Pointless distributor conversion
Bill, any thoughts on finding one?
http://www.themotorbookstore.com/ignition-systems.html
And here's a kit to build your own transistor ignition.
http://www.electronickits.com/kit/co...ve/VEK2543.htm
Happy building!
Dave T.
Happy building!
Dave T.
there may be some merit to the second link as it may take the load off the points and use them as a simple switch to trigger the transistor; enabling the points to last 'forever' (or until the rubbing block wears...). if so, then it is probably an ideal solution and very inexpensive.
the old CD boxes, besides using the points as a switch, also amplified the spark from the coil and extended the spark duration a bit.
this kit would do neither, but it would probably eliminate burnt/pitted points; at the expense of a potential failure of an electronic component. BUT, a switchable bypass could be built into it to minimize that hassle; or it could be simply removed...
Bill
Having said that I've converted my '60 over to a Crane XR-i Fireball electronic ignition. Only had it in a few months. So far it seems to start better and run smoother. Will it be better long term? Time will tell...
Dave T.
Using your own methodology, the simple spark plug is 8 times less reliable than points. Why don't you stop using those too?
Oil?
Filters?
Tires?
Belts?
All evil.
The random, sudden, and totally irrecoverable failures of some electronic units is a different ball game.
Seriously, from all the electronic ignition questions that come up about ballast resistors, wiring configuration, types of coil to use, distributor shimming, etc. I'm sure that some portion (possibly large portion) of these problems are self-induced. I HAVE been stranded by points - in a VW beetle (no jokes please) in a dark bowling alley parking lot. The points were cracked across one of the contacts - never saw the like before or since.
This is one of those religious debates (like ZDDP vs diesel oil and Win vs Fram oil filters)...its all based mostly on opinion so each to his own I say...
I know people that have had the same points in their car for over 20 years and still going strong.
Since I was talking about a FAILURE rate between points and electronic conversion kits (remember what this defines!, see above) if you like to bet so much make a bet with yourself and go thru the forum achives. Find how many posts and threads there are about electronic conversion kits failing and the car died and/or would not start, than find how many threads and posts of people with points whose cars died on them while driving or would not start because of points failure. In fact, I challenge you to find any threads at all about someone whose car died on them while driving leaving them stranded because their points failed.
As it's already been pointed out before I could reply, points tend to slowly wear, and they give you warning that it's time to replace them (that's not considered a failure though) but electronic conversion kits fail completely without warning.
I use the most reliable spark plugs, oil, filter, tires, and belts available. Comparing spark plugs to points is an apples to oranges comparison that makes absolutely no sense.
In fact, Mikes relationships between those listed items of spark plugs, oil, tires, etc is closer in comparison to points than yours is between electronic conversion kits and modern electronic ignition systems.
What Mike was pointing out is that points can wear (bit that's isn't failure!) as do spark plugs, tires, oil, etc. For example, after installing a spark plug and driving 1,000 miles that plug has some wear on it but that doesn't mean it's now useless or going to leave you stranded on the side of the road so in that aspect it's the same apples to apples comparision to a set of points. Neither sparkplugs nor points have a bad habit of leaving you dead and stranded as electronic conversion kits have been known to do.
Maybe one day we'll talk about 'dependability' or 'durability' when you're ready.
Good luck.
If points don't fail, why do you replace yours every year?
Have you completed or reviewed a single scientific study on "ELECTRONIC CONVERSION KITS" to verify that "the percentage of failure on the electronic conversion kits is going to be much higher!"? Since you've provided no data beyond your personal opinion and conjecture, my guess is no.
Failure is when they stop working. You replace the points in your car yearly because you fear that failure is imminent and you wish to prevent said failure.
As I stated previously, replacing points in my car every year is completely unnecessary, especially because of the limited miles I put on it, but I do it because I enjoy working on the car and it's my way of spoiling the car with something it doesn't need bit i enjoy doing.
Electronic conversion kits, as I've mentioned and are commonly brought up as a topic on here, again, such as Pertronics, Breakerless SE, etc are very different things than "upgraded ignition systems such as MSD systems or modern electronic ignition systems such as you find in your daily driver car. As I keep discussing, the conversion kits sich as the Pertronics, et al, have a higher failure rate, period.
fine, out of the 850 million points (your own number) one set in a VW failed.
That's the first time I've seen anyone post about being left with a dead vehicle in 4.5 years on this forum but I still see issues being discussed weekly on problems with electronic conversion kits on herePersonally, i'm done debating with you because except on this last quote of yours you are only going in circles. Enjoy your conversion kit but i sure hope for your sake that you at least carry a set of points in the glove box on the chance that your module fails on yours. I'll be thrilled for you if you NEVER had to rely on those points but just in case something does happen at least you will be able to get home.
There are a few things that I know from around 50 years of driving and wrenching automobiles.
1. I have NEVER had a set of points or condensor fail. They to deteriorate and need replacing yes, but never a total 'call for help' failure.
2. The Delco Remy window cap disrtibutors make point replacement, especially with a uniset a rather simple, regular 'tune up' task. The engine will start and run with the uniset points installed right out of the box. The dwell may not be spot on but is easily adjusted. The conventional points will also work right out of the box and can also be easily 'gapped' with a feeler guage or even a match book cover until properly dwelled.
3. If a 'poinless' conversion does fail ....and you are not carrying an expensive replacement module, AAA is going to have to dispatch a roll-back... if your cell 'phone is woking. And folks, there really are places where there is still no cellular service. You know; some of those place where you would like to be anyway.
