Headlight Switch removal
Old Sep 1, 2018 | 04:40 PM
ah53's Avatar
ah53
Default Headlight Switch removal
Pushed the button and pulled on the **** to remove the shaft but it seems to hang up. Any thoughts or help before I start cutting the shaft. Is there a connector to the switch I can remove instead?
Joe
'65 Coupe in process of removing the cluster.
Old Sep 1, 2018 | 04:50 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Sometimes the shaft does get hung up. Keep wiggling, jiggling it. Mine did that, but finally came out. Dennis
Old Sep 1, 2018 | 07:50 PM
bj1k's Avatar
bj1k
Don't cut it ! Sometimes they are a little stubborn but it will come out . Those are not cheap .
Old Sep 1, 2018 | 11:20 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Agree with Dennis.
Old Sep 2, 2018 | 12:55 AM
buns's Avatar
buns
Joe
Yes. Pull or push up on the connector pictured.
Old Sep 2, 2018 | 09:32 AM
65air_coupe's Avatar
65air_coupe
I had the same problem not too long ago and someone gave me a simple answer that I can't remember now but it was either push it all the way in before pushing the release button or pull it all the way out, then press the button. Whichever it was, it was exactly opposite of what I was doing and it came right out once I did it differently.
Old Sep 2, 2018 | 10:16 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
People don't understand how the push-to-release mechanism works on these switches; start watching at 11:45 minutes into this video to see an explanation (the guy is not the greatest narrator but you'll get the idea):
This should show you why the release is a bit flakey....you have to push up on the button straight, firmly and ALL the way in to cause the little "teeter totter" metal on the slider to move the blade in the vertical plate down to release the ****'s shaft's groove to slide the **** out....and the slider has to be positioned just right over the button.
Old Sep 2, 2018 | 03:54 PM
Redbird's Avatar
Redbird
Thank you for posting Frankie! I just pulled mine out a few minutes ago and hope to have the same results!
Old Sep 2, 2018 | 07:44 PM
ah53's Avatar
ah53
Success!!!!!!!!! I want to thank all who offered suggestion and help. When you put it all together , knowing what the objective was it slid right out. Just to add one more idea, I remembered the old adage "if it should move and doesn't WD40 it". I did that, spraying both the shaft and the button; waited a few minutes and it came apart as "advertised". Hopefully opening a beer will be less trouble. Again thanks to all and if you reading this from the archives I
Old Sep 2, 2018 | 11:25 PM
Dave Tracy's Avatar
Dave Tracy
Be careful with the WD-40. It is not a lubricant! When the volatile agents evaporate, the remainder becomes sticky. Make sure you clean off the residue before you reassemble it.
Old Sep 3, 2018 | 07:30 AM
Frankie the Fink
Army
Buy some DeOxIT electronic contact cleaner - its good for switches, connectors (like bulkhead connectors) and radio *****. I always have a can handy - far superior to the Radio Shack spray goo...
To Headlight Switch removal
