[C2] Small Cap HEI Distributor
Old Dec 25, 2019 | 11:06 PM
99Silverbullet's Avatar
99Silverbullet
CI 8 & 9 Veteran
C2 of Year Finalist (performance mods) 2019
St. Jude Donor '07-'08
Default Small Cap HEI Distributor
Thinking of swapping my stock style distributor with pertronix ignitor to an hei unit to see if there is any difference.
My intake is a 3x2 intake so the normal large hei unit wont work, as i tried one in the past and the rear vacuum port is in the way.
I read somewhere there is someone that will convert your stock style small cap distributor to an hei unit, where can i find him?
Also is there a company that already sells one for a sb/bb gm engine?
I did some searching online and the ones that look to be small cap dont advertise it as being one.
Im running a stock style with no tach drive.
Any leads would be great. Thanks!
Old Dec 26, 2019 | 09:11 AM
Robert61's Avatar
Robert61
This is what I was telling you about except I used the flat top cap. Use this dist with an HEI module. MSD makes a ready to run distributor but it has a circuit board with a ton of electronics and I've seen them go out. With this 8361 you could use a 6al box but I just used the HEI coil instead so if they are out on the road and it fails they can just plug another readily available one in.
This looks like a good price.
https://www.ebay.com/itm/Distributor...gAAOSw3t1d6rw7
Old Dec 26, 2019 | 10:08 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Reading on here I doubt you will notice a difference unless your stock one is wore out and needs rebuilt anyhow. I would think the only time you will know a difference is on a dyno in a RPM range you never drive in.
Old Dec 26, 2019 | 10:20 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Unless you need to eliminate an external ignition coil for some reason you'll see no benefit worth mentioning; certainly not a "seat of the pants" improvement over the Pertronix. Take particular note of the chart in this article:
https://www.hotrod.com/articles/ccrp...formance-test/
The myth of a hotter spark is right up there with those 45,000 volt systems...
In a properly tuned engine the spark is gonna cross the gap at the typical 15,000-20,000 volt range...
Potential energy spark works as soon as its high enough to jump the gap; it doesn't "build up" to some maximum spec to fire.
Old Dec 26, 2019 | 12:05 PM
plaidside's Avatar
plaidside
A properly tuned engine without worn ignition components or lean or rich mixtures should only need 8 - 12KV to overcome total resistance in the secondary circuit.
That includes, rotor to cap segment gap, ignition wire resistance and spark plug gap. Mixture will play a role in the resistance of the air gap of a spark plug, richer, less resistance and leaner higher resistance. When mixtures in the 70's were leaned out to a point of almost not running, GM went to large gaps, Oldsmobile went up to .080", to expose more spark to the mixture to ignite the fuel air charge. Those larger gaps needed more voltage to get across the gap and maintain the spark enough to fire the mixture and keep it burning.
This is why HEI was needed. It has the potential for over 40KV and the primary circuit only had 1/2 ohm resistance, when using Ohm's law it could pull up to 24 amps!
As Frankie has stated all this 45K stuff is not needed for our old cars. As this scope pattern will show you, that is my 61 fuelie pattern at idle, it is using under 10KV. The remainder of the voltage produced dissipates to ground. I am using the 0-25KV scale.
The extra voltage that the coil can produce is used during acceleration.
Joe
Here is a wire removed to show the potential voltage output of my stock GM coil, note it is over 25KV!
Old Dec 26, 2019 | 12:17 PM
SWCDuke's Avatar
SWCDuke
If your single point distributor is optimized there is no difference. I've run both TI and a "blueprinted" single point on my 340 HP SWC. and the only difference is that TI failed without warning twice in 50K miles... good riddance to it.
...suggest you search for threads started by me, download the distributor blueprint overhaul and breaker points article. It's a simple job to optimize the clearances on a single point and optimize the spark advance map if the shaft bushings are okay, and any competent engine shop should be able to replace them and hone to .001" clearance.
The distributor is the most overlooked component on the engine, and most out there have probably never had the above treatment, but a properly functioning distributor is absolutely necessary to achieving peak output and fuel economy. The single point rarely fails suddenly like electronic ignition systems, but they slowly degrade with time. Dwell angle timing should be checked every 10-15K miles or few years, and an overhaul should be done every 15-20 years in typical low annual mileage accumulation vintage car service. The primary unseen "degradation" is due to the upper bushing grease well drying out over mileage and time.
Duke
Old Dec 26, 2019 | 09:39 PM
R66's Avatar
R66
So, don't they still use an external coil? I guess the module just increases the voltage to the coil? I really don't see the advantage over a magnetic reluctor pickup with an external box similar to the old chrysler ignitions also made for Chevy by Malory and Accel. I have a couple in a box from racing days.
Just asking?
Ron
Old Dec 26, 2019 | 11:28 PM
John S 1961's Avatar
John S 1961
Msd makes these old engines run nice and clean.
Old Dec 27, 2019 | 06:22 AM
Frankie the Fink
Army
The coil is in the cap on the HEI, and, a Breakerless SE will give much of the same advantages, look completely stock and not "ugly up" your engine bay...and uses your perfectly fitting original distributor.
I think the OP is attempting to come up with "....an ingenious solution to a non-existent problem" to quote Jeff Cooper.
