Sound Proofing
I have been doing some research on-line about car sound proofing.
The experts are saying that you need 2 layers of sound deadening material before the carpet is installed.
One layer must be a MLV vinyl material (mat )and the other material what is most commonly used.
The experts are saying both layers must be used to be effective and of course 100% coverage including the firewall, roof and doors.
The vinyl material is needed for the outside noise barrier and the other material for inside noise like rattles etc.
Have you any knowledge of this 3 layer soundproofing barrier of vinyl material, standard material and carpet?
Lou
Cheers,
Richard
At some point the area of diminishing returns is reached and you can spend a crap load of time and money for ever smaller benefits. One layer of sound deadener underneath factory carpet may get you 85% of the way there for 40% of the cost and a lot less aggravation.
As I understand it, the game today in that world is in the wires that connect the various pieces in a system together. They get thousands of dollars per meter (of course) for these things. Personally, most of the electrons I ever interviewed don't have a preference for silver/gold alloy over copper/zinc/molybdenum wires, but you just never know, right?
Cheers,
Richard
Cheers,
Richard
Anyway, I suppose if you are building a recording studio and have long runs of wires you would go for OFC, so if OFC will make your 100'+ runs last longer/sound "better", I say go for it.
Funny, somehow, the guys at Motown made pretty good tunes back then with those old wires, old instruments, and those obsolete tube recording devices in a fairly small and somewhat-dead room. Must have been the talent, I guess, as the wires were pretty much whatever was around in the '50's and '60's.
This is obviously a "discussion" with little or no possible resolution. What I can tell you from being in that business for a long time is that after being fortunate enough to listen to pretty much every good speaker made back in the day--yes, it was a long time ago--I learned that box speakers add to the reproduced sound and planer speakers do not. The downside of this is that you need to buy pretty good stuff if you buy planer speakers as you basically hear what you provide it.
My "fav" speakers from college--REALLY BAD! I was pretty embarrassed by my lack of understanding back then as I THOUGHT I knew what I was doing until I had the opportunity to really listen in my shop for as long as I wanted to in every possible configuration. That is how I really learned what the business was all about. I had instruments there as well that I could play to compare to the reproduced sounds, and of course we went to many concerts of ALL kinds of music. Part of the learning process--I still do not "appreciate" opera...but I learned a lot by going.
Other than that, the most expensive items I sold mostly broke--Sequerra, Audio Research, Stax, Linn-Sondek, Nakamichi, etc., but most of the manufacturers were pretty good at fixing DOA or broke- in-1-day items.
Enough. Back to Corvettes!
Cheers,
Richard