4. Replacing a failed 'conversion' with points requires removing the distribotor. An empty highway somewhere in New Mexico is not an ideal spot to be doing this sort of thing.
5. Contrary to product advertising and most individual's experience and testimonials, these unit WILL fail at least sometimes. Before my experience with the Ignitor II, the Impala that I was driving had to be towed because the Pertronix Ignitor I that was 'properly' installed in the distributor failed; something that I was assured by Pertronix would never happen with the Ignitor II. Grrr.
6. Needless to say, I obviously have a rather shallow learning curve. (I even had one of their high output low restance coils crack at the base of the negative terminal.) Pertronix cannot depend on me to be an advocate for their products.
7. Think I'm 'gonna stick with good 'ol breaker points and replace them when it's tune-up time... or as required.
Thanks to everone for their input. It's been enlightening. I really didn't intend to stir up such a maelstrom, but it's been educational ....and entertaining.
Thanks again,
Bob
Thanks again,
Bob
Frankly I think you have made the correct decision for your Vette. There are applications where an enhanced ignition is used or needed on a relatively stock older Vette, but in 99% of the cases, it is due to something else "broken", and the ignition change is a bandaid (example, a poor fuel/air distribution or mix resulting in lean/rich cylinders that require extra juice to fire them, or an undiagnosed mechanical issue within the distributor).
As for the point replacement modules, they work for the guys who won't or can't use the opportunity to properly tune up the old Vette occasionally. As I have stated before, just replacing the points does not result in zero periodic maintenance of the distributor. Cent. advance needs a dab of grease and verify the advance stop is still in place plus checking spring function, rotors and caps need checking and cleaning, vac. advance can needs to be checked for a blown diaphram and freedom of movement, shaft/bushings need to be checked for wear, etc., etc. And I have seen some electronic modules fail, which adds to the aggravation of purchasing a component to "reduce" worry, and then it strands you out in the boonies. And contrary to what some guys say, without changing the coil (to a coil designed to be optimized with the module) at the same time, that new electronic module is actually decreasing the coil output by a small degree (due to the inherent increase in resistance of electronic switches). Note that a set of points are current limited (an increase in current will burn up the points), whereas an electronic switch can easily be designed to increase it's current handling ability, resulting in a stronger spark. Not taking advantage of this is foolish (if adding an electronic points replacement module in the first place).
Note that I have experienced a set of Delco points that failed (the movable point spring actually broke). It is a rarity agreed, but crap happens. Does this mean that points are inherently failure prone? Obviously not, but poor manufacturing or materials plays a part and the more parts, the more prone to eventual failure. The beauty of most parts on our Vettes is that they fail slowly with ample time to warn us that they need replacing (if we look and pay attention to what the vehicle is telling us!). That sluggishness or noise is not there saying everything is fine!
With all that said, I am still in the points category. If I need to get in there and check the distributor occasionally anyway, then checking and setting the points is a no brainer. And my 62 is not "stock". With dual AFBs and an Offenhauser intake that has poor distribution at low speeds, plus headers and a decent performance cam, it performs absolutely great with a single set of Hi-Po Delco or Echlin points.
One last note: A CD ignition does not increase spark duration. The duration is actually much shorter than a typical inductive coil spark, and the prime reason you not find them on OEM emission controlled vehicles (too short a duration to ensure complete combustion through out the cold/hot and full rpm range of conditions for minimum emissions). Now the MSD (multiple spark discharge) CD ignitions cover that up by firing several times during the power stroke, but then again their overall reliability is very poor (for a variety of reasons) in comparison to OEM requirements.
Plasticman
Lars did a tune-up on the engine (his usual..., shim the distributor, adjust, adjust carb, etc.) and all of a sudden, when you jumped on it, it would cut out under load when the secondaries opened (due to increased cylinder pressures presumably).
With the Mallory, if the box fails, there is a simple jumper plug to install and you are back on points (takes about 30 seconds). I put the jumper in and removed the ballast resistor by-pass wire and we jumped back in the car and it ran great!
OK, the next day I pulled the fuse on the Mallory and it had corrosion leading to a weakened current flow (?). I cleaned the fuse and its holder, reinstalled it, and the engine again ran fine to redline on the Mallory.
Another case in point. The points can get out of adjustment, but the Mallory box compensates. Regardless of when the point "strike" or for how long, the Mallory sets the duration. At one point I put in the Mallory bypass jumper and the car wouldn't even fire because the points were so far out of adjustment. I reconnected the Mallory and the car ran fine and this let me reset the points "on the fly." Afterwards, the car again ran fine with or without the Mallory.
BTW, with the Mallory, the points only act as a switch and don't carry any real current. I've had the same set of points for ~15-20 years and they look like new (though the car does sit most of the time).
I have had one Mallory box fail, but it was the fault of the auto shop. The Mallory instructions clearly state "Do not jump start the car with the box connected or failure may result." They did and it did.
I went to the shop, pulled the jumper plug out of the glove box, popped it on, and drove home. The next day I ordered another Mallory.
When I bought my '65 coupe in '72, I did a tune-up on it. That included new points, condenser, rotor, cap. I have not touched that distributor but once since. I had to file the points to get it started. They got a little fuzz on them from sitting over the winter in a damp place. I filed them and set the dwell. Points/condenser back then was about $3.50/set.
I'm gonna' see if I can get at least another ten years out of those points.
Toddalin: I respectfully do not share your enthusiam for Mallory products. Any ignition system that fails due to jump start is lacking in quality of design or assembly. JMO.
