Tech Section
The link is the same if if you use it and had it bookmarked it should still work.
http://lbfun.com/Corvette/Tech/vettetech.html
I wasn't able to solve EVERY issue i wanted to but I feel it's the best I could come up with to solve as many of the issues that I could, at least with my limited web development skills which are close to none actually.
If you come across any dead links please let me know in case I managed to miss one. I've tried to go thru and check everything but after staring at it for so many hours on end my brain is fried and it wouldn't surprise me if I missed some things somewhere.
Barry
Barry
With all you do you must love this stuff! We thank you very, very, very much.
Ummm kinda works for me. ....once it all loads...then page goes to chit.
Starts with all sections open while page loads...then once it loads.... all thesctions collapse but the links are still displayed...overtop of each other.
I'm running latest I.E 7.
Maybe its just me..
http://i42.photobucket.com/albums/e344/al329/BarryK.jpg
Maybe its just me..
it's your fault for using Windows and IE7!
I run all Macs here at home and things can and will display differently on a Window's based PC and IE7 is known to have various display "issues" as I see discussed all the time on a web development forum I'm on.
My monitor is set at 1280x1024 resolution and the text size INSIDE each Accordion section is set as a 10 point which shouldn't be too small to read - 10 point is typical size for magazine usage so should be plenty big enough to be readable.
What happens if you change the font size in your browser control?
Unfortunately I don't have a Windows based system here at home to test it out in either IE7 or Firefox.
On my Mac it displays perfectly in Safari, Firefox, Opera, and very old IE5. Without knowing what is causing it I am clueless how to fix it.
BTW, until the page loads completely the Accordion sections WILL all be open, it's how that page types works so that the Search Engines like Google can index the info in them. After the page loads completely is when they all close and is ready for viewing so that part is normal.
http://validator.w3.org/
So I opened up Firefox to check it out. Yes page loads correctly.....bUt when you open a section....the file names are so small you cant read em.
Yes I am using IE.
Roy
This may take a few days - sorry to all those that may need Tech articles in the meantime.
BTW, not that this is helping you guys with IE7 but this is why I'm confused........ it displays perfect on my system with the Accordion closed and open.
Closed Accordion
With Accordion section open
Seems MS had to muck around with IE again, seems they break a lot of sites with each new version
I'm running FireFox 2.0.0.14, Windows XP, and my monitor resolution is set to 1024x768
I'm in my mid 40s but am too old to read this small print
al, I have NO CLUE yet how to fix the display issues with IE7 but i'm researching it.
Jeff, seeing just how small the font is displaying for others in the content area helps since it's not that small on my system as I'm sure you can see from the screenshots I posted earlier. I agree, seeing your screenshot, that it's displaying way too small to be usable.
Now I have to figure out WHY it's doing it though.......
