AL vs Cast intake
Old Jun 27, 2015 | 11:12 AM
Spike66's Avatar
Spike66
Originally Posted by Frankie the Fink
You will HAVE to pull the distributor to swap intakes....there are two reference points to mark and then its a breeze. Mark the distributor position (normally you would mark it at the intake but the intake will be swapped); a piece of that blue tape on a valve cover in line with the vac advance hose tube fitting aligned via straightedge will do it. Then, in a similar fashion, mark where the rotor is pointing. Do NOT bump the engine over during the swap. All you have to do then is reinsert the distributor according to your marks. JohnZ has written an excellent article on the procedure....if you don't have it, or others, will post it...
Thanks Frankie. I'll ask John. I'm a carpenter so I was noodling on some sort of remote reference with a straight edge or square. Ain't nuthing square in an engine compartment so the straight edge is perfect.
Old Jun 27, 2015 | 11:15 AM
65 vette dude's Avatar
65 vette dude
When you install the aluminum intake, you might want to consider blocking off the exhaust crossover on the intake with F.I. intake gasket's. If you do, you will need to stop by any muffler shop, and have them install an H pipe somewhere behind the tranny. Good mod with today's gas, and you will pick up a little extra lower end torque with the H pipe.
Old Jun 27, 2015 | 11:23 AM
tuxnharley's Avatar
tuxnharley
Good advice. One step further is to first pull the distributor cap and then crank the engine until the rotor and the advance tube hose fitting line up. Only one position/mark to keep track of that way!
Remember that when you pull the dizzy the rotor will "rotate" slightly from that mark due to the spiral cut gears. When you reinstall it you need to start from the same offset it had from your mark so that it will wind up in the correct position as it again rotates on its way back down/in. If you try to start the re installation process with the rotor lined up with the mark you will wind up a tooth off on the final position.
Old Jun 27, 2015 | 11:24 AM
Spike66's Avatar
Spike66
It's a side pipe car.
Old Jun 27, 2015 | 11:55 AM
MikeM's Avatar
MikeM
Originally Posted by Spike66
Isn't there a bypass fitting on top of the L79 water pump? I'm unfamiliar with the L79 plumbing. If there's a bypass on both pumps and intakes, why wouldn't reconnecting fitting to fitting work?
You said you had a 300 hp engine didn't you?
When you put your distributor shield back on, make sure the 12V feed to the coil isn't binding/abraiding against the shield or you could burn you car to the ground.
Old Jun 27, 2015 | 12:43 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
If the dizzy gives you trouble I'll take you thru the Lars "rotor walking" method. I can have a dizzy installed in 2 minutes with his method..
Old Jun 27, 2015 | 01:25 PM
MikeM's Avatar
MikeM
Why is that called the "Lar's method"?
It's only useful if you don't get it right the first time which takes ten seconds.
Old Jun 27, 2015 | 02:14 PM
Spike66's Avatar
Spike66
Always good to remember. Thanks Mike.
Old Jun 27, 2015 | 02:22 PM
Spike66's Avatar
Spike66
Seems like I remember this from years back. You can hear/feel it turn and right out of the box, it's off a little.
Old Jun 27, 2015 | 04:02 PM
GTOguy's Avatar
GTOguy
What tuxnharley said. Note where the rotor is pointing, and note where it rotates to when you pull the dist. It usually will rotate about 20-30 degrees. When you go to install, have the rotor at the same position it shifted to when you pulled it. When the dizzy is seated, the rotor will turn and be exactly where it was before the r&r. Works every time.
Old Jun 27, 2015 | 05:03 PM
MikeM's Avatar
MikeM
Originally Posted by GTOguy
Works every time.
Old Jun 27, 2015 | 05:46 PM
kingwoodvette's Avatar
kingwoodvette
L 79 uses a Holley carb. Is that what you have on your 300 hp?
Old Jun 27, 2015 | 06:44 PM
  #33
SI67's Avatar
SI67
Default Just an idea....
