valve eats 63swc
Old May 12, 2008 | 11:50 AM
abe g's Avatar
abe g
Default valve eats 63swc
Does the 63swc 340 High Power engine have hardened valve seats? OK without lead additives? Regards, Abe G
Old May 12, 2008 | 11:59 AM
blubu's Avatar
blubu
Default hardened seats
Not from the factory
Old May 12, 2008 | 12:20 PM
Plasticman's Avatar
Plasticman
No SBC stock cast iron head had hardened seat from the factory until (I believe) 1971 production, when GM started lowering compression for usage with non-leaded fuel. 1971 heads were induction hardened (integral cast iron seats hardened using an electrical induction process to heat treat just the seat area).
However, note that stock non hardened seats (pre 1971) will last a very long time, unless used under high loads for long duration. Street engines have not seen the valve and seat damage that was once thought very likely. Boat and race engines on the other hand need the hardened seats and SS valves (or other combinations as needed, such as titanium valves and bery-copper seats, etc.). Lead additives have not been seen to be necessary for street engines.
Plasticman
Old May 12, 2008 | 12:46 PM
Rob-classof'64's Avatar
Rob-classof'64
I'm not as optomistic as Plasticman. I have no personal experience, but around here the guys with HP C-2's generally use a lead attative or stainless steel valves. I know a few guys who have had problems from not using one or the other.
The old oz. of prevention beats a lb. of cure seems relevant here.
Rob
Old May 12, 2008 | 01:52 PM
JohnZ's Avatar
JohnZ
Hardened seats aren't necessary unless you're towing a trailer all day long at 100mph or the engine is in a boat; lots of perfectly good heads have been ruined during machining for hardened seats, for no good reason. Rebuilders will always recommend it, but it isn't necessary, nor are any "lead substitute" additives (which don't have lead in them anyway - they're mostly kerosene and alcohol).
Old May 12, 2008 | 01:55 PM
66BlkBB's Avatar
66BlkBB
St. Jude Donor '13-'14-'15-'16-'17
Won't say my engine is super high performance but I had the hardened valve seats installed in the heads in 1979. Haven't had a problem yet. I have been running the non-ethanol fuel but it doesn't have any thing for a additive to ease seat wear. Mine valves are the stock ones so I don't see where there would ever be any problem.
Steve
To valve eats 63swc
