Solid state voltage regulator
Old Jul 13, 2010 | 10:54 AM
Kensmith's Avatar
Kensmith
Default Solid state voltage regulator
Ok, I am upgrading my alternator and need recommendations to upgrade the voltage regulator. I have been told the solid state is a direct replacement. 65 coupe small block VR mounted on passenger side of radiator support. Anyone have parts numbers etc? Can I get one at NAPA or other local parts store? Thanks
Old Jul 13, 2010 | 11:44 AM
dkleather's Avatar
dkleather
2016 C2 of the Year Finalist
The Duralast VR715 is a direct replacement and you can get it at AutoZone for less than $20. The cover of the your original will change over and fit if you're into that correct stuff. Dave
Old Jul 13, 2010 | 12:05 PM
Kensmith's Avatar
Kensmith
Thanks Dave!
Old Jul 13, 2010 | 12:22 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Exactly right! Dennis
Old Jul 14, 2010 | 12:09 PM
Steve59's Avatar
Steve59
Will the 715 work on a 59?
Old Jul 14, 2010 | 12:25 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
It might, but only if your '59 has an alternator.
Jim
Old Jul 15, 2010 | 03:34 PM
Steve59's Avatar
Steve59
Thanks, but it's still a generator.
Old Jul 15, 2010 | 06:48 PM
OCS1667's Avatar
OCS1667
Ken, I'm not a expert on electric applications but I did install a new 140 amp alternator. It is my understanding that the voltage regulator is not needed as it is built into the alternator. Another part you don't need that I remembered was a pain in the day. Buy the way I can run all my electrical exciseries , radio, lights, air conditioning, and guess what I can still read the gauges and the head lights through out plenty of light.
Dennis
Old Jul 16, 2010 | 10:14 AM
Kensmith's Avatar
Kensmith
Originally Posted by OCS1667
Ken, I'm not a expert on electric applications but I did install a new 140 amp alternator. It is my understanding that the voltage regulator is not needed as it is built into the alternator. Another part you don't need that I remembered was a pain in the day. Buy the way I can run all my electrical exercises, radio, lights, air conditioning, and guess what I can still read the gauges and the head lights through out plenty of light.
Dennis
Hi Dennis,
Some of the alternators have a built in regulator and some don't. I am staying with the old style 10dn alternator which does need a voltage regulator.
Old Jul 16, 2010 | 05:02 PM
OCS1667's Avatar
OCS1667
I followed your rebuild from almost the start, 383, seats, trans, and so on.
Old school alternator, why?, I was always thought you were a up date kind of a guy.
Dennis
Old Jul 16, 2010 | 05:16 PM
Kensmith's Avatar
Kensmith
Dennis
I have owned 1 wire alternators and didn't care for them. There was always a problem at idle. They just seem to drop off unlike the older 10dn 3 wire. Otherwise I would have trashed the 3 wire for a 1 wire. I also don't care for the new chrome one as I like the natural finish.
Old Jul 16, 2010 | 06:11 PM
OCS1667's Avatar
OCS1667
I understand your thinking, can't say I have noticed the drop off. But with re. the finish I have all natural upgrade finishes including the alternator.
Old Jul 16, 2010 | 06:19 PM
Kensmith's Avatar
Kensmith
And that look is nice!
Old Jul 16, 2010 | 06:27 PM
GCD1962's Avatar
GCD1962
On most one-wire units that are sold you can pull out the plastic plug and use it as a 3-wire set-up with no other parts needed.
To Solid state voltage regulator
