[C1] Need some Help...
Old Sep 21, 2017 | 03:23 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
You have to decide how original you want to keep things. You have a tach driven by the generator so a distributor swap wouldn't be such a problem.
I dropped a complete Pertronix distributor in my '61 and it worked perfectly, provided an electronic points conversion and worked with the ignition shielding.
With an HEI you can kiss that center ignition shielding goodbye (one of the distinctive features of a C1 engine bay IMO).
If you ball up some tin foil and tape it to various areas of the air cleaner and close the hood it will tell you how much hood clearance you have to play with. Trust me, it isn't much. The technique is similar to what I show here to check my air conditioning compressor clearance.
These cars do not have a PCV system originally, they use a road draft tube to scavenge the crankcase vapors at the rear of the block - I don't think you will lose that function if you swap intake/carb....but I could be wrong. PCV systems were introduced as factory standard in '63 except for option RPO-242 on '61 California cars.
Frankly, I would rebuild the WCFB if needed, get some unmolested valve covers (repros are available), get rid of that rubber hose in the fuel pump-to-carb line (repro, correct 'hard' lines are available), tune the car up and drive the snot out of it.
Old Sep 21, 2017 | 03:44 PM
Sovsen's Avatar
Sovsen
What performance gains are you looking for? If the car is running and your not looking for 10ths on the track why would you mess with it.
It is running very very bad. Its been parked in a barn for 16 years until this sommer. And it has been in and out of shops ever since.... My usual mechanic who is an elderly man, has given up. The carb has been cleaned 2 times and severel bits in it has been replaced. But it still cruises like a kangaroo and either dies in idle or run at 1000rpm.
I dont trust the car...4 times my dad in law have had to come out somewhere and tow me back to the shop.
Old Sep 21, 2017 | 03:47 PM
Sovsen's Avatar
Sovsen
I just want it to run smooth and reliable.... Dont trust any "rebuildt" stuff. Im afraid after a long journey here to Denmark and severel hours at the mechanic, it wont run much better than the one it replaced. After all it is very old and worn too.
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
If it's the original carb you might want to send it to someone in the states that knows what he's doing.
Old Sep 21, 2017 | 03:51 PM
Geralds57's Avatar
Geralds57
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
I doubt if it's the original engine but check the numbers. Finned covers and they don't look to be staggered bolt configuration for a 58.
Old Sep 21, 2017 | 03:54 PM
Sovsen's Avatar
Sovsen
Dont know if it is original....
Old Sep 21, 2017 | 05:39 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
We all want smooth and reliable.
I took my father's car out of storage 4 years ago. It had sat for 40 years. I have found that rebuilding/restoring the original parts is often the best path - not only to preserve the value of originality, but also you will find that modern reproduction parts are not made with the same quality as originals.
Lots of things can make a car run poorly. Have you checked the valve clearances? Spark plugs? Points? Fuel tank and lines (for rust, crud)? Old gas? Has a compression test been done?
It also appears you have an oil leak causing a puddle on the manifold.
Old Sep 21, 2017 | 06:00 PM
Frankie the Fink
Army
Originally Posted by Geralds57
I doubt if it's the original engine but check the numbers. Finned covers and they don't look to be staggered bolt configuration or a 58.
Nice catch.
I totally blew by that
Old Sep 22, 2017 | 12:08 AM
Sovsen's Avatar
Sovsen
The oil comes from the breathers on the valve covers. I forgot to mention it it drives Okey the first few miles when its cold. But the hotter it gets the bigger the problem gets... its impossible to cruise slowly down the boulevard...
Old Sep 22, 2017 | 12:11 AM
Sovsen's Avatar
Sovsen
The plugs are new. And he fitted a gas filter right Before the carb to catch any dirt.
