Engine code help
Old Oct 23, 2023 | 07:54 PM
Willysvette's Avatar
Willysvette
8th Gear
Default Engine code help
Hello. I have a '53 ****** with a '67 (from what I can gather) 327 from a Vette.
Casting at rear is GM 3892657
Stamping at pass side front of head is V0524XXD.
I think the 'V' means Flint.
Can anyone decipher the rest?
I've got it pulled so as to rebuild it this winter.. trying to figure out the specs etc.
Thanks.
Old Oct 23, 2023 | 08:14 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
V0524XXD
XXD is not a valid suffix code. can you get a picture of the pad
Old Oct 23, 2023 | 08:27 PM
Willysvette
8th Gear
Old Oct 23, 2023 | 08:30 PM
Jdsal's Avatar
Jdsal
Old Oct 23, 2023 | 08:42 PM
Willysvette
8th Gear
Oh oh.. got the popcorn emoji after my second post... that's not good lol
Old Oct 23, 2023 | 08:53 PM
Nowhere Man
that is puzzling for sure. three-digit suffix codes was first used for the 70 model year. XXD is not listed anywhere. there is a XX and a XD both 69 truck engines
Old Oct 23, 2023 | 09:01 PM
Willysvette
8th Gear
Well we were told from the old guy we bought it from that the tranny (Muncie) and engine were from a Vette.
Digging around online, it seems the xxd could be from any number of Chevy's.. including Camaro. There's no definite info about what it means (warranty, marine, truck, ag), but others have found it as well.
Interesting thing is that when I rebuilt the Muncie and Hurst shifter last winter the guy said the shifter was off a Camaro.
It's a 327... that's for sure and '67-69 for all intents. Maybe the head casting numbers will shed some light...
Thanks.
Old Oct 23, 2023 | 09:13 PM
R66's Avatar
R66
The casting number looks like a 67 327 or 350. If it is a 67, it will have the draft tube opening at the back of the block, last year before the PCV valve. 69s did not have a draft tube.
Old Oct 23, 2023 | 09:15 PM
Willysvette
8th Gear
It has the draft tube....
64L76's Avatar
64L76
According to the "Lime Book" --- XX was a suffix for 69 350 cu in truck engines, 255 HP, 4 barrel carb and manual transmission. It does not show an XXD suffix.
Old Oct 23, 2023 | 09:16 PM
65GGvert's Avatar
65GGvert
Probably won't help in any way, but I saw this:
http://www.camaros.org/forum/index.php?topic=16466.0
And this same question:
https://www.camaros.net/threads/need...-block.190619/
Old Oct 23, 2023 | 09:25 PM
Willysvette
8th Gear
Ok.. I mistakenly thought that casting # was just for 327 but now I see they did 350 as well.
So only thing certain is I got a Chevy motor most likely a 67... losing ground here!
Any tips on id'ing this appreciated.. going to be tearing it down shortly.
Would the head casting #'s peg it as a 327 or 350?
Old Oct 23, 2023 | 10:19 PM
3154tm's Avatar
3154tm
if it's a '67 350 would it have large main journals?
Old Oct 23, 2023 | 10:33 PM
gbvette62's Avatar
gbvette62
The "657" block was a 67 block used for 67 Z/28 302's, 67 327's and 67 Camaro SS 350's. I'm pretty sure the 657 is a small journal block.
I seem to remember reading something years ago on the Camaro Research Group website about 63-67 blocks with XXA, XXB, XXC, and XXD suffix codes being a Chevrolet "Service Assembly Engine". I think it said they were complete over the counter and warranty engines less exhaust manifolds, distributor, water pump and carb. Basically the for runner of 1969's CE replacement blocks.
Welcome to the Forum!
Old Oct 24, 2023 | 02:32 AM
Boyan's Avatar
Boyan
Default Code
Every used 327 sold came out of a Corvette
Old Oct 24, 2023 | 08:35 AM
64L76's Avatar
64L76
And they were all fuelies too.
Old Oct 24, 2023 | 08:41 AM
JohnnyRay's Avatar
JohnnyRay
The referenced casting number is a 1967 (MY) only, thus wouldn't apply to a 69 build.
My 67 MY L79 has this same casting. Built November 8th, 1966...
I would believe that "XXD" references a service part that is not decoded in the Lime book. Hopefully, someone will come up with a decoder for 1967 era service parts to solve the mystery.
To Engine code help
Old Oct 24, 2023 | 11:29 AM
Boyan's Avatar
Boyan
Default Code
There is no mystery. It’s a service block that could have gone into anything. Never came in a Corvette. You can do what you wish with it.
Old Oct 24, 2023 | 12:00 PM
JohnnyRay's Avatar
JohnnyRay
I agree that it did not originally come in a Corvette...but there IS a mystery. The mystery is the definition of what the "XXD" stamping represents. If you have the decoder documentation that defines this, then you should share it with us, please...
Old Oct 25, 2023 | 09:18 AM
apahl's Avatar
apahl
I also have never seen a 67 small block with a three letter code. However, we have a common Yale forklift at our museum that has a serial number that is untrackable, even by the Yale service folks. Someone said it could be from the military?
