C2 Alignment spec analysis needed
Old Aug 23, 2010 | 10:41 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Default C2 Alignment spec analysis needed
Just had the '63 aligned at Southwest Alignment on Richmond in Houston. The owner did the work. He was very careful and allowed me to work in unison with him. It was Friday,hot as hell. He did it on a drop in. I don't mind going back for a re-tune on an off day.
Those in the know? Please analyze my specs? My rear tire fender clearance has been reduced since re-doing my trailing arms. Any suggestions for adjustments to increase clearance?
Left front Right Front
Camber: .03 Deg .25 Deg
Caster: 1.06 1.45
Toe: .08 .21
Left Rear: Right rear
Camber: .14 .19
Toe: .10 .09
Thanks in advance.
Old Aug 23, 2010 | 11:10 PM
JLMICCA's Avatar
JLMICCA
Setting negative camber on the rear will help with you rear fender clearance (also help with handling). VB & P has a very interesting table on alignment specs. http://www.vbandp.com/Tech-Info/ There is a pdf file you can download with the info here.
Old Aug 23, 2010 | 11:14 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
On my last alignment the finished specs were:
Front Left/Right
Camber -0.4/-0.4
Caster 4.1/3.9
Toe 1/16 / 1/16
Rear Left/Right
Camber -0.6/-0.4
Toe 1/16 / 1/16
Car steers effortlessly (jeep P/S box upgrade) and tracks straight down the road. Tires are 205/75R15 on six inch rims.
Rich
Old Aug 24, 2010 | 12:30 AM
wombvette's Avatar
wombvette
Caster: 1.06 1.45
Toe: .08 .21
Camber: .14 .19
Toe: .10 .09
Thanks in advance.
With 1.06 caster on the left and 1.45 on the right. it will probably pull left a little.
Old Aug 24, 2010 | 09:39 AM
John BX NY's Avatar
John BX NY
I agree with Wayne..the specs do not mention the cross camber or caster tolerances which is generally the left reading minus the right.
Anything more than 0.5 degrees could induce a pull or lead....
john
Old Aug 24, 2010 | 11:26 AM
66since71's Avatar
66since71
right to left differences might be a road camber (drainage) compensation. The rear camber ought to be around -1 degree. As others have suggested it will increase clearance and keep the rear end planted in corners. I'll also agree that VBP has some good recommendations on alignment.
Harry
Old Aug 24, 2010 | 12:00 PM
MiguelsC2's Avatar
MiguelsC2
john
Cross camber is .22
Cross caster is .39
Total toe is .29
Set back is .13
Old Aug 30, 2010 | 02:05 AM
MiguelsC2's Avatar
MiguelsC2
Anymore opinions before I head back to the alignment shop?
Do the fronts need negative camber?
Old Aug 30, 2010 | 11:13 AM
JohnZ's Avatar
JohnZ
For normal "street" operation, front camber should be zero, and rear camber should be zero-to-1/2* negative.
Old Aug 30, 2010 | 02:28 PM
midstyle's Avatar
midstyle
John -- any different for repro bias ply (say, 4-Ply 7.75 x15) and radial (say, 205/75 R15) ?
Old Aug 30, 2010 | 02:59 PM
MiguelsC2's Avatar
MiguelsC2
I need a little extra tire clearance on the rear. Would 1 degree negative camber on the rear be ok for aggressive street driving?
Old Aug 30, 2010 | 05:21 PM
66since71's Avatar
66since71
Absolutely OK. The factory spec is -0.5* +/- 0.5*, so at -1* you're within limits.
Harry
Old Aug 30, 2010 | 08:29 PM
street62's Avatar
street62
Front Left/Right
Camber -0.4/-0.4
Caster 4.1/3.9
Toe 1/16 / 1/16
Rear Left/Right
Camber -0.6/-0.4
Toe 1/16 / 1/16
Rich
how did you get that much caster in the front.
Old Aug 31, 2010 | 01:21 PM
JohnZ's Avatar
JohnZ
The only setting difference between bias-ply and radials is front toe-in. Use the factory specs for bias-ply tires (1/16" to 1/8" per side), and for radials use zero-to-1/16" TOTAL toe-in.
Old Aug 31, 2010 | 02:35 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
THAT'S what everybody forgets, and that's why you see so many posts about "lousy" bias ply tires that wander all over the road, etc.
The specs changed, and JohnZ has posted the correct ones.
IF you put bias ply tires on a car aligned to radial tire specs, it'll be a nightmare to handle.
Look at the significant difference in the toe in, 1/16 to 1/8 PER SIDE for bias and 0 to 1/16 TOTAL for radials.
Chuck
Old Aug 31, 2010 | 06:52 PM
BADBIRDCAGE
VBP Offset upper control arms. Relocated ball joints.
Silverslashstreak has posted how to have your upper control arms machined to make it possible without going to aftermarket parts.
Rich
To C2 Alignment spec analysis needed
