getting depressed
Old Aug 19, 2018 | 06:42 PM
  #81
MikeM's Avatar
MikeM
Originally Posted by number3
yeah im thinkin its gotta be that damn module
Did you use the test light to check it or just pull a coil wire and see no spark? Could be two totally different problems?
Old Aug 19, 2018 | 06:49 PM
  #82
Factoid's Avatar
Factoid
the set up i have is similar to that one i believe it has the 605 module , but i cant get at it until i figure out how to get the centrifugal setup off , if i put a meter on the wires from it what should i get for a reading ?is that possible ?
That module is actually made for Mallory distributors. Does your engine have a Mallory distributor?
Here are the installation instructions and there are troubleshooting tips on the last page.
https://static.summitracing.com/glob...nitionmodu.pdf
Old Aug 19, 2018 | 06:50 PM
  #83
rtruman's Avatar
rtruman
you might be on the right track there , im thinking its electrical , mech said yestrday the carb wasnt perckin fuel after he drove it , what gets me is when i changed it to the ballasted coil all was well problem solved so i figured it was the resistor , then it happened again i was getting a sticker the other day and while it was in the garage it was idleing of course while hot then the idle started to struggle a little and then boom it died , wouldnt restart with the key , we pushed it outside and rolled down a decline with key on and bingo it fired off , i got about 2 miles from the place and it sputtered but cleared up and got it home , would it have jumped started if it were electrical ?
This happened to me there is a by metal strip inside ignition when its gets worn it doesn't make contact I broke down at the same traffic light
The car was on incline next time it happens put a test on the coil to see if the ignition isn't making contact .
Old Aug 19, 2018 | 06:52 PM
  #84
Factoid's Avatar
Factoid
Dammit, Mike, that is a good question! I assumed (perhaps stupidly) that he followed your advice and used the test light as that would have been the proper half-splitting troubleshooting approach.
Old Aug 19, 2018 | 06:59 PM
  #85
number3's Avatar
number3
yes i checked it both ways got the light on the neg side of coil , but zilch for spark
Old Aug 19, 2018 | 07:04 PM
  #86
MikeM's Avatar
MikeM
Did you get a light, steady light, dim light, or bright flashing on/off/on/off or what?
If you got a bright flashing on/off/on/off light, your distributor is good. That leaves the coil and what else? If you didn't get the bright flashing light on/off/on/off, your module or something connected to it is bad.
  #87
number3's Avatar
number3
if that is what the module is made for then thats gotta be what i have what i have , it looks exactly like the 605 and has the centrfigal contacs under the rotor that i cant get off
Old Aug 19, 2018 | 07:08 PM
  #88
number3's Avatar
number3
it was bright steady light , tester also has the audible beep and that was steady
Old Aug 19, 2018 | 07:14 PM
  #89
Factoid's Avatar
Factoid
If you have a Mallory distributor, it is probably this one (pictures would be nice).
https://static.summitracing.com/glob...aa-3727501.pdf
Remove the distributor, punch out the gear roll pin and remove the gear. Slide the shaft out of the housing and replace the module (make sure you set the gap properly) and reinstall in reverse.
Old Aug 19, 2018 | 07:27 PM
  #90
number3's Avatar
number3
I think thats the one i have but i have never pulled a distributor out and dont have that much experience i was hoping that damn thing could be replaced without takin the whole thing out, i called a fireind and he said he could help me with that . im just a parts replacer as long as i can get the old one out without to much expertise . ps i dont know why but everytime you send me a link i can keep it up on my screen , im sure its on my end and not yours .
Old Aug 19, 2018 | 07:28 PM
  #91
number3's Avatar
number3
what gap are you talking about ?
Old Aug 19, 2018 | 07:51 PM
  #92
number3's Avatar
number3
If i have time tomorrow ill get some pics up thank you all for your help
Old Aug 19, 2018 | 07:56 PM
  #93
MikeM's Avatar
MikeM
I'd say your module is bad. I'd almost bet on it. I don't know anything about beepers. What are they supposed to do? BeeP?
Old Aug 19, 2018 | 08:50 PM
  #94
MrTrim's Avatar
MrTrim
Used to sell both the Mallory breakerless conversions as well as the Mallory unilite distributors in the 70's, 80's and 90's. We finally had so many defects, mostly due to heat related concerns, we quit selling them. Now that said, I don't know how old your system is, so maybe those problems may be in the past. The Petronics system was always the fix for those who wanted electronic ignition with the look of an original distributor.
Chris
Old Aug 19, 2018 | 10:15 PM
  #95
number3's Avatar
number3
the test lite has a tone as well as a lite yup they beep.lol
Old Aug 19, 2018 | 10:25 PM
  #96
Factoid's Avatar
Factoid
The gap between the reluctor and the pick up. See the 605 instructions I posted earlier.
Old Aug 20, 2018 | 05:13 AM
  #97
number3's Avatar
number3
perfect thank you for the help
To getting depressed
Old Aug 20, 2018 | 01:09 PM
  #98
number3's Avatar
number3
Just an update called mallory this morm sat in que for 15 minutes taklked to some guy that sounded like he was distracted maybe playing solitare ? tells me the modules either work or dont (ive heard that before ) no way does it work after cool down when it goes it goes yeah ok he had an accent . anyway he tells me to make sure voltage on green wire is between 3 and 6 volts , i go check and sure enough the wires are reversed getting 12 on the green wire so i reverse them and call back wait 15 more minutes in cue this (he also has accent) tells me it wont damage the module even though ive read on the website it will but he says let me check , boom we get disconnected . I call back wait another 15 minutes in que and bingo i get a guy who talks american he says yeah that'll cause the hot start problem and yeah that'll damage the module better order another just to be on the safe side . So module on order as well as circuit protector , headed up tp adap to get new voltage regulator as the cover on mine warped (plastic) and fell off . parts should be here friday i'll keep ya posted thanks again to all who helped !
Old Aug 20, 2018 | 01:14 PM
  #99
emdoller's Avatar
emdoller
Great news.
Old Aug 20, 2018 | 06:14 PM
  #100
number3's Avatar
number3
second update ! installed new vr, voltage to batt is now 12.7 before it was at 16 ! i took it for a blast down the road about the same miles as yesterday , temp only got up to 165 degrees as compared to yesterdays temp at just under 180 . unfortunately no change in temp under the hood, other parts should be here friday , mechanic told me to bring it down and hell swap'em out no charge ! Hes as pissed off that the first fix didnt work as i was , cant beat that for a square shooter .Ill update ya next week
PS old vr was solid state vr715 i think new one is old style like original equip
