1961 Wiper Coordinator question
Old 03-08-2011, 03:56 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,089 Likes on 4,740 Posts
Army
Default 1961 Wiper Coordinator question
I'm installing my wiper coordinator just restored by Tom Maxwell.
Can anybody tell me (who has a properly operating coordinator) if the little 1/2 circle clamp that holds the metal shaft of the coordinator 'locks' it in place. When tightened completely down the shaft of the coordinator is still loose. I don't remember it being that way from before the restoration.
Old 03-08-2011, 04:05 PM
mike coletta
mike coletta's Avatar
Received 1,073 Likes on 517 Posts
Frank,
It is supposed to stay loose. When the vacuum is applied to the coordinator via the washer button, it will push the wipers to on for about 4 strokes. It needs to be able to slide in order to turn the wipers on from the switch. As I told you in your ad to buy one, the only thing that the coordinator does is turn the wiper motor on while vacuum is applied to the washer head. You can operate the wiper motor normally with a non functioning coordinator.
Mike
Old 03-08-2011, 04:42 PM
Frankie the Fink
Army
Duh! Yeah I should have studied it some more before posting....
I DO know the wipers work with a dead coordinator - that's the way I was running them
for the last couple of months... HOPEFULLY, the whole system (washers & wipers) work now as EVERYthing has been rebuilt by either me or Tom...
Old 03-08-2011, 05:33 PM
Frankie the Fink
Army
Everything is installed and wipers/washers now work just like they did in 1961...which means pretty **** poor...
Old 03-08-2011, 06:29 PM
Jackfit
Support Corvetteforum!
Jackfit's Avatar
Default I never noticed
When I was 22 and bought my first corvette, 1961, in 1969 , I thought they worked great. But then again, I thought the car had a great ride.
It must have been our younger bodies and butts.
Fortunately or unfortunately, it caught fire in 1969 and I never got to replacing many parts. Lucky me.
Jack
Old 03-08-2011, 08:59 PM
Pilot Dan
Pilot Dan's Avatar
It's great to know the washers work, my problem is I hate to use them because all the *&^% that comes off ends up on my nicely waxed paint. Can't win for loosin.......
Old 03-08-2011, 09:04 PM
Frankie the Fink
Army
Of course, you know to use RainX - the funky C1 washers and wipers are only worth operating for entertainment value and bragging rights...
Old 03-08-2011, 10:10 PM
narlee
narlee's Avatar
My wife and I always crack up laughing whenever we have to use the wipers.
Old 03-09-2011, 04:09 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
the last straw for me was when the wipers started wiping the hood instead of the windshield...
Bill
Old 03-09-2011, 08:24 AM
Frankie the Fink
Army
Actually - once you've screwed around with these systems...most problems are pretty easily fixed NOT including wiper transmission or windshield washer pump rebuilds.
Those are an exercise in patience and medieval masochism...
Old 03-09-2011, 08:32 AM
Steve59
Steve59's Avatar
Frank:
Been toying with the idea of having my entire system done by Tom Maxwell. All of the parts are old and dead except I do have a new tank. What parts did he rebuild? Did you have the switch rebuilt? How long did it take and what's the cost?
Steve
Old 03-09-2011, 08:39 AM
Frankie the Fink
Army
Originally Posted by Steve59
Frank:
Steve
Tom does most anything with these systems.
To repair the coordinator was about $70...he rebuilt my washer pump but I'd have to find the receipt. I would assume he rebuilds the washer motors and transmissions but can't swear to it. I did my own transmission using restored units from a swap meet. My wiper motor was restored by this guy: http://cgi.ebay.com/ebaymotors/58-62-CORVETTE-WIPER-MOTOR-RESTORATION-RESTORE-SERVICE-_W0QQcmdZViewItemQQhashZitem2eb1b746dfQQ itemZ200550074079QQptZVintageQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
which included restoring the external finish for $199.
All told the price was probably comparable to the price of an aftermarket wiper arrangement...and most of those don't include a washer system.
I never had the switch rebuilt and I run with a repro vacuum can that came with the vacuum valve already installed on top.
Frankly Steve - if the other parts of my car weren't so original and correct I'd have bolted in a RainGear or some other system and be done with it.
Old 03-09-2011, 09:02 AM
Steve59
Steve59's Avatar
Frank:
I'm not particularly married to the idea of having this system in "working" order since, from what I've read, at it's best, it's still bad. What I would really like to do is to keep everything "stock" looking, yet have some kind of electrically operated pump in the reservoir that is operated by the push button in the switch. Do you know of anyone that makes that kind of retrofit?
Old 03-09-2011, 09:16 AM
Frankie the Fink
Army
I did look at some electrically operated, submersible washer pumps a year or so ago. My thought was to stick it in the water tank and run the wiring, invisibly, through a vacuum hose to the dash switch which I would convert to an electrical switch. Nobody I could find made such an arrangement so I would be on my own cobbling something together. In the end I gave it up as it seemed to be as much trouble as fixing the original stuff.
I'll bet if somebody did come up with a 'plug and play', invisible, conversion there would sure be a market for it!
Old 03-09-2011, 09:25 AM
Steve59
Steve59's Avatar
Thanks Frank appreciate the info. Will probably go the rebuild route.
Old 03-09-2011, 10:16 AM
INMYBLOOD
INMYBLOOD's Avatar
Location: The problem is all inside your head she said to me.
I just put in the SPW wiper kit and the switch is capable of working washers, which my car did not have anyway. I don't see why you could not use it just like you said. Not sure if when depressed it runs the wipers, or weather you'd have to turn them on and push the washer when you wanted. I have not run the car and still have a lot of the dash apart still. My plan is to clean up the original wiper motor and re-install it. I could even install the cable but would have the switch just tucked up under the dash. No one would know the difference, that is until I actually use them....
Old 03-09-2011, 12:08 PM
abe g
abe g's Avatar
Default auxilary windsheild wiper washer motor.
All parts retailers carry a add on electric washer pump that install as add on existing wirepng. You use the switch button as previous for "squirt" operation. JC Whitney and others, been around for last 25 years, (*** now chinese) sold for about $10 dollars. hope this helps someone. Regards, Abe G
To 1961 Wiper Coordinator question
Old 03-09-2011, 12:30 PM
vette61
vette61's Avatar
It could be worse, remember the old VACUUM operated wipers on some of the pre 55 Chevy's? Step on the gas and they stop in mid stride. Makes us appreciate the electric ones.
Old 03-09-2011, 01:54 PM
Frankie the Fink
Army
YES! Vacuum operated wipers on my '55 Buick and they 'stalled' when you hit the gas...JUST when you need them most! Also had a gas pedal operated starter which would sometimes mysteriously start the car by itself...I thought it was haunted!
Old 03-09-2011, 07:35 PM
vettefred
vettefred's Avatar
C-1 wipers are only there to pass state inspection. They were never designed to really clear the windshield.
Quick Reply: 1961 Wiper Coordinator question
