[C2] Six Sequential Tail Lights
Old Apr 26, 2018 | 05:07 PM
  #41
toddalin's Avatar
toddalin
Originally Posted by KC John
What is the clicking sound coming from Plasticman's car?
Flasher relay.
There is no video of the '62 to go with the audio, at least on my system.
Old Apr 26, 2018 | 06:03 PM
  #42
Plasticman's Avatar
Plasticman
Originally Posted by toddalin
I've been considering doing this on my '64, but it seems that the wiring is a PITA to get at. I would just use a pair of 555 chips and relays with the existing bulbs. Probably no more than $10 to do the job.
You are correct (but only one 555 required and no relays - I tried relays but are too slow). Note that it does require LEDs (incandescent bulbs "turn on" speed is too slow).
See below circuit:
Black Magic fixed the link to my video (see his website link in his #1 post).
I have the PCB (perf board) layout, etc., if any one is interested. The values for R1 (and R1A) are listed on the lower left of the schematic. One note on the schematic says "1N4002 diodes were used....". These are in ref. to the 2 1N4001 diodes shown in the schematic (in other words, 1N4001 diodes are fine for this application).
Note that I have been running this circuit in both my 03 and 62 Vettes since 2011, plus have it installed on friend's Vette, with zero issues.
Plasticman
Old Apr 26, 2018 | 06:15 PM
  #43
Plasticman's Avatar
Plasticman
I have a LOUD clacker circuit for my turn signal flasher (due to hearing loss, and loud exhaust).
Video has been repaired, thanks to Black Magic!
Plasticman
Old Apr 26, 2018 | 07:04 PM
  #44
wmf62's Avatar
wmf62
St. Jude Donor '07
Unfortunately the video did not come through.
Plasticman
John
I can see the video on the bottom of Black Magic's web page, see post 38
Bill
Old Apr 26, 2018 | 07:14 PM
  #45
Plasticman's Avatar
Plasticman
Originally Posted by wmf62
John
Bill
Bill,
Yes George (Black Magic) ran it through a converter, and it works great!
Thanks to Black Magic!
John (plasticman)
Old Apr 26, 2018 | 07:20 PM
  #46
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
There was a problem with the original .mp4 file John sent me that caused it to fail on SOME version of browsers. I ran it through a converter .mp4 in .mp4 out and it cleaned up the problem.
If it does NOT work on your OLD browser
Try this link for 62 Vette (Plasticman) ===> Click Here
George
Old Apr 26, 2018 | 07:35 PM
  #47
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
PO installed the extra tail lights in the 65 in late 60s. He used some homemade U brackets he made up. Not as nice as Magic's though. When I had the body repaired from an accident I had "buckets" added to replace the hardware used before. The inner lights now mount just like factory.
Tom
Old Apr 26, 2018 | 07:41 PM
  #48
toddalin's Avatar
toddalin
See below circuit:
Plasticman
Both systems are a bit fast for my taste.
I would run them slower and 555s/relays could be used (they operate down to milliseconds with the time is spent heating the filament). A partial current through a resistor could also be sent to the outter light when the inner light comes on, so the bulb is "pre-heated" when the relay fires it.
Remember that the original T-Birds/Cougars did it with incandecent bulbs.
With the provided circuit, it states that each LED assembly consumes 0.15 amp. The 555 chip can dissipate as much as 0.25 amp (250 milliamps) and the Darlington transistors may not be necessary if a pair of 555s or a single 556 chip were used. The 555s/556s are probably cheaper.
Alternatively, the Dartingtons could be replaced by a pair of relays using the single chip with just a bit of modification to the circuit, and this would retain the same timing between the two sides.
BTW, I think that the 0.1 mfd cap is shown in the wrong place. As shown, it is simply in parallel with the 100 mfd yielding 100.1 mfd. I'm thinking this should be on pin 5 and should be 0.01 mfd.
Old Apr 26, 2018 | 07:53 PM
  #49
Black_Magic
Tom
If Vette wasn't painted I would have went with the buckets BUT the simple brackets vs new paint job --- no contest
George
Old Apr 26, 2018 | 08:14 PM
  #50
wmf62's Avatar
wmf62
St. Jude Donor '07
they're a bit fast for me too, and John's seems to get faster as 'things' heat up...
the TBird/Cougar sequencers were done with an electric motor operated 'timer' for each set of lights. you could hear them run when the turn signal was operated...
Bill
Old Apr 26, 2018 | 09:43 PM
  #51
Sky65's Avatar
Sky65
George
You did a nice job on the brackets.
Tom
Old Apr 26, 2018 | 10:32 PM
  #52
Plasticman's Avatar
Plasticman
Bill
My design can be adjusted to suit.....Simple single screwdriver adjustment on one pot (one pot, one timer that covers both left and right - which eliminates any differential from side to side). But the turn signal (electronic) flasher determines the base flash rate. The 555 chip just determines the offset of the 2nd light flash.
I believe that was the first version, which did not have the stability of the 555 timer chip.
John
Old Apr 26, 2018 | 10:55 PM
  #53
409/409's Avatar
409/409
Originally Posted by 409/409
Do you use the inboard bezels and is there a left and right? Also under what category is the mounting hardware? Thanks
Can anyone answer my questions???
Old Apr 27, 2018 | 02:47 AM
  #54
wmf62's Avatar
wmf62
St. Jude Donor '07
check the Trim Parts website. they are the inboard lights and there is a right & left. you're going to have to make your own U-bracket retainers as shown elsewhere in the thread.
Bill
Old Apr 27, 2018 | 08:10 AM
  #55
Black_Magic
See post #30 Above
George
Old Apr 27, 2018 | 05:31 PM
  #56
GARRETM-FABTRON's Avatar
0GARRETM-FABTRON
Former Vendor
Cool thread , 6 lights look good on the GS also. We are building two
with the sequential lights.Found these harnesses on ebay for 2008
mustang and up , has the sequencer built into the harness. Hope to
try them out in a few weeks.
Old Apr 27, 2018 | 09:20 PM
  #57
65air_coupe's Avatar
65air_coupe
George
I did buckets and did not disturb the paint job.
To Six Sequential Tail Lights
Old Apr 27, 2018 | 10:00 PM
  #58
409/409's Avatar
409/409
If I do this I would forgo the sequential for backup lights like on the Impala. I think this is how GM would have done it and wiring wise it would be simpler.
Old Apr 28, 2018 | 03:59 AM
  #59
wmf62's Avatar
wmf62
St. Jude Donor '07
that is a possibility that they might have been done that way, considering backup lights were an option; otherwise they would have been all red
Bill
Old Apr 28, 2018 | 07:12 AM
  #60
409/409's Avatar
409/409
I have a 1966 coupe and backup lights were standard starting in 1966 and onward.
