Engine wire harness install question
This is next on the list, since brakes are done. I remember years ago when I tried to start it last, as the engine was turning over, there a puff of smoke that came up around where the starter was. A new engine harness was then on order. Didn't want to take any chances with 50year old wiring.
Is the a certain place to start? Any need to take pictures of how the current harness is installed? Can it be done all topside without having to get underneath or Jack the vette up? Do you take the old one out completely and then put the new one in or put the new one in as your taking the old one out?
If I had the car on a lift and standing would have been much easier for starter hook up......but the rest of the wire replacement is very easy
install the starter,,,( pull remaining harness up, or push extra loom below)and very carefully route the wires to get as much Clarence as possible from exhaust...HUGGING THE BLOCK...easy to burn them if not really routed and placed and pushed into certain areas to make sure they stay in place and don't move later...... while driving resulting melted /burned up loom @ starter ruining a new loom
How did they install the engine harness at the factory? Did they attach to the starter first, then drop the body on and then route and hookup the rest?
SMART IDEA
This is what that GM connector from the starter basically looks like.
Close up of connector:
DUB
Before I connect the connector from the new harness to the firewall connection, is there something I can put on there, like dielectric grease or something, or just take a soft bristle brush and clean and vacuum it as much as possible?
Also, it looks like there are 3 black ties on the vendor which hold the harness wires going to the alternator/VR/horn relay areas. Can these be saved, meaning can they be unhooked to reuse again? They appear to be attached through the fender wheel well. Or are they just cut and new ones used?
When cleaning the terminals...make sure you take the TIME to actually understand what surface of the tang in the firewall junction area you need to be making sure are clean.
If you have not done so...taking the time to understand how the terminals meet up can and make a good positive contact with each other is important. These terminals when joined are under tension due to their shape...so simply assuming that they are all good can cause for the terminal or terminals that are not tight with each other...in conjunction with how many amps that circuit is providing can cause for a resistance and actually cause for that area to get hot and possible melt.
NOT meaning to put fear into your project...just trying to make you aware. Often times the circuits that can cause for terminals to get hot and melt are those are generally circuits that command a lot of amps...and by 'a lot'...I am generally referring to circuits in the range of 25 amps+. Any circuit regardless of amp draw can get hot if it is not making good solid contact.....but if the amps are low ..generally so is the heat.
I have felt the 20 amp fuse in the battery box are on a 1982 that supplied power for the computer and fuel pump relay,etc...and I have felt them and sometimes this fuse holder is HOT...but not to the point of being able burn me or melt the plastic fuse holder GM used. And what caused that heat was the fuse itself was dirty and not making good contact...even though it was able to still supply power to the components in that circuit.
What might take someone like me to do something can easily escalate to an insane number of hours due to so many potential problems can show up.DUB
