3M panel bonding
3M panel bonding
Check out this video. Better than Corvette bond?
http://www3.3m.com/metrics/redirect....EtuZP0DDDDC%2D
Any of the Epoxy adhesives will be much stronger than the Polyester based "Corvette" bonding adhesives. 3M, Duramix, and Lord Fusor to name a few. They are waaaay more expensive, but very nice to work with since the set times are relatively controlled. All require the use of a special applicator gun which at least the supply store I deal with will gladly loan you with the purchase of any of these products.
I have been using 3M Automix 8115 exclusively to put my frankenvette back together. It has pleny of "play time" and dries hard as a rock but is quite sandable. I also use it to fill the screw holes left behind, it won't shrink when it dries. Here's the new rear valance panel I just recently did before I sanded it:
Once I'm done sanding the seams down a bit I will build/glass them in. Being that I have the valance panels, a driver's side rear quarter panel and a new nose going on I will gelcoat the entire car (3 coats) once I'm done with the repairs. Other folks may use Kitty Hair or some other filler to finish the seams - different strokes for different folks.
