surface rust cleaner
Old Mar 6, 2021 | 04:21 PM
rowingone's Avatar
rowingone
Default surface rust cleaner
I have a 1966 BB with manual brakes and the master cylinder has some light surface rust on it . . I think it is plated and has a gold cast to it. Any ideas what to use to get this surface rust off? The calipers have a bit as well.
Old Mar 6, 2021 | 04:41 PM
esema's Avatar
esema
Evapo-Rust. Works awesome. Available lots of places. Use a small paint brush to keep the rust area moist for about 30 minutes and simply wash it off. I used it soak extremely rusty bolts, nuts, etc. in a bucket overnight and in the morning absolutely zero rust.
Amazon Amazon
Old Mar 6, 2021 | 04:45 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
https://www.amazon.com/Evapo-Rust-Or...s%2C228&sr=8-2
Yup. It also comes in a gel you can brush on.
Old Mar 6, 2021 | 04:54 PM
rowingone's Avatar
rowingone
thanks guys . .I will give it a try . .sounds like exactly what I need.
Old Mar 6, 2021 | 05:29 PM
SJW's Avatar
SJW
You won't be disappointed. Evaporust is amazing stuff.
Live well,
SJW
Old Mar 6, 2021 | 08:04 PM
ejboyd5's Avatar
ejboyd5
Evapo-Rust is amazing, but I'm not sure what effect it might have on the yellow anodized finish. You might want to test a small area before committing the entire part to a bath. If the surface rust is not too bad you might try Quick-Glo polish which does a good job of removing rust from other surfaces.
Old Mar 6, 2021 | 11:26 PM
Vitaminmopar's Avatar
Vitaminmopar
I bought the Gel version of Evapor-Rust to remove the rust off the back of a 64 clock. Has a phosphoric acid smell but maybe citric acid and not phosphoric that I was smelling. I give the gel a D grade as I had to apply 4 times, it dries out and because of the odor. I think the liquid is superior in every way and since it does not have an odor will keep your wife out of your business.
Old Mar 6, 2021 | 11:33 PM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
What is the difference between Evapo-Rust and naval jelly? I’ve used naval jelly for years!
Old Mar 7, 2021 | 01:05 AM
55hans55's Avatar
55hans55
I use ospho turns it to a black surface that won't rust again bought a gallon online at ace for 27.00 look it up great stuff I used inside rusty motorcycle tank
Old Mar 7, 2021 | 06:06 AM
Frankie the Fink
Army
Ospho is corrosive and hell on garage floors; Evap-O-Rust can be saved and reused and is not caustic.
Old Mar 7, 2021 | 07:53 AM
DinoBob's Avatar
DinoBob
I strain my used Evapo-Rust and put it right back in the container.
Old Mar 7, 2021 | 08:00 AM
tgtexas02's Avatar
tgtexas02
The lowes or home depot liquid versions work really well. Nice part is that it does not seem to attack paint. It is nonflammable and works much, much better at warmer temps too. I have used in a heated sonic bath and it has speeded things up tenfold.
Old Mar 7, 2021 | 12:56 PM
mrtexas's Avatar
mrtexas
Rust911 is a clone of Evaporust, 16x cheaper and comes as a concentrate.
Can be mixed up stronger as well for quicker job. $60 for gallon of concentrate which
makes 16 gallons diluted to Evaporsut strength. So $5/gallon vs $30/gallon for Evaporust. I've bought many gallons
but part must be submerged in the liquid and won't work painted on.
The stuff work miraculously on some parts since it leave no residue. I fixed an old Ford glove box door with the hinge
a piece of rusted wire folded over sheet metal. Don't know of another product to fix that one. After treatment the
liquid ends up black from the carbon in the steel. Stuff is not phosphoric acid and doesn't sting your skin.
Old Mar 7, 2021 | 01:36 PM
jkinton's Avatar
jkinton
Evapo Rust is amazing stuff.
See the photos of my brake calipers before and after in this post:
https://www.corvetteforum.com/forums...post1590607749
Old Mar 7, 2021 | 03:10 PM
LeeS's Avatar
LeeS
Sounds like great stuff, would this be the right stuff to clean up a frame and other bits underneath?
Old Mar 7, 2021 | 03:49 PM
gleninsandiego's Avatar
gleninsandiego
I love Evaporust liquid. Half my car has soaked in it. LOL
However, as stated above, I had bad results with the gel.
Quick Glo worked great on my shiny bits
Old Mar 7, 2021 | 03:59 PM
DinoBob's Avatar
DinoBob
Good tip, thanks!
To surface rust cleaner
Old Mar 7, 2021 | 07:42 PM
mrtexas's Avatar
mrtexas
To soak a frame you would need a container big enough to soak it and 100+ gallons of juice. And requires a clean surface with no grease or oil on metal to work.
Old Mar 7, 2021 | 08:00 PM
tgtexas02's Avatar
tgtexas02
It really works best when parts can be completely submerged for a couple hours to 24-hours. Fantastic results on light surface rust. Badly pitted items come out very clean showing all the clean badly pitted areas. It only attacks the rust and not the base iron piece. Something as large as a frame would be better sandblasted or professionally acid dipped.
Old Mar 7, 2021 | 09:47 PM
SonnyAK's Avatar
SonnyAK
I've had pretty good results using Evaporust on areas that I can't easily dip by brushing it on the surface, then covering it with a cellophane wrap to keep it from quickly doing out.
