C2 vent window regulator
Old May 19, 2010 | 04:07 PM
frankgv's Avatar
frankgv
Default C2 vent window regulator
Thanks guys,
I think what I need is the gear for the vent window regulator, it is stripped no doubt, my question is if I can remove the regulator from the frame and repair it without having to remove the entire assembly.
Thanks, Frank.
Old May 19, 2010 | 05:57 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Vent regulator
Yes. If I remember correctly, there are three phillips screws that hold the regulator in place. It should be evident when you remove the door panel and water barrier. Jerry
