Engine Stamp Question
Old Jan 20, 2022 | 08:37 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by LuckyGuy
I'm confused. Who would have added the paint and why?? And are you saying that the orange paint on the engine was somehow carefully applied so that it did not cover any part of the engine stamp??
Someone who wanted the engine to look better than it did is who painted it. Previous owner, reseller, who knows – but it wasn't the factory's engine paint guys.
The factory's painting was very quick and haphazard. For example, the water pump was installed prior to paint, so there should be unpainted block and timing chain cover immediately behind it; in some instances the exhaust manifolds were installed and blocked off the sides of the block from getting paint; the manual trans bellhousing was attached so it got a shot of overspray when the back of the block was sprayed. None of this matters unless you are going for a true restoration and judging.
The above came from an article, by John Hinckley, on Chevrolet's process for building a small-block. Big blocks followed a similar journey.
http://www.camaros.org/pdf/flint_engine.pdf
