[C2] Ignition "upgrade" options?
What Distributor and Ignition System is "The Best" for my Street Car?
By Lars
The "best" distributor and ignition system to use is the one you're comfortable with setting up and tuning. Any two systems, set up with the same timing curve, will perform virtually the same on a mild street car. For a mild performance street-driven car, I also highly recommend getting one with vacuum advance, and there are many to choose from.
To demonstrate the equivalent performance from one system to another, I actually did dyno testing at Westech with Hot Rod Magazine several years ago. Here are the results that I've published here on the Forum before:
A few years ago, I did a bit of dyno testing at Westech Performance with Matt King, former Editor of Hot Rod Magazine. We tested several of the aftermarket capacitive discharge systems and top-end distributors against a plain ol' points-type distributor. The engine was a nice street-type 302 Ford putting out 370 horsepower. We tested ignition systems and distributors from Crane, MSD, and Mallory, making sure that each distributor had exactly the same centrifugal advance curve in it with the same total timing. Once these nice aftermarket systems were tested, we went out in the parking lot and pulled the stock points distributor out of Matt King's crap Falcon: We set it up with the same advance curve on Westech's distributor machine and dropped it in the 302 test engine. Results: There was no change in the engine's performance whatsoever at any point on the rpm curve. Absolutely none.
So here's the recommendation: Run whatever distributor you're comfortable with tuning and curving, and set it up with a good performance curve to match the needs of your engine. Whether this is a tach-drive points-type distributor, an HEI, or an MSD ProBillet is completely irrelevant as long as you can get it set up right. Buy something of good quality that is easily tunable, and make sure you run vacuum advance on any street-driven engine. Trigger boxes, amplifiers, huge coils, and fancy systems will not gain you anything on a moderate performance street engine - spend your time getting the curve and total timing set up right on whatever system you use - that's where the power is.
Here's Matt King (black shirt) and me setting up the points distributor from his Falcon in the 302 test engine to run head-to-head against the top-end capacitive discharge systems:
Notice that we even used the old crap wires out of Matt's Falcon for the testing:
Here's the same engine with one of the fancy aftermarket systems in it and some really nice red plug wires:
Famed Westech Dyno Operator Steve Brule (left) overseeing the testing:
Results: Absolutely no change in power whatsoever from one system to another, as long as the advance curve remained the same (note Matt King's astounded "I can't freakin believe it" expression):
Here is my own 407 that's in my '64 Roadster on the engine dyno. It puts out 500 hp with 500 ft/lbs torque. I run the stock tach drive distributor with a nice set of points and an aggressive advance curve which nails the optimum total timing for max power and performance. All you need is to get the curve right and the total timing right in a system you know how to tune. Everything else is fluff:
Running the additional benefit from vacuum advance (limited to 12 degrees) hooked up to manifold vacuum makes a huge difference in idle quality and engine operating temperature of this big-cammed, solid roller engine:
Lars
but I am still scratching my head on how you figure out the right
advance curve for a given engine, and then how you dial in the distributer
to that?
For example, I have the typical 383 small block chevy that is supposedly
going to put out about 430 gross hp. Spirited street driving and no racing
on the track. Sniper fuel injection
How would I know what the advance curve should be and how do I get there?
Glenn in San Diego
https://www.holley.com/products/fuel...park_ignition/
From what I can tell, that distributor and ignition box allow you to control your ignition curve through the Sniper ECU. If it works anything like the Terminator ECU I'm running on my Suburban, it makes tuning timing, fuel curve, etc all very simple.
but tach drive?
Glenn
With regard to the current state of my car, Im going to leave it as-is for now and see what tips I can pick up watching over the shoulder of the tech as it gets tuned.
This is an interesting discussion and all points are good. Yes, GM went to an electronics system and away from points and condensers. But they addressed heat issues to make them reliable. Some of the after market electronics manufacture make good stuff and some have gone off shore to source products and unfortunate compromised their quality.
I own and operate a certified airplane. The FAA controls the acceptance of aftermarket parts that are deemed suitable for use in a certified airplane. It is telling that the FAA mandates the use of an 80+ year old designed ignition system called a magneto. Airplanes have two ignition systems that are independent of the ships electrical system and them selves. Meaning, you can have a complete electrical failure plus one magneto fail and the engine will still run. The FAA has been approached by electronic ignition manufactures asking to allow their system to replace magnetos. At this time one electronic system is allowed but the ship must have at least one magneto. If you buy a $1M new piston powered airplane it will come with elector-mechanical magnetos.
My point is, I'm a points and condenser guy. It is simple, reliable and I can fix it on the fly, well on the ground... Al
Reliability and higher energy are plusses for performance engines and helping keep rich mixture/fouled plugs firing sufficiently.
