[C2] Aluminum 327 Intake Manifold (3890490) - Can it be saved?
Can this be returned to original? I have had this laying around for 25 or so years. Not sure how I came to own it...and I had no part in its butchery. Question is, can new aluminum pieces be welded back inside and can this function as new? Why would this have been done in the first place? Thanks for any help........
Chopped Aluminum Intake
Received 1,922 Likes
Looks like someone thought that might "improve" this divorced choke dual plane into some kind of bubbafied hybrid stepped single plane.
Yes, a good aluminum welder could restore it, but I'm not sure it would be worth it.
Milling out the divider is an old hotrodder trick. It was to move the power band of the manifold up a bit. FWIW, L88 intakes are just L72 manifolds with the divider removed by the factory.
So, as it is, I should be able to bolt it onto my 66 327 300 and be good to go? Does it add much HP?
It was done to do 2 things, increase upper rpm power, and improve the air fuel balance between each side of the engine. The way it was originally made each section fed 2 cylinders on each bank. By opening it it allowed all of the flow from the carb to be more evenly distributed. How well that worked I can't say. Most carbs idle and perform better with a 4 hole spacer with the correct gasket on an open plenum, it improves the signal to the Venturi. I would guess if you installed it as is you wouldn't notice a huge difference. I know it was done a lot back then. I never did it, I used single plane manifolds.
Joemac8 (05-17-2020)
Received 2,351 Likes
It was done to do 2 things, increase upper rpm power, and improve the air fuel balance between side seats of the engine. The way it was originally made each section fed 2 cylinders on each bank. By opening it it allowed all of the flow from the carb to be more evenly distributed. How well that worked I can't say. Most carbs idle and perform better with a 4 hole spacer with the correct gasket on an open plenum, it improves the signal to the Venturi. I would guess if you installed it as is you wouldn't notice a huge difference. I know it was done a lot back then. I never did it, I used single plane manifolds.
I use to build a race engine for a friend that had one of these. Never noticed any difference. It wouldn't make the manifold completely divided but would get you closer. Myself I would run it as is. Years ago ever hot rod magazine had articles about removing the wall to improve performance. If I remember correctly this is about 1/2" thick.
Sartana (05-17-2020)
Received 1,845 Likes
