Has anyone ever pulled a small block from a C2 without removing the radiator and fan shroud. It looks to me like it can be done. If I leave the transmission and the bell housing in the car. Of course I would remove the fan, pulleys, fuel pump. dizzy, and alternator. The last time I pulled the engine, it was with the transmission.
This is an L79 without: air, power steering, or power brakes.
Dude, don't do it. Pulling a motor is a big job, don't minimize the nature of the job by saving 20 minutes from pulling a radiator and shroud. Shroud and raidator out, hood off, and you're smooth sailing. Do the job once, do it right, and don't need to do it again. Remember, beers are for AFTER the motor is on the cradle. LOL...Good luck. I did it with my BB 69 Camaro.. Was fun, and the beers somehow taste colder when you can lean on the engine you just pulled out while drinking them. ARA
Considering the time wasted by having to put accessories back on the engine after it's decked, just so you can leave the radiator in place, I don't think it's wise to leave the shroud and radiator in place.
I wouldn't think about leaving the radiator and shroud in place if I was replacing a midyear engine.
I have pulled the engine (leaving the bell housing and transmission in the car) without removing the radiator. I didn't know it was a big deal and just did it. My car has an electric fan, so that might also make a different in ease of extraction.
All that said, it only takes a few minutes to pull the radiator and it gives you a few more inches and saves you from an expensive "oops!"
Well, if you're gonna try it, I'd strongly recommend pulling the distributor so it doesn't hit the firewall when you tip the engine front end upwards to gain enough clearance.
Sure it can be done...BUT, not worth the hassle. Or it just depends on what you are in the mood to try work around.
Easier (and cheaper) to take the shroud and rad out...the radiator is only held in by the upper bracket once the hoses are off...two bolts and it can be lifted out.
I got rid of my shroud all together...added a dewitts rad w/ elec fan
Don't ask me how I know.............
If you take the motor mounts off, you don't have to tip the engine. Just slide the engine straight forward. Easy peasy.
Sure, now you tell me! Where were you 44 years ago in 1971 when I made that mistake..... I did get it right the second time 15 years ago in 2000!
PS - I don't think he can slide the engine forward if the radiator and shroud are still in - which is what resulted in my tipping the engine that first time............
Reason: typo
Hi, here are a few pictures of my install, I did it by myself. I also used guide pins in the bottom two holes of engine to help line up bell housing. Taking out radiator / water pump gives much more room. It was not hard to install. Had to do it two times because of other problems...
That is just another reason to pull the radiator and shroud.
Does anyone have any thoughts on this wear? I am thinking that it was a bad case of miss alighment of the roller tip . I am going to get a set of adjustable guides when it all goes back together.
In over 35 years working on cars professionally, I've learned that 'shortcuts' often become 'loncuts' due to unanticipated collateral damage and hardship. I've found that removing any and all items even remotely in the way assures a clean, neat, timely job with no damage repair needed at its completion. It took me about 30 years to learn this, but man, it's a huge life lesson! Turn on the radio, have a sip of soda or coffee, and take your time. That way, its fun and stays fun.
You said it. . .. By the time one gets it all figured out it'll be time to retire and it won't matter anyway! (Well, kinda) .. . . It's all about having fun now. . .
You are pulling the motor to change a cam and valve?
1), if you are going to pull the motor, take the radiator out, sometimes it takes a little pulling to separate the motor from trans, or bell, and then the engine swings forward and takes out your radiator.
2) why not do the cam swap in the car,I haveve done that several of times, in an evening, it doesn't take hardly any longer to pull a head, or heads, vs fussing around under the car disconnecting and reconnecting the motor to the rest of the drivetrain.
The harmonic damper is more of a pain to R&R in the car, but less work than removing the motor.
Thanks everyone! The cam swap will be done with the engine in the car. I still have to get that ordered. It is true. There really isn't a reason for me to be in a hurry.