Quick question: Can I take the cast iron intake off my recently rebuilt 327/300 hp and drop an AL intake on without having to retune? I put breakerless ignition and the rebuild was dyno'd. I'd do it for cosmetic purposes only as I didn't go with any L79 mods.
Have you considered cleaning your 300 HP manifold and then painting it with a high-temperature aluminum paint? Then you wouldn't need to change choke rod (assuming you're using a divorced-choke Holley), thermostat housing, pump-to-carb fuel line, upper radiator hose, vac advance tube..... (Did I leave anything out?)
Also wouldn't have to think about the water pump bypass. Just throwing the suggestion out there for consideration.
Is it safe to assume you're already sporting the finned aluminum valve covers?
Steve
Old Jun 27, 2015 | 07:10 PM
  #34
Spike66's Avatar
Spike66
3367 Holley
Old Jun 27, 2015 | 07:12 PM
  #35
Spike66's Avatar
Spike66
Steve
That's kinda clever...hadn't thought of that. And yes, AL valve covers.
Old Jun 27, 2015 | 10:41 PM
  #36
Spike66's Avatar
Spike66
So let me get this right... the rotor will reverse itself back to where it was before it got pulled providing it's indexed where it was after it got pulled?
That seems easy enough. I'm assuming the dizzy body has to be replaced in exactly the same position as it was prior to removal.
Old Jun 28, 2015 | 07:00 AM
  #37
Frankie the Fink
Army
Look at the bottom of a distributor - the gear is helical... On a GM IIRC there are 13 teeth. So 360*/13 teeth is 27.6* or thereabouts. As mentioned, that's the displacement factor when you pull/replace the distributor. The Lars method doesn't require this "Kentucky windage". You seat the distributor in its approx correct location with the main point being getting the oil pump drive to engage (the distributor should sit ALL the way down). Then, by lifting the distributor ever so slightly you can 'walk' the rotor gear-by-gear to the correct position in steps and then do the final alignment of the body. This disengages the helical gear just barely but keeps the oil pump drive in place
Quite easy. No looking down the dizzy hole with a flashlight and screwdriver trying to align the pump gear. Or completely repulling the dizzy multiple times to get the right guesstimate for the correct rotor position.
I just did this the two days ago when I put points in my '63 (yes I said points)....
To AL vs Cast intake
Old Jun 28, 2015 | 07:09 AM
  #38
MikeM's Avatar
MikeM
When you pull the dist. out, the rotor will turn in reverse rotation to normal rotation due to the cut of the drive gears on the rotor shaft. As you pull the distributor out, it also disengages with the oil pump shaft which has a tongue/groove mating connection.
In my considerable experience over the years, maybe one out of dozen times when you put the distributor back in will the distributor line up with the distributor shaft and the distributor won't go all the way down against the manifold.
No problem, just bump the starter a couple of clicks and the distributor/oil pump shaft will align and the distributor will drop on down and seat.
If you're in the right notch, typically the vacuum advance nipple will be pointing at the RR inside valve cover bolt with the rotor pointing to #1 cap terminal.
I never look down in the hole to see where the gear is, don't fiddle faddle with a long screwdriver, just drop it and bump the starter and good to go.
Different people have their own personal way they like to do this. There's more than one way and some of them are even wrong but the engine will still run okay.
Old Jun 28, 2015 | 07:15 AM
  #39
Frankie the Fink
Army
Bumping the starter works...I did that a lot, but the downside being you better have the dizzy/rotor alignment spot on...cuz once you rotate the engine; its a whole new ballgame.
Then you get to do the "where the hell is TDC drill"...
Old Jun 28, 2015 | 07:40 AM
  #40
Spike66's Avatar
Spike66
When the engine was on the dyno, I saw this maneuver so I know exactly what you're talking about now. I wondered what the logic was behind it but it makes sense since you explained it.
If I'm really careful, do I need to leave the distributor off during installation of the engine/trans? Or is it simply asking for trouble not to?