Old Dec 27, 2019 | 06:39 AM
Gavin65's Avatar
Gavin65
Try DUI, Davis Unified Ignition, I believe they make a small cap HEI
Old Dec 27, 2019 | 09:29 AM
Avispa's Avatar
Avispa
It would be interesting if one of you guys with a scope would take some HV screen shots during cranking to compare points and any EI system. The focus seems be on how the motor performs once it's running. That there isn't much difference between points and EI is old news. Starting, especially when cold, is another matter. Even the grouchy old man that did a lot of my restoration work, who'd practically sledgehammer anything that didn't come in a GM box, asked me why cars seem to start so much easier and get to a stable idle faster with EI. They seem to, and MSD for one, is really noticeable. Even when points are used as a trigger. I have my own theory, but no proof. Any takers?
Old Dec 27, 2019 | 11:04 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
There's an Ignition sticky in C3 Tech that will address some of your questions, and point out some of the Ignition old wives' tales that are slow to die.
Old Dec 27, 2019 | 12:40 PM
Avispa's Avatar
Avispa
Thanks for that. Checked out the sticky and it's really good. Didn't see the particular issue discussed, namely, we assume that the condenser always breaks the arc across the points fast enough to avoid substantial energy loss in the point arc. At any speed above a few hundred RPM the scope proves this is the case. What about at cranking speed? Just a hunch, but points act like more of the coil energy gets burned in the arc at cranking speeds because of slow air gap expansion at the points. Does it? EI switching speed is related to how fast the electronic circuit element opens rather than a mechanical switch that arcs, so the distributor speed wouldn't affect the observable switch response at the coil.
Old Dec 27, 2019 | 01:49 PM
VaCat33's Avatar
VaCat33
The threads from which I learn something...which is practically all of them.
Thanks to all and Happy New Year.
Jim
Old Dec 27, 2019 | 03:10 PM
sixtysixtom's Avatar
sixtysixtom
Look up Dave’s small cap HEI’s. He can convert your original distributor to hei.
Old Dec 27, 2019 | 05:16 PM
69427's Avatar
69427
You are correct. Twelve volts (battery/alternator voltage) isn't enough to jump the points gap, so that tells us the voltage must be higher than twelve volts across the points when it arcs. That "higher than 12 volts" has to come from somewhere other than the battery/alternator, and that source is the energy stored in the coil's magnetic field. While the arc is happening, we're seeing the coil's magnetic field diminish. Once the points separate enough to "kill" the arc, the collapsing remainder of the magnetic field (the remaining energy in the coil) will build up a voltage across the secondary windings until the voltage builds up high enough to ionize/breakdown the A/F mixture in the plug gap. The energy dumped into the plug gap is then the coil energy (put in during dwell) minus the points gap arc energy that was wasted.
You are correct in your last comment as well. Electronic ignitions don't use a capacitor/condensor on the switch (ie: the transistor). This gives two improvements: There is less coil energy wasted, as there's no arcing anywhere in the primary circuit, and the coil is "allowed" to build more secondary voltage (if needed) due to the faster shutoff of the primary current. (There's a formula to explain this in case anyone is having a geek curiosity moment.)
Old Dec 27, 2019 | 06:11 PM
Avispa's Avatar
Avispa
Thanks for that, too. So there's an actual reason for EI systems to make an old timer start easier at least. You've probably been following the never ending points / EI discussions in this forum, most of which don't shed any more light than points are good enough, which for these cars they are. Finally an actual improvement in something, not trivial, with some theory to back it up. So if the OP wants to stick a modified HEI distributor under his shielding, go for it. There is a reason even if there are other solutions.
To Small Cap HEI Distributor
Old Dec 27, 2019 | 07:53 PM
69427's Avatar
69427
I converted my stock distributor years ago to drive a stock HEI module and the stock can coil. Everything fits under the stock shielding, the parts are stone reliable, and I get great plug life with the extra energy of this system.
Old Dec 28, 2019 | 01:09 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Well 99 I think I will let you do the shopping for a small cap HEI with remote coil as there are so many choices. But it is such a simple conversion with only 1 wire to the distributor for power as it grounds through the body/case to the engine/manifold. Of course the the coil will have 2 wires but you should have a coil like that now with the Pertronix. Now the timing curve is still set with weights and springs and who know what kind of timing curve an aftermarket distributor will have? But myself I wouldn't pay over $100 for a small cap HEI and they make a great solution to points or whatever is in use. In fact they make a great tool box spare for troubleshooting also. Cheap enough to buy two.
Good luck.
Oh BTW you should bypass the old resistance wire to the coil (or ballast resistor if you have one) as its no longer needed.
Old Dec 28, 2019 | 01:31 PM
GTOguy's Avatar
GTOguy
Duke
THIS^^^. Lars even ran a side by side dyno test on a 302 Ford and had zero difference in HP and TQ when he switched the Buck Rogers Special Zapper back to the stock points distributor. There are more downsides with electronic ignition systems than points. ALL of my mechanic friends agree with this, coming from the same background of tow-ins and roadside stall-outs. NONE of my non-mechanic friends believe in points, and prefer to screw around with their fiddly electronic distributors that always seem to be on the fritz. To the OP: I would leave your Pertronix in place if it's working, and when it dies, I would re-install points. If you're bored and simply looking for something to 'fix', I recommend detailing the car or engine compartment.
