Cloyes C3023K OE replacement truck roller chain set or the four degrees advance/retard option version, C3023X. These sets are available in other brands including NAPA... same parts, just a different marketing channel.
The OE replacement passenger car silent chain set is C3021K. This is the second design all metal version that is narrower than the early set up to the '64 time frame that replaced the nylon cam gear type that was OE from '65 to ???, but these are junk and have a habit of shredding teeth. This nylon tooth cam sprocket set has not been manufactured for decades. I'm not sure if there is an adjustable version of the C3021K. Check the Cloyes Web site.
All should be in the range of 20-25 bucks for the set... shop around for the best price.
I agree with Duke. I used to run the Cloyes double roller chain sets in my Pontiacs (still do because they've been in there for 30+ years), but they like to stretch quite a bit after the initial install. The stock style, but steel geared link sets as mentioned above are strong, run quiet, and stay tight for a long time. That would be my choice. I ran the double roller because back in the day, it was the hot tip.
The iwis brand chain is the best chain. I'm not sure which brands use them in their sets. I just bought a US made Dynagear set for my LS and I'll be damned if it didn't come with a chain made in India. I bought it because they said US made.
Duke
I know they were still around in 1971. I had one go bad on my 71 vette back in the late 70's. Couldn't believe it when I pulled the cover and saw that nylon mess, what were they thinking!!!???
I have seen the 9 key crank sprockets mark up the crank snout pretty good some have even said they led to crank failure. I prefer 3 key way or less. Cloyes has them I didn't see a Melling available. But to answer your question Melling products are good.
On the other hand, those nylon sprockets were known to run many tens of thousands of miles without a problem. Almost 200, 000 miles of personal eperience. Not taking up for them, just saying....................
In 1968 and 69, Chevrolet engineering recommended the nylon sprocket for Trans-Am competition 302 engine builds. I think Traco built a few with that gear too.
I cant imagine those nylon gears making 10 laps with spring pressure (force). Back in the 70s a friend parked his Ford truck at home. The next day it wouldnt start. When i got into it and i did it in the street in front of his house. The nylon had come off and the chain drooped down so far the crank gear wouldnt touch it. I never checked to see if it bent any valves I put it back together and he drove it.
No, I'm serious. The nylon gear was quite durable when new. I used one in the 302" Trans-Am engine in my Camaro. It was years of heat that destroyed the gear. Not valve spring pressure or RPM.
We built quite a few Trans-Am engines with nylon gears and never had an failure.
I can dig out the GM engineering recommendation of the nylon gear for competition if you need to see it.
Which is better then the 75K mile timing belt on most Honda’s.
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
[QUOTE=SWCDuke;1598743450]This nylon tooth cam sprocket set has not been manufactured for decades.[/QUOTE
I was surprised to pull out a pretty decent looking nylon toothed cam sprocket out of my 327 out of my '65 last year. No idea how long it had been in there, as the engine was not all original, but the nylon looked good. The chain was stretched beyond reuse, not that I was going to reuse it anyways. I hadn't thought about a nylon cam sprocket in decades myself.
That's the salient point. Racing engines that got rebuilt frequently likely got new timing sets. That's a lot different than a road engine where the timing set should last the life of the engine, but decades of thermal cycles degrade the nylon material, make it brittle and prone to failure.
It's a moot point since it's unlikely to find one of these nylon gear sets. Even if you do, don't get sucked into the "NOS" argument. Walk away. Either the current Cloyes OE replacement truck roller or passenger car silent chain is good for at least 150K miles. And 25 bucks or less is unbelievably low. I cringe at the cost of replacing the chain and sprockets for a contemporaneous Porsche OHC flat six or a Ferrari V-12.
No, not necessary. Thanks, though. I'm just surprised by the GM recommendation......
Two years ago I helped a friend reseal the 61,000 mile original engine in his '69 GTO. the engine was like new inside, so it was just a gasket and seal job. The timing chain was tight enough, however, every nylon tooth on the cam gear had crystallized with age and was ready to fail. So it wasn't a mileage issue, but an age and out-gassing issue that would have caused a failure. We went with a stock link-type steel set.
