Advice on using 383 replacement engine
Old Mar 8, 2009 | 03:54 PM
brookiez28's Avatar
brookiez28
Default Advice on using 383 replacement engine
I'm considering bagging my #'s 327/300 and replacing with a 383 stroker. The 383 has 10.25: compression and a 490 lift cam. Will I be ok using my stock radiator (radiator works fine right now) or am I going to need to change it to avoid heat problems?
Also, the engine builder recommends using a non-vacuum advance distributor for the motor. Says it is easier to tune, runs better etc., but is about $600 for the CDI, coil & distributor. Is this set up really necessary vs. an HEI or other? Is this a serious issue for engine performance? Will an HEI ignition even fit or is it too tight for the firewall?
Thanks very much in advance...
Old Mar 8, 2009 | 04:13 PM
SPLITRAY's Avatar
SPLITRAY
I put a 383 Stroker in my 63'. It does have a HEI Ing. and fits just fine. I do have the vacuum advace as well. Engine runs great but I have not driven the car yet. This year is the year!
Old Mar 8, 2009 | 07:48 PM
JohnZ's Avatar
JohnZ
You can add that guy to the list of "engine-builders" who has no clue whatsoever about what a street-driven engine needs for an ignition system. He needs to read this, but he probably wouldn't understand it:
http://www.lbfun.com/warehouse/tech_...101Article.pdf
Old Mar 8, 2009 | 07:53 PM
62Jeff's Avatar
62Jeff
I think I'd find another engine builder.
Old Mar 8, 2009 | 08:31 PM
Tonytz06's Avatar
Tonytz06
Forget the engine builder, go to your local GM parts department and buy a 383. You can choose one to fit your needs and get up to a three year warranty.
Old Mar 9, 2009 | 08:35 AM
brookiez28's Avatar
brookiez28
Default 383 and potential heat problems?
Several forum members have installed 383's in their cars. Is anyone out there experiencing any overheating problems with their stock small block radiator and clutch fan set up? Just wondering if I need to change any of my current cooling system if I run a 383 engine- thanks
Old Mar 9, 2009 | 09:50 AM
obx2323's Avatar
obx2323
I have a 355 built to supposedly 400Hp with a stock rad and direct drive 7 blade stainless fan. It runs all day at 165 in 65 degreee temp. I guess I better go buy me a vacuum advance as my MSD is mechanical. I hate learning this stuff the expensive way but I should a known.
Never ceases to amaze me the variations of advice you will get when asking 'good mechanics'.
Old Mar 9, 2009 | 10:29 AM
MikeM's Avatar
MikeM
I think it's safe to say the mechanical distributor would be best for mostly competition use and the vacuum advance unit would be best for mostly street driving. Either will work either way but not ideally.
Old Mar 9, 2009 | 10:36 AM
ptwohey's Avatar
ptwohey
I do not have a 383 but did install an original 1970 LT-1 crate engine with my original radiator which is OLD. On any day where temps went over 65 deg I ran really hot but not enough to boil over the fluid. I did that for about 4 years until I finially added a high density 4 core and now the temp runs a lot cooler in any temp.
You might try to keep the original but a new one might be less worry.
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Why do people no longer build their own custom engines?
Building a 383 from a rebuildable 350 block and a good used 400 crank (or just buying a 3.75 stroke crank) is just too easy. Plus, when you're done, you have the satisfaction of doing it yourself as well as KNOWING what's inside.
Engine building IS NOT rocket science!
Old Mar 9, 2009 | 11:24 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I put a 383 stroker in my 61 and it began to run warm. I attribute it more to the state of my old radiator than the engine causing the problem. I put a new aluminum Dewitt's radiator in and it runs 180 all day long. Stock clutch fan as well. I think the additional horsepower may expose any weaknesses your system may have. If everything is in order, you should be fine with a stock setup.
Old Mar 9, 2009 | 01:22 PM
63 340HP's Avatar
63 340HP
runs better?... hmmm NO
The non-vacuum advance distributor is easier to set-up & tune (it ignores tuning the vacuum advance), but it does not run better.
The engine with the non-vacuum distributor will run the same at Wide Open Throttle (WOT). This is because at WOT the vacuum advance is not employed (there is minimal vacuum, and no impact from the vacuum advance). Racers drive everywhere at WOT, but most of the rest of us take our foot out of the throttle now & then.
