Lot's of parts to make this conversion, their price was $6000 all in. Then probably another $1000 for installation. TREMEC qualified it all with, "this is not a bolt in, there may be some modifications needed to fit". Could be interesting, but I'd sure like to have that 5 spd.
This will be my last attempt on this thread and then I am done: you are toying with spending $7000 for a modify-to-fit TREMEC system to get an overdrive, but the prospect of literally bolting in an 833 with OD for under $1k in an afternoon and enjoying a .71 overdrive ratio is off the table? You certainly think differently than I do, Sir. Spending 7 times more for an item that won't bolt in.....whatever.
I checked and sent an email to the seller on EBAY. Then checked on that model Chrysler 833 and it's a 4 spd where 4th gear is the overdrive, so really a 3 spd with overdrive, not what I wanted.
IIRC the OP had originally stated that his objective was not only an OD gear but also equally spaced ratios.
Perhaps cost is not his primary objective. After all, none of these swaps ever really have a realistic pay back period. After that it’s just a matter of degree!
Thanks for the reply, I appreciate knowing you at least checked it out. It IS a 4 speed, but yes, with the compromise of using third as the 'new' overdrive gear. What you get is much larger gaps between the gears than a 'performance' box, ok on a passenger car or truck, but agreeably not as desirable on a car like a Corvette. I brought it into the equation because it was a direct-fit bolt in, cheap, and that your Hemi car can deal with the large gaps between the gears with it's torque output. If cost were no issue, without question the 5 speed Tremec is the better choice. For cheapskates like me, the 833 OD makes a lot of sense. Everything is a compromise, be it in funds or gear spacing. I love your car and am delighted that you have its history and are making the most out of enjoying it!
Stock market turned the corner today and hopefully next week will start working it's way back up. If so I'm going to bite the bullet. The way I look at these things is: at my age , 76, if I don't do it now something may happen where I can't drive a clutch and then what would I do with my toy cars. 5 spd Porsche 911, the Hemi/Vette, my 4 spd Classic Mini Cooper and even my 5 spd pickup.
Got to look at that chassis this morn , unfortunately forgot my camera. However got to talk to the owner and he used a Hotheads adapter with a Chevy bellhousing and a Chevy Tremec TKO. Looked like a very simple thick aluminum adapter plate drilled to fit both patterns. If you are still interested then you should contact Hotheads.
Perhaps there is a possible business in "Reverse Morgage car loans" for vintage/classic cars. It would carry all the usual insurance restrictions/etc. and when you pass away, they get the car if you choose not to pay back the loan prior to passing.
I have a couple Corvettes with no one to leave them to.
Well that's what I got to thinking this weekend. Since I got divorced and retired at age 72 I've been playing with my cars, playing golf and playing around in my motor home. Now I have and old dog (16) and a cat, they tend to get under my feet sometimes and I never thought of falling down and breaking something to where I couldn't push in the clutch. I actually broke my left ankle 50 years ago and leant to drive the old corvette without a clutch until my ankle recovered.
So I'm going to get the TREMEC and drive the Hemi/Vette at 2000 rpm on the freeway, drive the Mini at some autoxes and the Porsche at a few track days this summer.
I agree 100%. I somehow pictured Kolsen as about 46 years of age, judging by what he drives and his lifestyle. At 76, it's time to do whatever the heck you want to do!!
Talked to TREMEC distributor in Caldwell Id. Several guys in the shop where going to sit down and try to figure out how to do this. Then this afternoon I get a text message from them saying they can't do that with a Chrysler unless they custom build the bell housing for about $!200.
So I called the shop here who will do the install and they have a MOPAR guy. We talked and he pointed out another place that has an overdrive for my stock 833 Chysler Transmission.
One step forward and two back but then this is a unique car anyway.
Give me Call we have the correct set up behind all the Mopar engines. I even make Big Block and small block bells.
Well I did get a response back from TREMEC and talked to Doug this morning. He clarified that I want the TKO model. So after playing with numbers again and reviewing all your inputs, which I appreciate, I'm going for the TKO -500 with the 0.68 over drive and will have them change first gear to the 2.87. For now I'll stay with the stock rear end of 3.23 but will keep the 3.73 ring and pinion as an option.
I had an interesting talk to the shop owner Denny Finn over in Woodburn, Or. When I showed him the dyno chart I got on the car a couple years ago we talked about in the old days they advertised Gross Horsepower and SAE. Then the numbers I got on the dyno where wheel horsepower. The dyno showed 239 hp and 310 ft/lbs, compared to the advertised 325 hp and 430 ft/lbs. As you can see I was looking for some way to get more grunt out of this old Hemi. For now I'll see how it feels with the TREMEC and save the 3.73 for later.
I have been dealing with Silver Sport for a TKO-500. I wanted them to change the 5th gear from 0.68 to 0.82. The reason is with my differential ratio of 3.08 and a 1st gear of 3.27 gives me the optimal launch ratio (10.07). I feel the 0.68 5th gear in the TKO-500 is too tall for my high horsepower motor. Sliver Sport wants to sell me the TKO-600 with a 2.87 1st gear which puts my launch ratio at 8.8, not as desirable launch ratio, has the 0.82 5th gear.
Feedback from Silver Sport;
" The gearing between the 500/600 models is not interchangeable."
My questions;
Is Doug with Silver Sport or Tremec.
And I'm still waiting to get in the shop, phew! Glad I wasn't in a hurry. They have the transmission just waiting for space to get into so they can start. That's now looks like the first of May.
I have the L76 with a 3:55 rear end, and I still feel the need for a fifth gear when just cruising along at 45-75. The only thing holding me back is the lock on my wallet that keeps telling me not at this time. My wife agrees with the wallet. I put a Miata five speed transmission in my MGB and it changed the whole personality of the car. It was fun to drive again, I guess the older you get, the more gears you need.
