Backfire! (long)
Old Oct 13, 2016 | 08:27 PM
61 Roadster's Avatar
61 Roadster
2020 C1 of the Year Finalist - Unmodified
Corvette of the Year Finalist 2018
2017 C1 of Year Finalist
2015 C1 of Year Finalist
I may have found something; while tighting the manifold bolts to 30-35 ft pds (they were a little loose) I noticed the drivers exhaust "doughnut" is brittle, crumbling and can freely rotate. Passenger side crumbled a bit to the touch on the outer edges, but feels "rubber-like" and tight.
The drivers "doughnut" feels like a loose, broken plastic toy tire.
Will head in to local shop if possible tomorrow to remedy; hope that was the culprit.
Thanks to everyone here again!
kolsen911's Avatar
kolsen911
I would agree with the driver's side either exhaust leak or maybe even the intake manifold. Ignition or carbs would not effect one side.
Old Oct 13, 2016 | 08:30 PM
Twan Sloot's Avatar
Twan Sloot
Old Oct 13, 2016 | 08:35 PM
bluzrocker's Avatar
bluzrocker
Default Back fire
good deduction on the donut....
ok ....there are IMHO 2 kinds of donuts....the fiber/asbestos......and the ones that are all steel...
I have the steel ones and dont seem to break down....I assume all the major vendors have 'em and possibly a local shop Beveled on both sides...... just like the fiber ones...
been there with the exhaust leak/air introduction in the system....
Old Oct 14, 2016 | 12:06 PM
SWCDuke's Avatar
SWCDuke
Backfire is when the carb spits back. Afterfire are pops in the exhaust system.
If the latter it could be caused by a too lean idle mixture. If you lift off at high revs the mixture may be too lean to ignite, but it ignites in the exhaust system causing the pop. Back when Sprint Cup cars ran carbs that's why you saw flame out the exhaust when they lifted off.
Go through the idle speed mixture adjustment procedure. Start with the mixture screws out one turn from the seat and set idle speed at 500. Turn the screws in (leaner) and out (richer) in quarter turn increments until you get the highest idle speed gain with a smooth idle.
Reset idle speed to 500 and do it again. Once you get no speed increase and the idle is smooth, take it for a test drive. If it still afterfires try a quarter turn richer (out) on each screw and go from there.
The final adjustment should have the mixture screws out the same amount from the seat. I've seen plenty that are up to one turn different.
If there was a leak in the exhaust system you would hear it all the time.
Duke
Old Oct 14, 2016 | 02:22 PM
61 Roadster
Default Backfiring Solved!
It turned out that the broken donut was not the cause, but a symptom!
The drivers donut had blown out; a symptom of the backfiring along with muffler deformation (both of them). Once we had the car up on a rack, it was plain both sides were experiencing backfiring. It's likely I just didn't hear the passenger side as well when both of them backfired
The culprit turned out to be a cracked restrictor/cover plate for the passenger side metering rod on the AFB. Apparently under full throttle, the spring loaded rod would rise too high, allowing too much fuel into the carb. Under normal conditions, vacuum would pull the rod down far enough that both sides would function normally. Only under hard acceleration would the rod surpass the cover plates correct height.
Backfire is altogether gone.
Many thanks again to all who helped!
Old Oct 14, 2016 | 02:52 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Surely you aren't talking about that sort of kidney-shaped little cover secured by a screw on the carb's air horn that secures the spring-loaded metering rod ?
If that's the cause of the backfiring then that's one for the memory banks
Old Oct 14, 2016 | 03:11 PM
tuxnharley's Avatar
tuxnharley
Like I thought, it was the carb/too much fuel on deceleration, not the exhaust. On an AFB the metering rod steps basically serve the same function as a power valve on other carbs.
Glad you got it fixed!
Old Oct 14, 2016 | 03:57 PM
61 Roadster
Apparently it was; the shop hadn't seen that before either! BTW, the mounting screw had partially snapped the head, not the cover plate itself.
Thanks again to everyone!
Old Oct 14, 2016 | 04:01 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Glad it's fixed... but I think we should adhere to SWCDuke's suggestion of calling this "Afterfire".. as this is very different from backfire.
Old Oct 14, 2016 | 04:10 PM
61 Roadster
So when I heard a loud noise similar to a 30-06 round firing off, it was afterfire? My mufflers will never look the same again Perhaps I've been using the wrong terminology.
In any case the neighbors weren't pleased!
Thanks to all.
Old Oct 14, 2016 | 04:48 PM
tuxnharley's Avatar
tuxnharley
That's a great idea among us gearheads, and I'm sure the term is technically and semantically correct for all combustion engines. Backfire would have to go backwards through the combustion process, and afterfire would have to be after the combustion takes place.
"After" all in a jet its called an afterburner!
I think its way too late to change the use of backfire in the common lexicon though. How many of us former troublemakers remember intentionally turning off the key (in the days before steering wheel/ignition interlocks) while driving at speed and then back on again to intentionally create a "backfire"? I blew a muffler off of my Mom's 390 4bbl Ford Country Squire wagon that way............ Heck I remember the really old guys talking about accidentally causing a "backfire" by bumping the timing lever on the steering wheel on their Model T!
Maybe us gearheads and engineers can at least use it correctly when trying to diagnose a problem.
Old Oct 14, 2016 | 05:23 PM
  #33
GTOguy's Avatar
GTOguy
Never heard the term 'afterfire' before, but it is an accurate description and I like it. Will use it in the future. I too have never run into this problem with an AFB, and have owned, tuned and driven many of them. Another one for the memory banks. Glad the car is fixed, and even more glad the solution was posted in detail.
Old Oct 14, 2016 | 05:40 PM
  #34
Frankie the Fink
Army
"Afterfire" has been used on here back as far as '09 and prob much farther back; its not a new term but very descriptive...
