From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Originally Posted by Daren67
I can feel the gears come up and down smoothly when I lift it 1/2 inch ...so I think the gears are not binded. I will try a straight smooth pry and get back to you all. Spinning the advance flange does nothing as I pull correct?
i remember having a few stuck, mostly on engines thst i was stripping for a block,crank, whatever. When I would try to rotate the advance can back and forth it would be tight. Just kept going back and forth, rocking what little I could from side to side, and pulling upwards. Always pulled out built up gunk like it had been run on Havoline HD. Crap was thick! A small pry bar with a hook at the end as Frankie and others suggest always worked. Yesh, you have to get serious with it
I put two 1x2 pieces of wood 10 inches long and tried to pry on both sides evenly.
Depending on where your fulcrum point was, that 10" piece isn't much. Neither is wood. Use metal. Use a long metal bar and catch it under the flange of the distributor that seats on the manifold.
I agree with everyone else, spray the crap out of it and keep working at by pulling it up and wiggle/rotate it as much as possible to work sludge/grim loose..
you probably already know to pull the pan after its out..but its just a reminder...
If you are concerned about the pieces of gunk that drop off while pulling the distributor you can flush the block with the pan in place. After draining the oil pour some Diesel fuel into the oil fill neck, 1/2 gallon should do it, about $2 worth. Then drain that. If it is still dirty while draining do it again. I have done it a few times for different reasons.
Once on a Z28 after doing a valve job, you try and work clean but some particles get by you and end up in the pan. This is not factory approved I am sure.
There won't be enough Diesel left in the block to be concerned about after draining. Add oil and off you go. Much faster than pulling a pan to get some sludge out.
I was going to change the oil but not drop the pan. I would only drop pan if I broke or dropped the oil shaft that spins oil pump
Agree with that. Just drain it before starting it again because you dont want to circulate the PB or Kroil or whatever else you needed to shoot into it.
I'm getting skeptical that perhaps the OP has something unique going on...I've NEVER had, or even heard of, this much trouble removing a distributor. Trick question...what if the roll pin that holds the helical gear has worked loose ?
Good thought Frankie.
To test this theory I would pull up as hard as I can and at the same time rotate the distributor shaft, if there is resistance then I would suspect you are correct.
But in the thousands of distributors I have pulled I have never encountered the pin coming out. 2 + 2 gum cutter always worked for me when a distributor was stuck.
Joe
If that turns out to be the case strong prying could break it and the pan will be coming off afterall. Lets hope not.
Guys I appreciate your help with this. I plodded into many worse projects successfully with the help of the crack corvette forum squad. I am a solid 200lbs and put all I got into the pull. Second with a wood lever, I Applied a good amount of force. Certainly it should of broke the crud by now. But it did not. Thankfully I have patience ( still)and did not break anything. I want to put a crowbar in there but of course I will not. I doubt there is that much crud in there as we had car since 1980 (and babied it with oil changes galore) . Oil pan was dropped for new one back in 1990s as old one was dented bad. Dist was out in late 1980s for shimming as well.
Sounds like youve exhausted all reasonable approaches to the problem. Have you had anyone else take a look? Sometimes a second set of eyes....
If the distributor raises up the stated 1/2", and the rotor turns, that means the helical gear is dis-engaged....so that means the oil pump drive gear is badly stuck or the piece is trying to come out crooked and bumping one of the concentric, raised flanges along the shaft against something (I agree - unlikely)...
The oil pump drive screwdriver-like tongue slips into the slot and the connection depends on the distributor hold down clamp maintaining contact. I can't imagine enough "sludge" in that connection that would prevent the removal based on the effort already applied...
I'm now suspicious of maybe a slipped rubber chinese wall gasket (I never use them) or a big clot of RTV holding things up...if jerking up on the distributor feels a bit spongy that would be my final guess. I'm outta gas on this one!
Very strange...
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
If I remember correctly...Follow this and Comment guys...
The end of the distb shaft is set into the cam gear.... The end of the distb shaft also connects to the oil pump drive tang shaft... That tang has a Nylon collar the slips over the oil pump which connects to the oil pump drive shaft ....
Is it possible that the nylon collar is bound some how to the shaft and the distb drive? So when he pulls up the drive shaft to the oil pump it is coming up with it hitting the cam gear?
Sounds way out there don't it. But as stated the distrb can stick but if that intermediate oil pump drive shaft is somehow coming up stuck on the distrib shaft that could that have an effect?
Ok experts debunk my theory. I might learn something here.
I would have a helper crank the engine over while I was prying up on the distributor with a long screwdriver or something. Of course, if you can already lift it up far enough that the distributor gear is disengaged from the cam gear, then I guess bumping the engine over won't help.
If the roll pin holding the gear on to the lower part of the distributor shaft worked its way out far enough to prevent removal, then you may be kinda screwed. If that was the case, I think (Speculation) if the roll pin was sticking out and facing the cam gear it would hit that first, and if you then tried rotating the distributor ninety degrees, so the pin was oriented fore and aft, the distributor should come out further as the pin slides up past the cam gear until it hits the block.
