Tach on my '62
Tach on my '62
When I bought my '62 in 1987 and started my restoration, I never found a correct distributor or a tach cable for the instrument cluster. The installed distributor works great but has no provisions for the tach cable. At this point I'm not about to take out the instrument cluster, line up a numbers correct tach, or try to jam my big hands in back of the instrument cluster to thread the tach cable. So is there a way to operate the tach electronically using my installed distributor?
Received 1,126 Likes
Your tach that is in your dash is a mechanical unit so it has to be driven by a cable from your distributor. If you want to go to an electronic tach you still have to pull the dash and swap out the tachs.
Joe
Joe
First thing you need to do is verify that the tachometer in your instrument pod actually works. You can do this by hooking up a tachometer cable and spin it with a drill (in reverse). If the tachometer works there are "black boxes" available that can convert the distributor signal to a mechanical drive cable. Look up the Abbott Cable-X unit, rather pricey but it works. I have used the Cable-X on two cars to drive the speedometer and the tech at Cable-X told me it can be used on a coil/points ignition to drive the tachometer, but I have never tried it. If the tach does not work your options are to remove it and repair it or replace it with an electronic unit (probably your cheapest solution).
Charles
Charles
Since I'm not concerned about a numbers matching distributor will any Chevy tach drive distributor work on my 327 SB? I'm thinking 62-74? Still... trying to thread that cable from under the dash is going to be a bi*ch!
Received 3,443 Likes
This is what I did. I bought a good used one off of Ebay that was out of a '69 Corvette for about $150. I wanted it for the vacuum advance, mainly. It worked out fine. Super easy.
ANY tach drive dizzy will work. I am going to make an assumption that ALL '62 tachs were driven off the dizzy, and NOT the generator on some?
To the OP: if the tach drive sources were different, you need to verify of yours was dizzy driven or not, to get correct reading.
Doug
Doug
Doug
Doug
Received 1,957 Likes
Pretty sure it was for a '62. I've had it for several years. $100.00 would be fine.
Let me know if you're interested.
Pat