Old Sep 22, 2017 | 12:14 AM
Sovsen's Avatar
Sovsen
This is the rebuild from CorvetteCentral. Is it the right one ? Maybe I should consider it....but 839$ 🤤
Old Sep 22, 2017 | 07:50 AM
Frankie the Fink
Army
That is NOT the right carb - that is for a later 62 or even a 63 as it has the fresh air tube at the passenger side at the rear of the air horn and doesn't have the brass vent tubes arching over the throttle bores. Besides being way over priced. Your carb should be a 2669S WCFB Carter with an air horn number of 6-1354 and a main body number of 0-208 or 0-1208, but, nearly any of the later C1 single carbs (not dual quads) can work on your car.
This is a 1957 Corvette carburetor but it may be as close as you can get...pricey but appears to be a quality rebuild: http://www.ebay.com/itm/1957-Chevrol...1ZnvPe&vxp=mtr
The fuel filter is inside the big fitting on the fuel inlet in the air horn on WCFBs. Its a sintered bronze filter - you may want to take that off to see if it needs cleaned out (note the direction of the filter and spring - they only go in one way).. You do NOT need that external filter and rubber fuel line.
Your problem may be as simple as a stuck choke based on your symptoms.
Old Sep 22, 2017 | 08:51 AM
  #33
Sovsen's Avatar
Sovsen
Okey thanks for the reply. But will the one CorvetteCentral recommend on the picture fit and work on my 58 ? It is not that important to me that it is the same as now. I just want a smooth driving har.. .
Old Sep 22, 2017 | 09:00 AM
  #34
Frankie the Fink
Army
It can probably be made to work; I looked at the web site, I don't know why they call it a 1958 specific carb when the picture is clearly NOT a '58 carb. These vendors have third parties that do the specialist work so there is nothing unique about buying it through Corvette Central. Why would you pay more for this clearly wrong carb than the more correct '57 carb I included above for less money ? Unless they don't ship overseas.
Old Sep 22, 2017 | 09:24 AM
  #35
Frankie the Fink
Army
That is about as 'hosed up' as you can get. Its not original, don't think its even a Carter carburetor. It looks huge and you may well be over-carbed...resulting in bog and poor performance. Looking at that, you need to make sure your intake manifold is original before you go buying a carb. The WCFBs have small bores and the manifolds are unique.
Old Sep 22, 2017 | 09:35 AM
  #36
Sovsen's Avatar
Sovsen
Is it a Rochester then ?
Old Sep 22, 2017 | 10:00 AM
  #37
Frankie the Fink
Army
Thought it was a Rochester, it needs to go IMO...
And the manifold application needs checked.
To Need some Help...
Old Sep 22, 2017 | 10:38 AM
  #38
Sovsen's Avatar
Sovsen
Needs to go ? Why? Is a Rochester like this one a bad match for a 58 Vette ? But your right, id needs to go, because it dosent work....
Can any one tell me what carburetor will fit on the intake under a Rochester like this ? Someone clearly made some changes on this car in the past... I dont have the time to take of the carb. We are in a hurry, cause my dad in law is going to the States next month to visit Hersheys. And he need the parts to be ordered and delivered to a friend called Bob who trades vintage cars. From there they will load a container and ship to Denmark...
Old Sep 22, 2017 | 11:08 AM
  #39
Frankie the Fink
Army
For one thing I believe they are spread bore carbs and might not match your manifold. For another that carb doesn't have air valve controlled secondaries. When you hit the gas it'll dump oceans of air-fuel mixture into your engine unregulated by engine demands. It appears you need to find somebody that knows classic cars nearby.
Old Sep 22, 2017 | 11:15 AM
  #40
Nowhere Man
Before anyone else recomends parts we should first figure out what you have. Locate on the intake manifold and block the casting numbers of each. Then tell us if you don't mind keeping the intake if we can tell you what carb you need. If indeed you really want a new intake and carb set up someone can recommend that too. But the way you discribe is the carb and possible the timing is not set up correctly causing your problems. If that's really the case then throwing parts at it won't solve anything.
