Flushing Brake System
Old Sep 13, 2015 | 10:34 AM
ph31mwl's Avatar
ph31mwl
Default Flushing Brake System
I am in the process of doing a frame off rebuild of my 65 convertible. The frame has been straightened, all the suspension bushings have been replaced, have installed a new set of Vansteel’s complete trailing arms, VBP’s HD Rear Camber Strut Rods, 3 inch half shafts with all new U-joints, new Eaton rear spring, new shocks and probably other things I can’t remember.
To finish the frame before installing the engine and transmission I am going to install new fuel and brake lines. I have 2 questions:
1 – back in 1982 when I had to rebuild the car after an accident (frame was not straightened correctly at that time) I installed new brake calipers that had the stainless steel inserts. The instructions said to use silicon DOT 5 fluid. In all this time I have never had a problem with the brakes…always rock hard. With the frame completely disassembled and the brake lines and calipers removed I assume that I will need to flush the dual master cylinder, splitter and the calipers in order to clean out anything that may have gotten into them while sitting on the shelf. What do I use that will not damage the seals, O rings and everything else that is inside them.
2 - The brake lines are 3/16 and I want to change to ¼ inch. Am I going to have to get some sort of reducers so I can fit them to the junction blocks, splitter, and master cylinder?
Thank you for your input. Mark
Old Sep 13, 2015 | 10:57 AM
MikeM's Avatar
MikeM
I think you've gotten your money's worth out of the seals in your calipers and MC. Wouldn't you agree?
Old Sep 13, 2015 | 11:23 AM
Roger Walling's Avatar
Roger Walling
Why would you want to change to 1/4" lines with disk brakes? Drums, maybe but disk?
Old Sep 13, 2015 | 11:47 AM
GTOguy's Avatar
GTOguy
I agree changing the line diameter is not called for. Simply flush the system with clean new fluid.
Old Sep 13, 2015 | 12:00 PM
MikeM's Avatar
MikeM
Well, I wouldn't change the line's size either even though GM eventually did. The 3/16" size works well. I would disassemble the calipers, inspect the pistons for corrosion (not that I think you will find any with the dot 5) and put in new lip seals/boots.
Old Sep 13, 2015 | 07:21 PM
ph31mwl's Avatar
ph31mwl
Thank you gentlemen, that is all I needed to know. Will purchase new 3/16 lines and disassemble the calipers and put in new seals and boots.
Mark
To Flushing Brake System
