Engine ID help please?
Old Sep 19, 2008 | 08:13 PM
Stevea62's Avatar
Stevea62
Default Engine ID help please?
I picked up this motor from a guy and I was wondering if anyone could tell me what it came out of? He seemed to think it was a Corvette motor, but I'm not sure.
Here are the numbers:
F280 on back of block
3756519 on back of block
F0706D on front pad
Thanks for your help
Old Sep 19, 2008 | 08:41 PM
Donald #31176's Avatar
Donald #31176
Cast June 28, 1960 & assembled July 6, 1960. "D" is not a Corvette engine trans code.
Old Sep 19, 2008 | 08:51 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
F0706D on front pad
I have some very old Chevrolet Dealer Service Information Bulletins covering model years 1963 - 1984. Based on these I suspect you have a 307/200HP that was used in Camaro, Nova, and Chevelle that was produced at the Flint Motor Plant on July 6 for many of the late 1960s model years. This is based on F0706D.
However, my "Corvette by the numbers" identifies block # 3756519 as a 283 block used in '59-'61 Corvettes.
I believe F280 represents the casting date of the block. F = June; 28 = 28th day; and 0 = 1960 model year.
Hopefully someone else can confirm or challenge my findings.
Hope this helps until then.
Old Sep 19, 2008 | 10:38 PM
john neas's Avatar
john neas
D 2bbl pass car powerglide
Old Sep 20, 2008 | 12:02 AM
Stevea62's Avatar
Stevea62
I also got the 283 Block used in a '59-'61 corvette?
Well I'm still a little confused lol
Old Sep 20, 2008 | 08:12 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
3756519 = 1958-62 283ci 170-315HP 2 Bolt passenger & corvette
Old Sep 20, 2008 | 10:21 AM
Mike Ward's Avatar
Mike Ward
This casting number, like most engine blocks, was not unique to Corvettes.
The D suffix at the end of the assembly code is not from a Corvette as others have said.
Last edited by Mike Ward; Sep 20, 2008 at 09:49 PM. Reason: still learning to spell
Old Sep 20, 2008 | 02:07 PM
JohnZ's Avatar
JohnZ
F0706D on front pad
283 block, cast June 28, 1960, assembled July 6th; the "D" suffix says it was originally a 283/170hp 2-barrel Powerglide installed in a passenger car.
Old Sep 20, 2008 | 10:02 PM
youngpup's Avatar
youngpup
2nd Gear
Default engien
F0706D on front pad
3756519 1958-62
cid 283
hp 170-315
main 2
body type passenger
corvette
this is what i have found
Old Sep 21, 2008 | 05:24 PM
JMR5's Avatar
JMR5
3rd Gear
Hey guys, I also have a 3756519 283, but on the front engine tab it shows F6I0CF. I don't have the casting date handy, but wondered if from the casting number on the front of the block you could tell if this was a vette motor. Thanks!
Old Sep 21, 2008 | 05:57 PM
Panama 58's Avatar
Panama 58
CF is not a Corvette suffix. Check out this site.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php
Old Sep 21, 2008 | 07:09 PM
JMR5's Avatar
JMR5
3rd Gear
Thanks Panama 58!! I've also been trying to determing if there is any info on the metal tag that is riveted to the front of my block reading...
Stock No
SS675
Rebuilt Engine
Power - Pak
I've read a few other threads that mentioned similar tags, but no real solid info on wether these tags were used by a specific shop or what.
To Engine ID help please?
