[C1] One dim headlight
Old Dec 8, 2018 | 10:20 AM
mcb55-210's Avatar
mcb55-210
Default One dim headlight
On a road trip this past fall, a bouncing rock zeroed in on my '62 and directly nailed my left side low beam headlight. As you can imagine, I was quite pleased that it hit the headlight and not the body! I picked up a couple new headlights and decided to replace them last night. After installation I noticed the left side was dimmer than the right side. Swapping the right side (brighter) bulb to the left side, it was as dim as the other one. Thinking it was maybe a corroded connection, I cleaned the terminals but experienced no change. Although I seldom drive the car at night I have considered the relay upgrade in the past (and now may be the time) but I'd still like to know if there is a way to diagnose the dimmer left side before moving forward.
Any thoughts?
Mike
Old Dec 8, 2018 | 11:09 AM
emdoller's Avatar
emdoller
Do you have a voltage meter? If so, measure it.
Ed
Old Dec 8, 2018 | 11:13 AM
kellsdad's Avatar
kellsdad
If it were mine, I'd get out the multimeter and some jumper wires. Connect one jumper to a known, good ground and another to the powered connection to the headlight. Use the multimeter to measure the voltage between the two jumper wires. Repeat for the other headlight and compare the voltages. If the dim one is lower, I'd start moving back along the wiring harness on that side until the voltage read higher. That would identify the stretch of harness with the problem. .... If the initial test showed the voltages were about the same, I'd use the multimeter to measure the resistance in the ground wire serving the dim headlight. If it is high, then a bad connection in the ground circuit is the problem.
Mark Lovejoy's Avatar
Mark Lovejoy
Also check the ground wires carefully.
Old Dec 8, 2018 | 11:50 AM
GTOguy's Avatar
GTOguy
What these guys said. You have excessive resistance in the circuit or a bad ground. You will need a multimeter to check it out. The headlamps run off of full system voltage (12.6-14.5).
Old Dec 8, 2018 | 11:59 AM
65GGvert's Avatar
65GGvert
I'm betting on the ground connection on that side. there are two connections, one on the bulb and one about a foot from it check those connector ground leads.
Old Dec 8, 2018 | 12:14 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
All good advice. And spray that connector with some DeOxIt - best stuff around
Old Dec 8, 2018 | 03:18 PM
mcb55-210's Avatar
mcb55-210
Thanks, all. Will do. And since I just received the "brake attention module" I recently ordered (one of those gizmos that permits the brake lights to flash rapidly before becoming full-on) it looks like I will be spending some time working through some electrical projects.
I appreciate the suggestions.
Mike
Old Dec 8, 2018 | 05:10 PM
Frankie the Fink
Army
The brake strobe module I got connects to the brake light switch in series. It’s a no-brainer.
Old Dec 20, 2018 | 01:39 PM
mcb55-210's Avatar
mcb55-210
Finally getting some shop time...wired in the brake light flasher last night. Very simple and clean installation. Really like the results and hope it will attract attention while stopping. Highly recommended!
With 14.3 volts at the headlight connector, with Frankie's help I resolved the dim headlight problem. The ground source on the horn relay was corroded. After cleaning it up I now have two bright dim headlights. Thanks to all for the recommendations.
Mike
Old Dec 20, 2018 | 01:42 PM
65GGvert's Avatar
65GGvert
That''s always better than two dim bright headlights.
Old Dec 20, 2018 | 05:17 PM
mcb55-210's Avatar
mcb55-210
.....guess I had that coming!!!!!
Mike
Old Dec 20, 2018 | 07:21 PM
Frankie the Fink
Army
Folks can say what they want but that brake light strobe module has made a difference. I notice people behind me doing a slower roll up on me at red lights and not camping out 2 feet off my bumper.
Old Dec 21, 2018 | 07:58 PM
bj1k's Avatar
bj1k
Bad ground .
Old Dec 21, 2018 | 08:18 PM
65GGvert's Avatar
65GGvert
Originally Posted by bj1k
Bad ground .
Somebody skipped post 10.
Old Jun 8, 2019 | 12:38 PM
Rhettvette's Avatar
Rhettvette
Right on Ed. Thank you
Old Jun 8, 2019 | 12:39 PM
Rhettvette's Avatar
Rhettvette
It was a bad Ground. Thank you
To One dim headlight
