Powerglide problem
Old Sep 20, 2010 | 10:55 PM
JMC706's Avatar
JMC706
1st Gear
Default Powerglide problem
In my 1965 Vette..I just can't seem to get my 2 speed powerglide trans out of neutral. Try as I may..any suggestions??? Thanks..Jim
Old Sep 20, 2010 | 11:04 PM
Ron Miller's Avatar
Ron Miller
A little more info . . . .
You can't move the gearshift selector lever?
Or, when you move it, it doesn't go into any gear?
Old Sep 20, 2010 | 11:12 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Check make sure the fluid is red, doesn't smell burnt, and at the right level. And check your linkage, you may have a disconnected or loose rod. My truck just did the same thing.....a cotter pin rusted through and the rod slid out of the lever. Shifter moved but nothing happened.
Old Sep 21, 2010 | 12:03 AM
sub006's Avatar
sub006
Yeah, sounds like a linkage-related problem if it happened all of a sudden, with no warning changes in transmission performance, noises, etc.
Old Sep 21, 2010 | 07:59 AM
Ron Miller's Avatar
Ron Miller
My thoughts . . . .
Old Sep 21, 2010 | 01:45 PM
DZVette's Avatar
DZVette
Check underneath to see if one of the linkage retainer spring clips has come loose somehow (pic attached).
Dave Z
Old Sep 21, 2010 | 02:52 PM
emccomas's Avatar
emccomas
Dave Z
I like the 45 D Lincoln.
Old Sep 22, 2010 | 08:53 PM
DZVette's Avatar
DZVette
Wish I had a 1909 S VDB!
Old Sep 22, 2010 | 10:15 PM
Randy G.'s Avatar
Randy G.
Print this and you'll be close!
To Powerglide problem
