[C2] Differential Leak ?
Old Jun 4, 2019 | 09:42 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Default Differential Leak ?
I have a clear, viscous, greasy fluid dripping onto the hood of the Thunderbird as it sits under the 63 coupe on the lift...its prob a teaspoon full the two times I've found it. It doesn't look or smell like rear end lube. I can see the T-Bird's red paint right through the stuff..
The car had zerkless U-joints installed last summer, do these things sling a little goo after a while ? The DS inboard half-shaft U-joint looks a little damp...
I'll check the differential fluid later today but, again, this fluid doesn't look like typical rear end lube.
Old Jun 4, 2019 | 10:15 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
If it's not 90 weight..........it wouldn't be the pinion seal.....Any chance is could be running down the DS from the trany.......Your question about the U-joints.......????
Old Jun 4, 2019 | 10:29 AM
Frankie the Fink
Army
I'm gonna drop the spare tire tub tonight and clean everything off and check the fluid....I'm hoping its just the differential cover gasket and not a pinion or axle leak. I checked the torque on the rear cover and those bolts are really tight...
Old Jun 4, 2019 | 10:35 AM
pop23235's Avatar
pop23235
Differential oil has a unique odor. First leak is traditionally engine oil, followed by transmission oil. Diff and u joints, not so much. If you park in the same orientation, can you verify the area it drips from? May be Corvette doesn’t like FoMoCo on it’s turf.
Old Jun 4, 2019 | 10:43 AM
426 Hemi's Avatar
426 Hemi
I had a heck of a time getting the 63 fill plug to seal. I used thread tape. And if I'm thinking right the gasket from a Cummins diesel oil plug. Had to trim the ID a little.
Old Jun 4, 2019 | 10:58 AM
MikeM's Avatar
MikeM
Maybe one of these has give out on ya'?
Old Jun 4, 2019 | 11:06 AM
DansYellow66's Avatar
DansYellow66
I do see u-joints sling excess lube from the caps but it's usually more dark and grease like. Could it be condensation dripping from your exhaust pipes?
Old Jun 4, 2019 | 11:32 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Didn't your lift come with drip trays??
Mike: What in the hell are those things in the pic?
Doug
Old Jun 4, 2019 | 11:57 AM
GTOguy's Avatar
GTOguy
I hope it's not brake fluid! Seriously, Frank, if it were gear oil from the trans or the rear end, you could tell.....the stuff stinks and is greenish yellow. And THICK. U-joint grease could be more likely, as it is odorless and in hot weather, can run. Let's hope that's the culprit. Personally, I just think the SWC is marking it's territory and pissing on the T-Bird deliberately.
Old Jun 4, 2019 | 12:01 PM
MikeM's Avatar
MikeM
Doug
Dzus fasteners. Comes in very handy for quick disassembly/reassembly of cars that go through weekly tear downs. A must have for quick service in the pits and driveway warriors that want to save time..
Old Jun 4, 2019 | 12:13 PM
tuxnharley's Avatar
tuxnharley
If it was regular brake fluid it would be eating away the paint. Any chance there is DOT 5 (silicon) brake fluid in that thing? The description sure sounds like that stuff.
Old Jun 4, 2019 | 01:12 PM
smacota1's Avatar
smacota1
It has been years since I have even thought or heard about Dzus fastners. Cool pics though!
Old Jun 4, 2019 | 01:31 PM
lonzoo's Avatar
lonzoo
Leaking Shock Absorber??
Old Jun 4, 2019 | 01:52 PM
Frankie the Fink
Army
Yes I have drip trays (I've repositioned them now to cover the leak, no, definitely not brake fluid as its been DOT-3 for years and would have flat eaten T-Bird paint and the differential is topped off or very close to it maybe 1/8" below the fill plug hole. Dry under the pinion seal, dry under the axle flanges and and around the fill plug. There was some dampness along the bottom of the case and around the bottom two bolts. Nothing blowing back from the transmission/engine area.
Cleaned everything off real good and will check for drips tomorrow, if nothing, I'll take it for a good ride and park it and check again. Not shock absorber or the U-joints -- I can see some of the U-joint grease and its a medium-bodied greenish-gray grease, not clear syrupy fluid.
I'll get back with whatever I find out. Gads I don't want to mess with that differential now that I've refreshed my memory on how it attaches to things.
Old Jun 4, 2019 | 02:49 PM
GTOguy's Avatar
GTOguy
Frank, in hot weather I have seen wheel bearing/u-joint grease 'sweat' like old fashioned peanut butter and drop clear drops of oil....this may be the case. Ever open up a tin of grease and see a small pool of liquid in it on a hot day? This could be what's happening. I hear you on the rear end....that white '66 I was looking at really hard needed the entire rear end rebuilt.....and when I saw how it was assembled and installed, I felt really good hopping back in my solid axle and motoring off!
Old Jun 4, 2019 | 02:57 PM
Frankie the Fink
Army
I hear ya Jeff. I'll take the car on a 25 mile run tomorrow, park it on the lift and see what oozes out....its almost like I have to get the driveline up to a certain temp or perhaps get the fluids sloshing around real good before this happens; we'll see..
Old Jun 4, 2019 | 03:33 PM
pop23235's Avatar
pop23235
Your lift cylinder leaking?
To Differential Leak ?
Old Jun 4, 2019 | 03:58 PM
GTOguy's Avatar
GTOguy
Now there's an out-of-the-box idea. THAT would be something.....and the hydraulic oil is honey colored 10 weight with no odor at all.....
Old Jun 4, 2019 | 04:22 PM
Frankie the Fink
Army
Hmmm.....now I have to rip the bottom hard covers off the ramp to look - do it tomorrow after the rainstorms..
Old Jun 4, 2019 | 04:30 PM
AZDoug's Avatar
AZDoug
You should be able to spot a drip under the rails. BTW, there should only be one cylinder, under one rail.
Doug
