C2 Alignment Problems - Upper Control Off-Set Kit
Old Jun 19, 2011 | 07:27 PM
dewhurstaj's Avatar
dewhurstaj
Originally Posted by magicv8
There is a link to rear wheel alignment in the help section at the bottom of my home page (http://home.mchsi.com/~magicv8) that has the info on calculating rear shim thickness changes.
To get increased caster (3.5) in my 66, I replaced the factory bolts with longer (grade8) bolts that allowed a spacer to be placed at the base of the shims. Nothing else had to be removed.
I just printed off the alignment procedure!
I will review it & give it a try!
Thanks!
Andy
Old Jun 21, 2011 | 02:22 PM
magicv8's Avatar
magicv8
Originally Posted by dewhurstaj
Here are the questions:
1. What is the thickness of the Right Rear shim that has to be added or subtracted from the inner or outside trailing arm to meet GM spec?
2. I only want to remove & replace the trail arm bolts to get the rear suspension w/ in spec.
At this time I do not plan to remove the entire trailing arm unless I have to.
Is it safe to remove the training arm bolt w/ 4 jack stands supporting the frame & nothing supporting the trailing arm?
I'm very concerned about the rear spring pressure & getting a new bolt back in place w/ the rest of the trailing arm still attached.
Thanks!
Andy
Just so everyone keeps up with our PMs:
IMO remove 0.155 from shims on the RH side of the RH control arm and insert them on the LH side of the RH control arm.
A jack under the control arm has always allowed me to swap shims.
