driver
67L36Driver's Avatar
My '67 CSM shows it on the floor shift under the console.
Old 08-24-2005, 09:58 PM
Stingray_RSSS
Default Neutral Safety Switch Located on 66 With auto Reply to Thread
Thanks for the reply, I just love this site! I will start there tomorrow.
Old 08-25-2005, 01:38 PM
DZVette
Support Corvetteforum!
DZVette's Avatar
Stingray
If it's like my 65 PG, it looks like this. It mounts to the shifter with a screw on each side. The hole in the plate on the switch goes over the little nub on the shifter (red arrows). The tang on the shifter engages the little slot on the switch (pink arrow) to move it when you change gears. The NS switch is the purple wires and the back-up lights are the green and black. Note, that this one has been worked on (or over) by a previous owner. Works fine though.
Good luck
DZ
P.S. Can send you more pics of this job if you need them. Can you handle PowerPoint files?
Old 08-25-2005, 08:23 PM
Stingray_RSSS
Thanks for all of the information, yes if you have powerpoint pics, feel free to send them to gtpstealth@yahoo.com. I appreciate all of your help!
Dennis
Old 08-25-2005, 09:41 PM
DZVette
DZVette's Avatar
Dennis
Files are headed your way!
DZ
Old 08-29-2005, 11:50 AM
michaeliss
michaeliss's Avatar
Default Powerglide NS BU light switch
Mine did not work either. Took the shifter a part. Plastic sliding piece was broken. Could not find a replacement with the normal vendors. Found a complete one nos on EBay. That EBAy has everything.
Old 08-30-2005, 04:45 PM
toadster
toadster's Avatar
Default Neutral Safty Switch
My PG has been replaced with a 700R4 trans, and now the safety switch seems to be out of adjustment. Sometimes in Park, I have to tap the shift handle forward in order to start. Also, it will now start in Drive, which is not good. Must be an adjustment, right?
To Neutral Safety Switch Located on 66 With auto
Quick Reply: Neutral Safety Switch Located on 66 With auto
