[C2] NOM Engine ID help?
Old Jul 11, 2020 | 09:30 PM
SJW's Avatar
SJW
Default NOM Engine ID help?
Hi, all.
Wondering what can be learned about the origins of this block:
Many thanks in advance.
Live well,
SJW
Old Jul 11, 2020 | 10:05 PM
oldskydog's Avatar
oldskydog
Original 250 hp engine for 63 Corvette 11290
Old Jul 11, 2020 | 10:26 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I agree with oldskydog. Flint block, approx March 12. 327/250HP. Dennis
Old Jul 11, 2020 | 10:46 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Engine looks like it has been decked, but the machine operator very graciously avoided decking the important part of the pad. GOOD JOB !!!
Old Jul 12, 2020 | 08:46 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
All, While we are on the OP's thread......Can you confirm this engine number:
F0322HC
Flint
March
22nd Day
HC??
Thanks everyone
Old Jul 12, 2020 | 09:18 AM
gbvette62's Avatar
gbvette62
F0322HC
Flint
March
22nd Day
HC??
Thanks everyone
HC was used from 65-69. Below are the applications. It was not a Corvette engine.
1) 65 - 327/250 4bbl and a Powerglide in a passenger car (full size, Nova, Chevelle, El Camino )
2) 66 - 327/275 4bbl and a Powerglide in a passenger car
3) 67 - 327/275 4bbl and a Powerglide in a passenger car
4) 68 - 327/275 4bbl and a Powerglide in a passenger car
5) 69 - 350/250 2bbl and a manual trans in a (Chevelle, El Camino, Nova, Camaro)
To identify it further, we'd need the casting number and casting date, from the rear of the block. If there's a VIN on the pad, that might help too.
Old Jul 12, 2020 | 09:54 AM
dcamick's Avatar
dcamick
Glenn,
Thank you!......as I expected..(at least with the Powerglide)
Casting # rear of Block 3782870
Old Jul 12, 2020 | 11:17 AM
SJW's Avatar
SJW
Thanks for the replies, all. Yes, it does appear that somebody carefully decked it.
If you own VIN 3111290, I know where your engine block is.
But, it doesn't look like it did when it left the factory:
Live well,
SJW
Old Jul 12, 2020 | 12:10 PM
gbvette62's Avatar
gbvette62
Glenn,
That makes it pretty easy then. Since the 870 block was used for 327's from 62-65, it makes your HC engine a 65 327/250 with a Powerglide, from some sort of Chevy passenger car. As a 250 horse passenger car engine, it probably doesn't have a VIN derivative, since at that time only high horse passenger car engines, and Corvette engines, were getting VIN stamps.
Old Jul 12, 2020 | 04:02 PM
dcamick's Avatar
dcamick
Glenn,
The previous owner had no idea about engine history. He only stated that the motor was changed......My engine has the High Double Hump Heads. I wonder if my current heads were original to the engine born with the car???? I may be wrong, but I don't think High Double Hump Heads where equipped on a 327/250 engine....
Interesting read: https://www.hotrod.com/articles/ctrp...ylinder-heads/
Doug
Old Jul 12, 2020 | 04:31 PM
kingwoodvette's Avatar
kingwoodvette
Glenn,
Doug
That’s pretty much like my 63 NOM. It is a 65 HC that over the years been been pretty much configured as a 65 L79- heads, domed pistons, intake, cam and 2818 Holley carb. And of course the ever popular finned valve covers and proper air filter. As we often say it’s hard to know what’s been done to the old engines-original or NOM.
Old Jul 12, 2020 | 05:13 PM
GTOguy's Avatar
GTOguy
I've never seen an engine pad saved that way during a deck job. Amazing. You can bet if the machinist was diligent enough to save the engine numbers on the pad, the rest of his work was stellar. And he did it with a 250 HP block, too. Impressive.
Old Jul 12, 2020 | 09:27 PM
SJW's Avatar
SJW
I'd have to agree, Jeff. I don't know anything for sure about the engine's internals. My buddy bought the car with a hurt engine, and hired the man who built the engine that's in there now. I'm told that the guy was one of the premier old-school engine builders in the area back then, and that he hung up his wrenches and folded his tent not long after building this one. It runs well.
It's built to look like a 340 horse, but it's not as rowdy as a 340. It's plenty strong enough, and pulls pretty hard with the .370s, but I don't hear solid lifters, and I'm told that the CR was purposely lowered to around 9.5 to make it more streetable on the pump fuel that was available back in '98 when it was built. I'm told it was done with Keith Black hyper-eutectic pistons, but I have no details. As far as I've been able to determine so far, it looks like the entire upper end is 340 hardware. I've verified the intake and exhaust manifolds, and it's fed by an AFB that looks to be at least period-correct. I do know that it's not the born-with carburetor, although there's nothing surprising about that. It had a Holley on it for a number of years.
I rebuilt the distributor for my friend a good many years ago, after it had lunched the tach-drive gears. While I had my dial-back on it as I re-installed the dizzy, I checked out the advance curve, and confirmed that whoever set it up knew what he was doing. It was dialed in just right and the vac can was behaving just as it should. All indications are that the builder knew his craft. It's still running well 22 years later. Next time I have it running with the hood up, I'll put a vacuum gauge on it, then solicit the thoughts of the brain trust here for best guesses about the cam profile.
The block is not original to the car, and I don't know what engine was originally in it. The VIN stamp on the block is only a few units away from the VIN tag on the car, which is pretty cool in a way, although that is of no importance to me. And it probably explains why the machinist took care to not mill the numbers off. The tach has the 6,500 RPM redline, which might suggest that the car came with a 340 in it, but I can't say whether it's the original tach. I'd say there's a fair chance that the entire top end of the engine is original to the car, but I know of no way to determine that 57 years after it was built.
Fun stuff.
Live well,
SJW
Old Jul 12, 2020 | 10:31 PM
Plasticman's Avatar
Plasticman
Recommend looking inside a spark plug hole with a good bore scope. You might be pleasantly surprised with what you see.
On mine, I confirmed the 2.02 intake / 1.6 exhaust valves (by comparing the width of the gap between the 2 valves), and read the ".030" stamped on the top of the pistons, plus the configuration of the piston crowns & valve reliefs.
Plus seeing the overall condition of the chamber.
Plasticman
Old Jul 13, 2020 | 12:53 PM
SJW's Avatar
SJW
Good suggestion. I don't have any immediate plans to pull any of the plugs, but the first time I have one or more of them out, I'll definitely scope the chamber to see what can be determined without pulling a head. Thanks for the thought.
Live well,
SJW
Old Jul 14, 2020 | 08:56 AM
emccomas's Avatar
emccomas
30867S111290 still exists. Here is the current title history.
Old Jul 14, 2020 | 12:52 PM
SJW's Avatar
SJW
So it was still around as recently as 2015, which means it almost surely still exists today. Interesting. Any way to determine if it's a SWC or ragtop?
Thanks for researching and posting this, Ed.
Live well,
SJW
To NOM Engine ID help?
Old Jul 14, 2020 | 01:02 PM
17outs's Avatar
17outs
Which site are you using for this?
Old Jul 14, 2020 | 03:38 PM
gbvette62's Avatar
gbvette62
Live well,
SJW
The 4th digit in the VIN is a "6", which indicates it's a convertible. A coupe would be a "3".
Old Jul 14, 2020 | 03:46 PM
silver837's Avatar
silver837
637 in the vin # denotes a convertible. 837 is the # for a coupe.
