[C1] 57 windshield mount " T " bolts
I had a new set of windshield mount " T " bolts From Doc Rebuild but I couldn't find nuts for them anywhere . Everyone said that they were and odd thread , so I ordered another set from a different vendor . The second set came with nuts but they were very thin and I wanted heavier nuts to pull the frame into the setting material . Same thing , Couldn't find nuts that would fit , even at " Fasten-all " , a large specialty nut and bolt hardware supplier . I managed to find a couple old used nuts in some of my bolt cans so I know they exist but for some reason they are making these with an unusual thread . This is insane. This is part of the job that should be simple but I have lost the last couple days looking for these 8 nuts with no luck .
I think they are 24 thread. If nothing else buy some regular bolts with matching nuts and grind down the head into the shape of a T I had to order a bag from Fastnall but I ordered nuts that were serated so I would not have to mess with lock washers.
Tyler
Tyler
bj1k (04-07-2018)
They are 12x24. Don’t use any other type/size, or you’ll screw it up.
I think that ACE hardware sells them. The big box stores don't carry such. Here are some links on line. I use the last one (Fastenal), with the serrated flange. No washer with this one.https://smile.amazon.com/Hillman-Gro...ords=12-24+nut
https://www.grainger.com/product/GRA...crew-Nut-2GA59
https://www.fastenal.com/products/details/37336
BTW, these are the same size for ALL of the C1 T nuts. This size is used in several places on C1 and C2 Corvette. Deck lid latches come to mind on both eras.
bj1k (04-07-2018)
