[C2] Steering Alignment.
I rebuilt the trailing arms on my 67 this past winter, so they had new bolts and sorted shims. Cost me $100 for alignment. I brought my own shims for front and back.
I would suggest that if you don’t belong, join National NCRS, then join the local chapter. Then contact the local chapter for recommendations. I’ll bet someone will know of someone old school enough enough to do a corvette alignment.
That's what I did!!!!! 61 drives perfectly straight.....no longer wonders...aimlessly!!!!!!
Good luck,
Dcamick
I am far from an expert on this..........so hopefully a few of the more experienced guys will input. But if you know the rear toe in degrees (your print-out) you can convert this into inches. Then you can see how much to adjust the rear shim packs to get it correct. That is the way I was planning to approach it on my own car, being careful to keep my final rear toe "slightly in" versus "slightly out". SWCDuke and others on this forum over the years have given information regarding shim adjustments versus rear toe in inches. So it is just a matter of getting it converted from degrees. I can't give you the formula today, but it is something that should not be difficult to get/do with a little investigation.
If needed, I will pursue this for you, but GTOguy and Cautrell05 may have a quick way to do. It should just be a simple matter of tire diameter and some old high school Trig functions (remember those??
)Larry
EDIT: Here is one calculator I found for the conversion. I have not checked/tested it for correctness, but if you check on the internet there are many sites that have this information. https://robrobinette.com/ConvertToeInchesToDegrees.htm
Write down exactly what changes you made to the rear so you can compare your earlier printout to the new one and you will know exactly how those changes impacted your rear wheel alignment.
Five years ago another shop quoted me $200 so I was judging off that. So here I am once again relying on myself to get things right. Nothing new for me as I have always done things myself, just for this reason. Thanks for taking an interest, Al W.
The manager said he'd have to charge me an "exotic car fee" (yeah - no kidding!)
I said that the Mustang was the most prolific car ever sold in the US but he wouldn't relent...
I rewarded him with a nice patch of rubber on his driveway as I left...
I sincerely hope the OP gets it resolved; if not I'd contact the local Better Business Bureau....
Some laugh at this but I've had excellent results getting resolution with a crappy re-plating job and a bum transmission fix from Coffman transmissions -- I'm just sayin'
As for the first gen Mustangs, they were never exotic, but always were a real PITA to align, due to their cheesy suspension design. (Ford Falcon). I could align 3 GM cars to every Mustang in the same amount of time.
Once camber is good, center your steering and front wheels into the most dead straight ahead position that you can determine.
It's a good idea to purchase or borrow a simple tram gage to check toe in, in inch fractions.
With KO wheels it's easy to stretch string line from front to rear by wrapping it around the hub of the KO spinner. With hubcaps you probably want to pull them and wrap it around a lug nut so it's fairly taunt. That gives you a reference line. The track is different front and rear so the two lines are not completely parallel but it's a reference only so that doesn't matter. I find something to use as a long straightedge - 4 or 5 ft long should be good but it needs to be straight. First I check the straight ahead position of the front tires by laying it horizontally against the tire side wall near the center and check to make sure that the distance off the string line is the same on both sides and that the tires are straight. You can also check distance to the body on both sides or to the frame rail if possible. It won't be as accurate as an alignment rack but if careful you can get it real close.
With the tram gage, check toe in (toe out) for a starting reference point. If it's around 1/32 to 1/16 inch toe in you will be in luck. Then lay the straight edge horizontally against the sidewall of the rear car and measure the deviation to the string line at the same distance from the wheel center on both sides. For example, if the straight edge deviates further out from the string line on the driver side than on the passenger side, you will have some negative thrust to the left. If your total toe in was not in spec, then based on the measurements to the string line, decide which side it would be best to move a shim on to get it within toe in spec before going on.
With a string line, the apparent thrust angle in my example (front of left rear tire turns out and right front turns in) will be exaggerated because with the left rear tire turned out in front, it will move the string line out while the string line on the right will move in along with the front tire shoulder. This discrepancy in the string lines doesn't matter because it's an arbitrary reference line that helps you decide which direction to go in making adjustments. As reference lines they only become uniform side to side with the car's centerline after the alignment has been wiggled in and the tires are tracking on both sides the same.
Assuming your total toe in was within spec to begin with - for the example now it becomes a matter of taking shims form the outside of the left trailing arm and switching to the inside - and taking the same amount (thickness) of shims from the inside of the right trailing arm and switching to the outside - and re-check where you are at. Hopefully your trailing arm pivot bolts and shims have been touched sometime in the not too distant past and are free and easy to work with. This part is basically just wiggling it in until you have uniform deviation to the string line on both sides and total toe-in within spec. If the deviation to the string line is equal on both sides, then theoretically you have even toe in on both suspension sides. The car should be rolled back and forth and settings double checked.
Plan on the better part of an afternoon for all of this. Is this as good as a modern alignment rack - heck no. But if you are real careful and double check your work you can get pretty good results. I've got 3 old cars I've garage lined and two have independent rear suspensions and they all track straight down the road with hands off (provided I find a uniform section of road). And no strange tire wear.
