Tall driver - Coupe or convertible?
Old 04-24-2016, 10:30 PM
wolfman64
Support Corvetteforum!
wolfman64's Avatar
2020 C1 of the Year Finalist - Modified
Originally Posted by Jackfit
Cruise Control is a must for us tall people. The gas pedal angle will kill you in long rides.
65,000 miles in the last 5 years was only possible with it
Jack
Ps. My son is 6'6" or more . I will eventually move the foot well forward 5"...no battery or AC in the way on drivers side. Once that is done, we will work on pedals. The extra room will allow the legs to lay flat on seat instead of splayed out.
We moved the floor board forward 4" behind the brake and clutch pedals....And added an Ididit tilt steering column.
carl3989 (07-08-2023)
Old 07-07-2023, 06:08 AM
adamp.burgess
5th Gear
adamp.burgess's Avatar
Default Someone help me
You must be talking about an automatic transmission... because how can you drive a 3/4 speed with 1 leg??? I'm 6'4 and can't drive my C1 (4 speed) because I can't get my foot to reach the clutch
Originally Posted by ghostrider20
I have a coupe, and I am 6-3". I'm long legged and fit fine. The only issue I have is on long drives. The steering wheel is between my knees and my legs are confined to the outside of the steering wheel, no way for me to stretch my legs in any regards. I actually got a blister on the back of my heal of my gas pedal foot driving to Arizona.
On the way home on the interstate I had an epiphany. I put my right leg in the passenger foot well, and used my left for the throttle.
Old 07-07-2023, 03:39 PM
Rick B
Rick B's Avatar
Originally Posted by bradc6
At 6'2" and 210 lbs with a 36" inseam, I fit better in my 66 coupe than I do in my 70 coupe. I think the old seats are worn out which makes me sit lower.
Headed to a car show 250 miles from here next weekend. Lots of fun getting out on the highway with the 66.
I'm 6' 2", 240lbs , 63 years old and fit in my 67 vert and 70 coupe about the same, both comfortable and no problems driving.
Getting in and out is another story, the tilt wheel on the 70 makes life much easier, thinking about going with a smaller steering wheel on the 67.
Old 07-08-2023, 03:02 AM
dunney
dunney's Avatar
I use this 15 " for regular driving. You can also move the column torward you almost 2" for extra leg room for shifting.
Is that a fishing pole sticking out the back of the car? I LOVE you!
I say convertible. I'm 6'0 300lbs and it's just more overall room. But try them both out, and see what you think is right for you. You can definitely maker adjustments with seats, steering wheel size, and maybe a telescopic sterring columns?
Quick Reply: Tall driver - Coupe or convertible?
