60 Engine Stamp Pad Question
Sorry, If this has been answered before. I've read other similar threads but never got anything definitive on this...
My C1 was built March 31, 1960. I'm trying to determine if it has the original engine. I noticed there is no serial number on the stamp pad. Only the F number with the date and engine type.
I found this blurb from a numbers book in another thread.
1957 & Later: Beginning with 1957, continuous engine serial numbering was discounted. Engines were prefixed with a source designation ("F" for 1955-66 Flint small blocks; "V" for 1967 and later Flint small blocks; and "T" for 1965 and later Tonawanda, New York, big blocks); followed by three of four digits representing the date of manufacture [first one or two digits representing the month("1" through "12" used 1957-59; "01" through "12" used beginning sometime in 1960; the last two digits representing the date of the month ("01 through "31"")]; ending with the engine type suffix code as indicated in the Engine Identification Codes section of this Spec Guide. Also, beginning sometime during 1960, a VIN derivative stamping was added to the engine pad, mating the engine to the vehicle in which it was installed.
A strict reading of this last sentence seems to indicate that some early '60s vettes may not have the serial number on the engine pad..
I've read a couple other places that the serial numbers being to be added mid to late 1960.
Given there is no serial number on the stamp pad is there any way to tell if this engine is original or not?
Engine
The first thing you need to tell us is what the casting number of the block is. Then tell us the casting date. Both can be found on the bellhousing flange at the rear of the block.
Boyan
Boyan
Nope, a March car would have been way too late not to have a VIN derivative stamped on the pad. I believe by March, they had made the switch to gang holders for the stamping. Early cars had a VIN derivative that was stamped one character at a time by hand. They looked like they were stamped by a drunk! I have had a couple of December and January 60's and the VIN stamp on the pad was really ugly.
Regards, John McGraw
A 1960 Corvette would have used a block casting # of 3756519 for all engine/HP configurations.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
The engine in my '60 is consistent with this. Assembled on April 14, the VIN derivative is gang stamped.
Hmmm... My stamp better resembles the drunken sailor method. The engine stamp is far to the right (too far to squeeze a serial number in.) The numbers and letters are definitely not straight so I'm thinking not gang stamped.
This guy seems to have the same issue: https://www.corvetteforum.com/forums...-question.html
I found this on another thread:
"The engine assembly stamp should read F4XXCQ, where the "XX" are two numbers for the day of the month; that assumes the engine was built in April (the "4"). That stamp will be on the inboard end of the pad, and any 1's in the engine plant stamp will probably be an "I" character. The last six digits of the VIN will be stamped (in a different font) on the outboard end of the pad, and any 1's will be a number "1", not an "I" character. The block casting date is typically 1-6 weeks prior to the stamped engine assembly date, but full judging credit is given as long as it's no more than six months prior to the car's final assembly date."
https://www.corvetteforum.com/forums...s-stamped.html
My Engine stamp is F1105CR. Is it possible the engine was manufactured in Nov of '59 and went out in the car in March of 60?
Hmmm... My stamp better resembles the drunken sailor method. The casting stamp is far to the right (too far to squeeze a serial number in.) The numbers and letters are definitely not straight so I'm thinking not gang stamped.
There's no such thing as a "casting stamp". The casting number is the date the block was cast at the foundry, and it is raised cast numbers at the back top of the block behind the intake manifold and in front of the bell housing.
That's the date when the engine was assembled, and yes, that's a viable timeline albeit a bit outside the norm.
Sorry, I'm new to this and my terminology is horrible.
I found the casting number but I'm having trouble seeing it. I need to get a better light on it. This number is just a date?
So, given the information I have is there anyway to confirm or reject that presumption this is the original engine?
If there's no VIN derivative on the stamp pad, then it's highly unlikely that it's the original engine. As others have said, by March Chevrolet was stamping the VIN on the block of all Corvette engines.
The casting number is on the driver's side. It's not a date, but a part number assigned to the block by GM. The casting date, is in about the same location, but on the passenger side of the block.
Good to know. I will assume it's not the original engine then. Thanks!
A January car would have been hand stamped, and a November car would not have been stamped at all. Prevailing wisdom says that when the VIN tag moved from the door pillar to the steering column as required by federal law, the VIN derivative appeared on the stamp pad at the same time. If you have a car with a VIN tag on the steering column, you should have a VIN derivative stamped on the pad.
The early 60 cars were hand stamped only until they could get the gang stamp made and delivered to Saint Louis. In the meantime the stamping was done one character at a time by hand, but the engine stamp was already in place when the engine left the engine plant.
Jim
Can you use a rag and some solvent (lacquer thinner) to clean the pad? Use no abrasives! Use no chisels or other sharp objects! Use only a soft rag and solvent. Then post a couple of more pictures.
Jim
Interesting pad. The "6" is consistent with other original pads I've seen (but I do NOT claim to be an expert on pads!).
Jim
Jim
I'll do that. I will get some pictures of the casting number and date too. Thanks Jim!
10/30/57 (J307). Slightly disappointing. I thought it was the original engine.
Received 1,858 Likes
That's a '58 block. September 6th was the last day of '57 production, and '58 production started on October 14th.