The engine with the non-vacuum distributor will NOT run the same at partial throttle, at the throttle positions most of us drive every day. It will get lower fuel mileage and have a less powerful response to slight throttle inputs (and can motivate the engine to overheat). This is because at partial throttle, vacuum advance is employed to provide better power and fuel economy. Vacuum advance is a benefit when the engine can use a little timing advance efficiency boost without detonation.
The HEI will fit the engine compartment, but not the original ignition shielding, and it will not fit many of the original air cleaner housings and intake manifolds. A good standard cap distributor will work just as well (with a quality points replacement electronic trigger if you want the same reduced tune-up advantage of the HEI).
Old Mar 9, 2009 | 02:36 PM
Five Window's Avatar
Five Window
I have a 383 dyno'd @ 455HP that runs @ 180 summer and winter. Like Capevettes, I put in a new Dewitt's radiator (the least expensive one!) and I run a 7 blade Flexalite fan. I use a vacuum advance HEI with tach drive from Summit.
Old Mar 9, 2009 | 09:37 PM
Dennis Beck's Avatar
Dennis Beck
I have the GM zz383 stroker in my '66. I am running a Dewitts replacement aluminum radiator with a MSD vacum advance distributor. I have a stock fan clutch and fan. My radiator shroud fits correctly and the fan sits in the shroud correctly. My car runs 180* all the time. Hot day, cool day, highway and local streets. I would urge you not to use the mechanical distributor and go with a vacum advance model. It is absolutely essential for a cool running engine in a C2.
Dennis
Old Mar 9, 2009 | 10:11 PM
SPLITRAY's Avatar
SPLITRAY
Well, When I looked at the builders expense, added the cost for me to procure the same parts, try to find a machinist around here I could trust...the price came out about the same. And I still couldn't find a machine shop! Bottom line - it was less hassle and quicker.
Old Mar 10, 2009 | 04:03 PM
Cpe04's Avatar
Cpe04
Well said ! I guess it's just a different generation. You don't have to know anything but how to write a check today.
Old Mar 10, 2009 | 04:10 PM
jdk971's Avatar
jdk971
i am no mechanic. i would love to build my own engine. but i have no
clue for clearances on bearings, clearances on the heads (which gasket
to use) and such. i would have to have a good mechanic sit and watch
me. if i pay a guy to do that then a crate engine would be cheaper. i am
not afraid to try things, but a engine is too expense for me to possible
screw up. i never had the training for this, which i really wish i had. i
am thinking of going back to school just to learn. but i have to wait till
the stock market rebounds a little. jim
To Advice on using 383 replacement engine
Old Mar 10, 2009 | 04:29 PM
DZAUTO's Avatar
DZAUTO
Is there no longer such a thing as a "buddy" that will come over and help/guide with these kinds of efforts?
If for example, a guy brings me a Muncie for a rebuilt/repair and says he'll pick it up next week, then he gets charged a full bore price for a rebuild plus parts.
But if someone comes over with his Muncie and asks me to help him to rebuild it, there is no charge (of course, he buys parts). Does no one do this any more????
Old Mar 10, 2009 | 04:50 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Tom - there are fewer and fewer guys like you around I'm afraid....
As to 'rolling your own' on a custom engine..I just hear too many stories from novices where the combination of 'hot' parts they bolt together either doesn't live up to their expectations or is a complete disaster. Its also nice to have that crate motor warranty.
Old Mar 10, 2009 | 04:53 PM
jdk971's Avatar
jdk971
dzauto, i wish i had a buddy. i had to retire early and take care of my wife. it is my fault that i shut off my old police friends, but i was busy.
i have not known a mechanic untill now. but steve is slowing down and
just does small jobs at his house. he will build me a engine, but he recommends a crate engine. he has done me good on my nailhead and vette. i just started to get into cars again after my wife died in 2007. it took a while for me to get moving around again. so yes i have friends,
but police officers i know do not build engines. when i decide to replace
the orig in the vette i will go to steve. we will decide on which one to get and i will be helping him pull the old and put in the new. just like when i put a 400 tranny in place of the 300 that was in the nail. boy that was a trip trying to find a nailhead 400 tranny. steve is old school, hell he doesn't even have a dvd player in his house. i know i am one of the few on this board that is not a mechanic or plays one. now if you need plumbing, tiling, or room addition i can jump right in. no electrical i fall on my *** every time, because i am to lazy to turn the breakers off. jim
