[C1] Need some Help...
Old Sep 22, 2017 | 11:27 AM
  #41
Frankie the Fink's Avatar
Frankie the Fink
Army
Before anyone else recomends parts we should first figure out what you have. Locate on the intake manifold and block the casting numbers of each. Then tell us if you don't mind keeping the intake if we can tell you what carb you need. If indeed you really want a new intake and carb set up someone can recommend that too. But the way you discribe is the carb and possible the timing is not set up correctly causing your problems. If that's really the case then throwing parts at it won't solve anything.
It's beyond that. Either the heads are wrong or the whole engine is a replacement. The straight-across valve cover bolts are a clue.
Old Sep 22, 2017 | 12:02 PM
  #42
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Weather or not the heads or correct to the year of the block should make no difference on performance of said engine. The thing the op needs to understand is all the parts need to be working at optimal performance and to have everything working in sync A whole bunch of miss matched parts won't help a thing
Old Sep 22, 2017 | 12:20 PM
  #43
Bill Pilon's Avatar
Bill Pilon
The WCFB will fit on the manifold the Rochester 4GC is on, I have actually used a 4GC on a car while waiting for parts for a WCFB, I have a few of each sitting around.
Bill
Old Sep 22, 2017 | 12:24 PM
  #44
Sovsen's Avatar
Sovsen
Bill
Is mine a 4GC model ? If so, there is no problem at all, if I understand you correctly ?
Old Sep 22, 2017 | 01:51 PM
  #45
Frankie the Fink
Army
a) running a carb temporarily while waiting for a correct part is not "...no problem at all" and I've certainly done it, and,
b) it sure as hell matters what heads, etc.. are installed vis a vis performance. Bolt a set of D00E Windsor heads on a stock Ford 289 and see what happens.
I'm out...there is not much more I can add that is deemed worthwhile
Old Sep 22, 2017 | 01:58 PM
  #46
Sovsen's Avatar
Sovsen
Sorry to ask... what is heads?
Old Sep 22, 2017 | 02:12 PM
  #47
Nowhere Man
cylinder heads.
Old Sep 22, 2017 | 05:01 PM
  #48
Sovsen's Avatar
Sovsen
Does this number tell you anything about the type of intake I have, and if it will fit well together with the WCFB ?
Old Sep 22, 2017 | 11:18 PM
  #49
Loren Smith's Avatar
Loren Smith
That is a good sign, you have the correct intake for a 1958 230hp Corvette - part number 3746829. Who knows, that might be the original intake for your car. If you are lucky, maybe you also have the original block, with later model heads. Nonetheless, Frankie is right that getting a rebuilt WCFB should be the easiest way to go. Here is another one I found on ebay, if you don't care about matching numbers, and the listing says it ships worldwide:
http://www.ebay.com/itm/1958-1965-CH...RZSTiF&vxp=mtr
Old Sep 23, 2017 | 11:48 AM
  #50
Sovsen's Avatar
Sovsen
We are ordering some other parts for the car from Corvette Central. Thats why we would like to get the carb from them as well. Just to keep things simple.
I understand that the right "original" carb is the one you links to on eBay. Chicago Corvette Supply got it as well. And I will try and buy one of them if necessary. BUT can you explaine what kind of problems I will get, if I buy the one from Corvette Central ?
Old Sep 23, 2017 | 02:23 PM
  #51
Sovsen's Avatar
Sovsen
Is that an adapter ? And if so...then what ?
Old Sep 23, 2017 | 02:41 PM
  #52
Sovsen's Avatar
Sovsen
Im pretty sure I saw 4jet written on it.... 4jet is different from a 4GC isnt it ?
Old Sep 23, 2017 | 08:25 PM
  #53
Loren Smith
Check the archives on Chicago Corvette, buyer beware. But you can't go wrong with Corvette Central, although they would probably cost more than an eBay seller. Since you are buying international, they might be your safest bet.
Old Sep 24, 2017 | 05:03 AM
  #54
Sovsen's Avatar
Sovsen
Im so sorry. I missed an e-mail from CorvetteCentral.... They admit it is a wrong photo on the webshop and they send me the right one.
I guess everything will be alright now 🤗
Old Sep 24, 2017 | 02:43 PM
  #55
Sovsen's Avatar
Sovsen
Cant wait until spring now. I have ordered all the parts now, so it will be ready :-)
