engine code
Old Jul 29, 2020 | 06:13 PM
shiky's Avatar
shiky
Default engine code
Can someone please try and decode this engine no for me ths is all i can see V0508 HV
THANKS
Old Jul 29, 2020 | 06:34 PM
leif.anderson93's Avatar
leif.anderson93
You can use the Lime Book at the top of this page in the "sticky" section to decode this for you.
P.S. This is your third post in two days and you haven't thanked one person for their help yet. Keep it up and nobody will help you in the future.
Old Jul 29, 2020 | 06:52 PM
MelWff's Avatar
MelWff
Flint May 8th
Old Jul 29, 2020 | 06:59 PM
shiky's Avatar
shiky
thanks very much just aquired this corvette from a friend of a friend.sticker on breatheresays 327 350 hp just wasnt sure.thanks again
Old Jul 29, 2020 | 07:00 PM
shiky's Avatar
shiky
i am so sorry i am not used to this site believe i will thank everyone thats even responds to me thanks for the heads up
Old Jul 29, 2020 | 08:09 PM
provette67's Avatar
provette67
Not from 1965. If it were from 1965 it would start with an F for Flint. The V for Flint was used starting in 1967. No HV code used in '67 or '68. There is an HV in '69. In '69 it = 350ci 255hp with a 350 turbohydramatic. What is the date on the block?
Old Jul 29, 2020 | 08:31 PM
shiky's Avatar
shiky
THANKS
I do not know where to find engine block date
Old Jul 29, 2020 | 08:39 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
It’s on the back of the block on the flange where the bellhousing/ auto trans attaches to the block. It will be a letter then the day and then the year. Like A 10 6. Or January 10 1966
65GGvert's Avatar
65GGvert
It's a 255hp 350 ci from a 69 passenger car.
Old Jul 29, 2020 | 08:52 PM
leif.anderson93
This...
Old Jul 30, 2020 | 07:39 AM
phil2302's Avatar
phil2302
Did you get your headlights to turn on and roll open / close ?
Old Jul 30, 2020 | 08:09 AM
shiky's Avatar
shiky
Default re headlights
Yes i did thank you i didnt see the separate switch under dash that's how knowledgeable i am
Old Jul 30, 2020 | 08:15 AM
emccomas's Avatar
emccomas
I have to admit that I get a little kick every time someone says "Use the Lime Book in the sticky section at the top of the page".
Regarding the engine, as indicated earlier it is definitely 1967 or later because of the V at the beginning of the engine code.
Does the engine pad also have any other numbers on it. I am curious if this year passenger car engine also had a VIN derivative.
65GGvert's Avatar
65GGvert
Then you should go back to that post and state the follow up. It should not be left hanging for others to keep trying to help when you don't have a problem. Always post the resolution, it will help everyone.
To engine code
