The Exploding Starter
Old Feb 19, 2011 | 06:37 PM
mscaggs's Avatar
mscaggs
Default The Exploding Starter
OK, Many of you have been following my thread about my transmission nightmare. So today I pulled the trans again for the 4th time! Did in 45 minutes too. That's what happened when you do things over and over, you get fast. Anyway, once the trans was out and all was clear I started the motor and all Hell broke loose. My starter exploded! If it had to happen I'm glad it happened with the tranny out. I pulled the bell housing and cleaned out all the metal. Thank goodness the block was not damaged. This has been a crazy winter.
Take a look at this
Old Feb 19, 2011 | 06:42 PM
KC John's Avatar
KC John
C2 of Year Finalist (appearance mods) 2019
If it wasn't for bad luck, you wouldn't have any luck at all. I hope this is the last time you have something happen to prevent you from enjoying your ride.
Old Feb 19, 2011 | 06:43 PM
Blk63Vette's Avatar
Blk63Vette
Holy Crap I never seen one explode..I put a cast iron starter head on my starter ...Old hot rodder told me more durable?..Anyway...that sucks good thing you werent under it when it happened...Something binding maybe?
Good luck
mscaggs's Avatar
mscaggs
Well, I have a confession. I did take her for a quick spin this morning before yanking the trans. I just had to. Man it's running so good too. Dang ole trans is breaking my B@lls I swear. Now the starter. I'm am very lucky the block did not break. The good lord was watching over me..
Old Feb 19, 2011 | 06:45 PM
mscaggs's Avatar
mscaggs
Good luck
Nothing was bound up it just let loose. What are the odds that would happen while the tranny was out! Good thing too cause I pulled the bell to check for metal.
Old Feb 19, 2011 | 07:01 PM
Jeff Garner's Avatar
Jeff Garner
Mike, WTH??!! Get that thing on all fours's and let's go. It's getting close to driving weather. Hopefully you're finding all your weak areas now before the season. Hang in there.
Old Feb 19, 2011 | 07:03 PM
mscaggs's Avatar
mscaggs
I know, this stuff is killing me Jeff... I'm almost there bro
Old Feb 19, 2011 | 07:04 PM
mscaggs's Avatar
mscaggs
Now the question is which starter to buy. I will go with a cast nose next time. Any suggestions on brand or stuff to avoid?
Old Feb 19, 2011 | 07:06 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Wow! What would cause that? I would carefully check the ring gear on the flywheel
I wonder if was somehow related to your tranny noise?
Old Feb 19, 2011 | 07:09 PM
mscaggs's Avatar
mscaggs
Nahhh, the ring gear is fine and everything else checked out fine. Just my luck this week thats all. You should have heard the sounds it made, make your skin crawl :o)
Old Feb 19, 2011 | 07:31 PM
Godholio's Avatar
Godholio
That picture makes my skin crawl.
Old Feb 19, 2011 | 07:35 PM
mscaggs's Avatar
mscaggs
The picture is nothing, you should have heard it go off!
Old Feb 19, 2011 | 07:38 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Never seen that before. Do I understand right that you started it with the trans out? If yes, then maybe that had something to do with it, nothing to keep the clutch disc in the middle, maybe through off the balance? Just an idea......
Old Feb 19, 2011 | 07:41 PM
mscaggs's Avatar
mscaggs
Well, as long as you don't push the clutch in the disk will stay put. To be safe though I put an alignment tool in the hole. That wasn't the issue, starter just bought the farm that's all.
Old Feb 19, 2011 | 07:54 PM
65specialk's Avatar
65specialk
Does anybody shim there starter like we're supposed to??? Wonder if it was to close to the ring gear??? Dave
Old Feb 19, 2011 | 07:55 PM
mscaggs's Avatar
mscaggs
Well, I will surely check that with the new starter. Thing is, that is the same starter that has been working fine for a long time, same flywheel too. I do have a new clutch...
Old Feb 19, 2011 | 07:56 PM
jdk971's Avatar
jdk971
you are having as much bad luck as i usually do. you will be happy once you get her
back together and are on the streets this spring. best of luck jim
To The Exploding Starter
Old Feb 19, 2011 | 07:57 PM
mscaggs's Avatar
mscaggs
It's all good Jim, I'm just getter to know her better that's all. Just glad the block is okay
Old Feb 19, 2011 | 08:23 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Exploding starter
The starter nose exploding is fairly common if there is no brace at the opposite end of the starter. Was the brace there and secure on the starter stud and bolted securely to the block ??? You cannot replace the aluminum nose with a cast iron one--The aluminum nose can only be used with the 153 tooth (small) flywheel and the C.I. nose only works with the 168 tooth (large) flywheel. The bell housings are different too, depending on which flywheel you are running. Why did you have to pull the trans again---I thought the problem was fixed.
RON
Old Feb 19, 2011 | 08:25 PM
MikeM's Avatar
MikeM
I think you like sympathy. What are you going to do if something major happens?
