Pinion Torque spec
Old Jun 26, 2007 | 10:49 PM
67's's Avatar
67's
Default Pinion Torque spec
I am changeing rear ends, and had to replace the pinion seal, does anyone know the torque specs, they are not in the Chassis service manual that I can see.
Tom M
Old Jun 26, 2007 | 11:15 PM
Hitch's Avatar
Hitch
Did you measure the amount of force required to turn the yoke first before you removed it? If not good and tight is you answer..
Old Jun 27, 2007 | 01:14 AM
John McGraw's Avatar
John McGraw
Tom M
Tom,
There is no torque spec for the pinion nut. You just tighten the nut to crush the crush sleeve until the preload on the pinion bearing is correct. There should be a spec in the manual for the force necessary to turn the pinion in the bearings, for both new and used bearings. Keep in mind that these specs are for only the pinion bearings and not the carrier as well. I will tell you that I have never checked the rotational force in my life. I just tighten the nut until the pinion bearing has just a light drag on it and then stop. I do not even have a torque wrench capable of reading low enough to check it. You would need a torque wrench that goes down to 10 in/lbs or less.
Regards, John McGraw
Old Jun 27, 2007 | 08:18 AM
Plasticman's Avatar
Plasticman
1st method (which is too late now), is to return the pinion nut to the same exact position that it was in prior to removal.
Optional method (which is also too late) is to measure the pinion torque (to turn the whole pinion/ring gear/axles/wheels & tires) while the rear is off the ground. Then tighten the nut back to where the pinion rotating torque is at the same point as before.
By using the above optional method, if you loosen the pinion nut (say 1/2 turn), and then take the rotating torque reading, you could then re-tighten it back so that it does not exceed that initial reading by any significant amount. I would then add a small amount of additional torque (to the loosened reading), just so I was assured that the nut was tightened. Do not confuse the rotating torque reading (the amount of torque needed to rotate the assembly) with the amount of torque needed to tighten the nut (which will be much higher).
Note that since the torque reading (when rotating the whole assembly) will be higher than when rotating via the spec setting of just the pinion, the actual rotating torque reading will be well within the range of the typical 3/8" torque wrench.
Good luck,
Plasticman
Old Jun 27, 2007 | 08:32 AM
GTR1999's Avatar
GTR1999
new bearings are 18-20 in/lbs used about 5in/lbs. Be careful not to over crush the sleeve when reinstalling.
If you PM me I'll link you with a full pictorial I have on this job.
Old Sep 7, 2007 | 12:49 PM
amcmast's Avatar
amcmast
You mentioned a link to a pictorial on this. Could you send it to me at ajmcmaster@buckeye-express.com?
Old Sep 7, 2007 | 05:08 PM
GTR1999's Avatar
GTR1999
PM sent but it is link for the 63-79 units.
Old Sep 7, 2007 | 06:38 PM
Silver63's Avatar
Silver63
Gary. Please foward the link to: cmarq820@aol.com Thanking you ahead. Clete
Old Sep 7, 2007 | 07:42 PM
darguy's Avatar
darguy
PM sent, can you hook me up as well?
Old Sep 8, 2007 | 11:57 AM
GTR1999's Avatar
GTR1999
Info sent
Old Sep 8, 2007 | 11:01 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Always interested in new ideas or any new information.
PM sent, I too would like a copy.
Don
Old Nov 1, 2018 | 02:14 PM
64corvet's Avatar
64corvet
5th Gear
This is the second time the pinion nut has come loose on my 64. I don’t know why it does this. How tight should it be so that it does not do it again? Bill..
Old Nov 1, 2018 | 02:29 PM
Critter1's Avatar
Critter1
You most likely need a new nut. Originally, these nuts had what is called prevailing torque. That means it's a self locking nut with distorted upper threads. If it has ever been removed with an impact wrench, the self locking feature is gone.
More important, read the threads above to understand how this nut is to be installed. There's a lot more to it.
Old Nov 1, 2018 | 03:04 PM
GTR1999's Avatar
GTR1999
DId you use Loctite on the nut? I always clean the nut and pinion threads with brake cleaner or Acetone then use #271 and stake the nut once in position.
Old Nov 1, 2018 | 04:00 PM
GTOguy's Avatar
GTOguy
This^^^. I've always counted the threads and marked the nut BEFORE removal to avoid damage to the crush sleeve on the re-install. Nuts that come loose should not be tightened beyond their original set position....they should be loc-tited or replaced with a fresh nut. Have had a dial inch pound torque wrench for decades for measuring drag on bearings, but after doing a few, as stated earlier, you learn to 'feel' what 5 inch pounds is versus 15. In both cases, you are talking about the amount of energy needed to turn equating with picking up a shoe to put it on your foot... Not much.........
Old Nov 2, 2018 | 02:01 PM
GTR1999's Avatar
GTR1999
Speaking of working on vette diff's. I was looking at youtube today during lunch break. There are some newer vette diff builds posted, if you follow what I saw I will guarantee the diff is not going to work too good. The one a saw today had some spec's posted up - completely wrong information. good luck
Old Nov 2, 2018 | 08:27 PM
Vette5311's Avatar
Vette5311
Default What.....
False information on the Internet? I'm shocked!🙄 As for pinion bearing preload (that's what we're dealing with here). There is only one way to set it correctly. Many people have many different ways of doing it and some occasionally work but there are pitfalls. GM built a differential that in most cases lasted 100,000 miles. To do it the right way there should be a new crush sleeve put in anytime preload is lost. The pinion nut which is torque prevailing should always be replaced also. I know you can lock tight it, add more crush on sleeve, etc. Not the GM recommended way. With a new crush sleeve and seal installed the new nut is tightened until the sleeve begins to crush setting preload on the bearing. Be careful it takes a lot of torque to crush it but once it starts to give it goes quickly. The proper amount of preload is measured in rotating torque of the pinion with an inch lb dial type torque wrench. The measure is rotating not what it takes to start it turning but what it takes to keep it rotating. Of course this is all done without the ring gear / carrier installed. The measurement is different for new or used bearings and they should be well oiled with gear oil for measurement. That is the correct way to do it. Not looking to start an argument just stating a fact. Again I know a lot of people do it a lot of different ways but this is the procedure by the book. Good Luck
To Pinion Torque spec
Old Nov 2, 2018 | 09:03 PM
Critter1's Avatar
Critter1
I agree with all of the above. Also, if the nut is torqued to tight and the torque required to rotate the pinion is above specs, it can't be backed off to bring it back in spec. Another new crush sleeve is required. (in almost all cases)
Old Nov 3, 2018 | 05:29 AM
tbarb's Avatar
tbarb
So in service if the seal is changed the nut is marked for an approx reinstall location. If not marked or the nut replaced the best you can do is lock the yoke in place and sneak up on the nut location by tightening to where all in/out movement of the yoke is gone, correct?
Old Nov 3, 2018 | 07:09 AM
MikeM's Avatar
MikeM
A local Chevy mechanic used to pull the crush sleeve out and lightly hammer the crush in the sleeve to flatten it a tiny bit. Then, re-tighten the nut to get the riight drag.
