odd 63 electrical ?
Old Mar 29, 2007 | 04:14 PM
TTop Tony's Avatar
TTop Tony
Default odd 63 electrical ?
I'm replacing the ignition harness on my 1963 conv and I'm comparing the old harness to the new harness. Everything looks good except the end of the harness plugs into a metal 4 prong box that bolts right next to the radiator shroud and the end plugs look similar but slightly different. I was just wondering what is this electrical thingamabob and what does it do? Does anyone sell a replacement for it? It's bolted right next to the radiator shroud on the passanger side.
Thanks in advance
Old Mar 29, 2007 | 04:42 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Voltage regulator. Chuck
Old Mar 29, 2007 | 04:44 PM
TTop Tony's Avatar
TTop Tony
Old Mar 29, 2007 | 07:41 PM
ren's Avatar
ren
I'm re-wiring my 63 too. Finding many differences, primarily because my car isn't original. The voltage regulator is very easy to replace and should be available at any parts store for under $20. Good Luck!
Old Mar 29, 2007 | 07:43 PM
TTop Tony's Avatar
TTop Tony
Oh great thanks I was wondering if it was a common part. I just found out from teh previous owner teh part I have is from a Ford because the GM repro's kept going out.
Old Mar 30, 2007 | 10:19 AM
magicv8's Avatar
magicv8
I use solid state electronic regulators. They are available at local auto stores fairly cheap and quite dependable. I currently have a TransPo high performance version in my car holding down a 135amp alternator, but I don't think it's necessary for alts below 100amps.
Old Mar 30, 2007 | 10:24 AM
TTop Tony's Avatar
TTop Tony
magicv8 Did you have to do any special wiring for that? Sorry I'm not much of an electrician if you have any more info about that I would greatly appreciate it.
Old Mar 30, 2007 | 11:16 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
If you have the correct GM corvette harness & connectors it should be just plug and play
Old Mar 30, 2007 | 11:34 AM
TTop Tony's Avatar
TTop Tony
I understand but he said he used a more modern solid state version and my question is is that plug and play.
Old Mar 30, 2007 | 12:22 PM
vetsvette2002
The only difference is INTERNAL. The electrical connectors are the same. The newer version will operate better than the old.
Old Mar 30, 2007 | 12:25 PM
TTop Tony's Avatar
TTop Tony
SWEET! I'm sold
Old Mar 30, 2007 | 12:43 PM
JohnZ's Avatar
JohnZ
The solid-state Wells VR715 (AutoZone) is a direct replacement for about $15.00 or less, and it'll accept the original Delco-Remy cover if you want it to "look" original.
Old Mar 30, 2007 | 01:03 PM
TTop Tony's Avatar
TTop Tony
Thank you that's perfect. I feel better now. Don't want to ruin a new wiring harness.
Old Mar 30, 2007 | 05:01 PM
Seaside63's Avatar
Seaside63
Wow, thanks John !!
I'll go out and get one this weekend to avoid trying to restore and replate the original.
Old Mar 30, 2007 | 05:11 PM
Chuck Gongloff
Although it won't have the "512" or "515" stampings and the date on it. Chuck
Old Mar 30, 2007 | 05:28 PM
Seaside63's Avatar
Seaside63
Yeah, I know...
To odd 63 electrical ?
