Replacing brake fluid
Popular Reply
1. Dot 3 and Dot 5 should not be used together because they don't mix. But accidently using them together will not result in instant failure or turn everything inside the system to goo. Fact is the law requires that they can be accidently mixed without failure. You should NOT mix it, but if it happens it is simply flushed. It is dirt and petroleum that you don't want in your master cylinder, that's why you are warned to clean the top before opening it.
2. Dot 5 will, in some systems but not all present a different pedal feel, not as hard and sometimes with more travel. This can become a problem when using disparate components, a later master or caliper on an earlier pedal arrangement or unusually large wheel cylinders. On an unmodified system the use of Dot 5 should result in negligible difference in feel. My L78 uses stock components running Dot 5 and the difference is undetectable.
3. Dot 5 is best for cars that sit more than they are used. A braking system filled with Dot 5 will stay fresh indefinitely while 3 will require flushing every so often depending upon climate. And a Dot 3 system that is ignored will eventually rust out and fail. Dot 5 systems can last the life, your life anyway, with the car.
4. Dot 5 will not contaminate fiberglass fenders in the area of the master cylinder. Dot 5 will contaminate a painting field or shop, so think about that when pouring it.
5. Dot 5 can be more difficult to bleed and requires a few extra precautions in that regard. You must pour it very slowly to prevent bubbles and foaming. And you must bleed it slowly and deliberately without "pumping" the pedal. I find gravity bleeding works best.
6. One is not better than the other for all things, so it makes no sense to argue about it in that way. If your car is used often and you flush the system every 3 years or so, great. If you have a collection of different parts from different manufacturers making up your system Dot 3 may be a safer bet. If on the other hand your system is stock, the car will sit far more than used and resides in a humid climate, Dot 5 makes a lot of sense.
Out of 9 cars, the Corvette, Chrysler 300 F and Plymouth Savoy use Dot 5 and the rest are on Dot 3.
Dan
Dan
I just had to replace two calipers last winter and noticed the tags. 15 years ago that was not the case.
The warning tags I've seen allude to some change in EPA regulations which have nothing to do with DOT5 fluid.
PARKER O-ring manufacturer states in their definitive o-ring manual that EPDM will work for both DOT 3/4 and DOT 5. They specify a particular grade that they sell solely to the auto/truck industry for brake applications........and back it up with test results. But if rebuilders choose to use something else for whatever reason ($$) they have to put restrictions on the product.I posted a long reply to this about a year or so ago, and provided details and part numbers, etc, etc. Besides EPDM (EPR rubber family), SBR (styrene butyl rubber) rubber is also used for automotive/truck brake applications within the industry, but it is best suited for DOT 3/4. It shows compatibility with DOT 5 as well, but not as strong as the Parker EPDM material.
For what it's worth.
Larry
Dan
My new invention to speed up the process, a clear soda container, two line (fluid in - air out) and a magnet to stick to the frame.
The brake pedal is hard as a rock, and high and tight, everything works great.
Doug
My Grand Sport vintage racer has DOT5 in the brake system. The pedal is high and firm. The brakes have NEVER let me down and I typically can out brake competitors going into a turn.
Although the fluids are not physically mixing, you have two different systems responding to the same pedal pressure.
DOT5 is tricky. Some use it and have no issues. Others can never get it to work. I've read that even POURING DOT5 fluid quickly can create micro-bubbles, leading to soft pedal.
So my advise is go with one or the other for BOTH systems.
If you choose DOT5, flush before installing it, and handle it very gently, and follow the bleeding instructions carefully.
If you choose DOT3/4, remember that it absorbs as much as 10% of it's volume in water every year... So flush it often (every 2-3 years).
Fred
